Question about Honeywell HHT-145 Air Purifier
After cleaning and replacing filters, won't turn on
Pretty much said it above, it won't power up. I made sure filters are properly in place after I vacuumed them out, and ruled out a problem with the outlet. It did power up before I turned it off and took the filters off. It had been working fine for a few months. Thank you for your help! Andrea Hankins
I have had the same problem. The way I fix mine (it only runs for a couple days staight) is to switch the two filters (or maybe you just need to remove completely?) making sure they are in tight. Replace the cover and it should work!
Posted on Dec 03, 2008
I had to blow mine out with an air compressor. I tried everything else, but this was what eventually got mine working.
Posted on Dec 03, 2010
Alpine Air XL-15 Air Purifier - never taken out of box - won't turn on whatsoever. Plate is accurately placed and the rear filter is properly fitted.
Is the fuse in properly? Try popping it out and put it back in, also check it when it is out..just to be redundant since you did it already. push on the bottom of the filter the switch pushes in . I at pushed down my first time.
Jul 06, 2012 | Alpine Air XL-15 Air Purifier
How do you reset the filter reminder warning light?
Filter Replacement
Filter Replacement Indicator:
Your Defender® is equipped with a Filter Replacement Indicator located on the front
panel. Anytime this red indicator flashes, it is recommended that you call your authorized
FILTERQUEEN® Distributor to order a replacement filter. Anytime this red indicator stops
flashing and remains solidly illuminated, it is recommended that you change your filter. To
receive full benefit from your Defender® and to extend your warranty, it is strongly
recommended that you follow the filter replacement schedule suggested above. Under higher
pollution levels, your filters will need to be replaced more frequently.
The Filter Replacement Indicator is operated by filter time in use and is controlled by an
onboard timer. After 11 months of time in use of your Medi-Filter® Cartridge, the Filter
Replacement Indicator will begin to flash. It will continue to flash until the you reach 12
months of time in use, at which time the Filter Replacement Indicator will stop flashing
and remain solidly illuminated.
After replacement of your Medi-Filter® Cartridge, you must reset the Filter
Replacement Indicator's timer. When the timer has been properly reset, the Filter
Replacement Indicator will turn off.
Resetting the Filter Replacement Indicator Timer:
After replacement of your Medi-Filter® Cartridge per the instructions found on page 7, the
Filter Replacement Indicator's timer can be reset by performing the following sequence of
steps:
1 Plug unit into outlet.
2 Press power On/Off switch to the On ("I") position.
3 Allow unit to start running at low speed.
4 PRESS and HOLD both the Up and Down arrow buttons until the Filter
Replacement Indicator starts to blink.
5 Release both the Up and Down arrow buttons.
6 While the Filter Replacement Indicator is still flashing*, again PRESS and
HOLD both the Up and Down arrow buttons until the Filter Replacement
Indicator turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will
turn off and not flash again for 11 months. If the Filter Replacement Indicator remains
on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when
the buttons are pressed the second time. The Filter Replacement Indicator will continue
to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Note: Under higher pollution levels, your filters will need to be replaced more frequently.
Note: To order replacement filters, call your authorized FILTERQUEEN® Distributor, or call
1-440-846-7800 for the Distributor nearest you.
http://www.filterqueen.com/pdf/defender.pdf
Mar 02, 2011 | Filter Queen Defender Air Purifier
I have cleaned the filters, and i still get the Clean Filter message. It is running fine, but the red letters Clean Filter are still there... any suggestions???
How did you clean the filters? I run mine through the dishwasher by themselves and it works pretty good. The tops and bottoms of the filters near the edges need to be wiped pretty clean.
Jan 02, 2011 | Brookstone Pure-Ion (506840) Air Purifier
How do you turn off the little red filter llight above the low speed indicator?
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Nov 28, 2010 | Filter Queen Defender Air Purifier
I have a constantly blinking red light above the lower setting arrow...how do i resolve the problem???
Nov 19, 2010 | Filter Queen Defender Air Purifier
Replace air filter warning light to reset?
Sep 30, 2010 | Filter Queen Defender Air Purifier
Blinking red light above the lowest setting on filter queen defender air purifier.
Sep 23, 2010 | Filter Queen Defender Air Purifier
How do you reset the red light on the defender when you put in a new filter? My light has never went out and I think it is supose to .
It won't go out by itself.
Sep 16, 2010 | Filter Queen Defender Air Purifier
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
Red light on air filter
After spending hours searching for this supposed little hole easy to miss, I called customer service. I found out that it's easy to miss because it doesn't exist!
Here's the correct answer: Once you've replaced the filters, turn the unit back on. Then, with the machine running, press and hold down the on/off power button for about two seconds. The red light will flash and then turn off.
Oct 12, 2007 | Holmes Products HAP422-UC Air Purifier
Honeywell HHT-145 Air Purifier Logo
629 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
