Question about Onkyo Audio Players & Recorders
Onkyo AV Reciever Model #HT-R540 was given to me by a friend, it had been violently dropped by UPS, upon taking it apart noticed one of the plastic standoffs had broken through the circuit board in one of the amplifier sections near the heat sink. Bypassed the broken area by soldering wires and repaired a few cracked circuit traces, haven't found any more obvious problems. System won't power up at all, no standby light, line fuses are good and line voltage is present, and am receiving voltage output from the small transformer, a little confused about where I should measure voltage on the larger transformer. Help Please!
5 Suggested Answers
  • 4234 Answers
SOURCE: Yamaha RX-V420 No power
If the standby voltage exists, the next step is to see whether or not the clock is working. Find the main micro chip. There should be a 3 legged crystal close by. You should see this oscillate (use a scope). No oscillation = no micro control = no turn on. It is possible that the micro is bad or the crysal is bad. Also, check to be sure that the output transistors are not shorted. It is also possible that these are preventing the system from turning on.
Dan
Posted on May 12, 2008
SOURCE: Onkyo TX-DS777 Problem
man I think i have the same problem....
i push the power button but immediatly the LED turns off. I cheked the fuse but thats not the problem. Please if you solve your problem let me know...
my e.mail adress soy_robertog01@hotmail.com
sorry if you dont undersatnd me in some parts..im not very good writting english haha sorry..
Posted on Jul 29, 2008
  • 4 Answers
SOURCE: No audio
I know that a couple of you have had the same problem with the blowing 0.47 ohm resistors. I had responded quite a wile back, but forgot to make any updates. Kostiko is correct about the problem relating to these two 0.47 ohm resistors being blown. In my case on two different Haman Kardon models, this was true, but there could also be another issue. What i have found is even after replacing these resistors, the problem appeared to still be there. What was happening was that right after turning the receiver on, the resistors would blow again. What you need to do is replace the two small ceramic disc style capacitors on the same pcb as the fusible resistors, as they could be shorted as in my case. You could remove these capacitors completely, or replace them with a similar size of the same type, as they are really just there for filtering higher frequency noises from the power supply. You can check them with your multimeter first. They shouldn't shorted even in situe. I forget the size, but they are approximately 100 nano farads. Good luck. I have done this to my AVR135, and it has been running great for about 6 months now.
Posted on Feb 03, 2009
  • 153 Answers
SOURCE: Power will not stay on
Activated protection circuitry means that the amplifier is seeing conditions it does not like and is shutting down the power to prevent further damage.
Either you have a short in your speaker wires, in your speakers, or a blown amplifier.
Disconnect both speakers and turn on the amplifier. Does it still give the error message? If it does, your amp is blown. If it does not, carefully inspect your speaker wires and their connection. Make sure all looks good and reconnect the speakers and try it again. Still get the error message? You likely have a problem in your speaker cabinet(s).
Posted on Apr 21, 2009
Onkyo ht-r530 subwoofer stopped working
Turn the out put leval down on your sub, End the reciever, I was turn up to high,End that will cause it to cut out.
Oct 20, 2012 | Onkyo Ht R530 Receiver 7.1 Surround Sound...
I have a Samsung HLP5063. Just bought a Onyko AV receiver with HMDI hook ups. Also connecting Dish 211VIP, and Samsung DVD connected to the receiver. I was able to get the DVD player to work, but no...
Have you gone through your onkyo receivers setup manual. You will most likely need to adjust the settings on your Onkyo receiver. I also have an onkyo reciever and I have to assign the inputs to the video source. Being that you got sound out of the front speakes. I am assuming when you were playing out of the dvd player your reciever was only on stereo sound. Once I get feedback I can assist you further
Thanks,
Lee
Sep 28, 2008 | Samsung Televison & Video
TV to Reciever Sound Problems
MAke sure your channel selection is correct.
Sep 17, 2007 | Onkyo HT-SR800 System
Black and white picture from blu ray player
Run the Blue Ray straight to the TV and see if the picture is still in black and white. If it is you know that your reciever is fine and the problem lies in the player or the TV. If the picture is normal then you probably have a bad HDMI IC that will need to be replaced.
May 09, 2012 | Onkyo TX-SR607 Receiver
I have an onkyo reciever HT-S580,that I want to connect up to my TV & my Bell reciever to get my surround sound system working.Where do I get a visual
You can download the owner's manual for your Onkyo a this link:
http://www.intl.onkyo.com/downloads/manuals/pdf/ht-s580_manual_e.pdf
It has drawings on how to connect just about what ever you want.
Good Luck
Feb 14, 2012 | Audio Players & Recorders
I have a n onkyo av reciever ht-r560 only the front 3 speakers go on when im using it i know the rest work and are plugged in correctly because the volume tester outputs sound through it. Is there an on...
Your sound might not be working because the HDMI and optical audio inputs might not be working.
I made the mistake of buying the Onkyo HT-560 and in less than two years all of the HDMI video inputs started intermittently breaking. Sometimes when you selected the channel both the image and the sound would not come though.
Also the rear speakers stopped working from time to time and I have to run the setup again to get them to turn back on.
I am not sure that Onkyo was ready to introduce this technology, it has been a nightmare and my stereo is going to cost almost as much as I bought it for to fix it.
Oh and there customer service was no help, they just told to bring it to an "authorized service center for repair". They had also had no idea where there was one in my city it took them a day to get back to me.
The Onkyo HT-S5100 looks almost identical to the HT-560 not sure if they are different in anyway.
Stay away from Onkyo in the future! I know I will.
Sep 02, 2010 | Onkyo HTR500 Receiver
Apr 21, 2009 | Onkyo HTR500 Receiver
Center speaker will not work
If you had the Speakers Set to A (not B) and no headphones connected when you pressed the TEST TONE button on the Onkyo HT-R540 (also known as the HTS-790) remote, and you had no sound from the Center Speaker then try the following steps. 1) Check the Center Speaker wiring at both ends under a bright light and make sure that there is not a strand of wire touching the Receiver Chassis or another speaker post. Check both + and - . If that looks okay, 2) unscrew the Center Speaker Post connections on the Receiver and verify that the bare stripped wire is making contact. Often, the insulation is too far into the connector. When screwed down, the wire's insulation is crushed and keeps the bare wire from making contact. If this looks okay and the unit is under Warranty, your last test is to: 3) temporarily swap the wires from the Center Speaker with the Right Front Speaker. Turn the volume down low and try the TEST TONE button again. If you now hear sound from the Center Speaker box itself and none from the Right Speaker box, then the Receiver is the problem. If you still do not hear sound from the Center Speaker box, then the Center speaker itself is defective.
Sep 25, 2007 | Televison & Video
Problem with Onkyo HT-SR700
Can you explain how you have the DVD player connected to the reciever and what the label on the jacks read on each.
Sep 16, 2007 | Onkyo HT-SR700 System
Onkyo HT- S790 installation manual
You can find manuals for Onkyo products here http://www.onkyousa.com/download/own_manuals.cfm
Jul 22, 2007 | Onkyo HT-S790 Home Theater System System
313 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
