Question about Saeco Vienna De Luxe Espresso Machine
Problem with machine
I took my brew group out to clean last night and when I go to insert it back in it does not lock in. Do you know why this could have happened?
  • 515 Answers
Open the door and put in the dregsbox and driptray to the machine, look at the chassis in the middle above the pin there are a hole, then look at the upper right corner and you will see another hole.
Turn on the machine and put a screwdriver in the middle hole and then another in the upper right corner.
Now will the machine do the self test, when it finish the self test then you can remove the screwdriver and put in the brewing unit and close the dorr.
Hope this will help you.
Best regards
/Mirran
Posted on Sep 06, 2008
While performing the descaling the brew group gets stuck
Have you check if the knob on the top of the machine to distribute hot water is fully closed. If on the edge, you may not get hot water flowing but the light may be on.
Look on page 12 of the manual. It explain the the meaning of the led flashing or stayed on from the control panel
Good luck
Aug 30, 2014 | Saeco Odea Giro Plus Coffee Maker
My Saeco incanto sirius coffee machine started the day with brew group blocked error. I have fiddled and got as far as it grinding beans before saying brew group blocked again. I took it out and now it...
If it stopped working after that incident of reset, could be. Water could have also gotten in the controls. I would use an air compressor and clean out all the alignment areas and switches.
Nov 02, 2013 | Saeco Coffee Makers & Espresso Machines
The brew unit still won't fit back into the machine. I have clarified the make of the machine as I think you were describing a different machine in the last instructions. I do believe it could be a matter...
Hi
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. (You can insert your key into the hole in the front and twist the key to return the brew unit to the center. Line up the 2 diamonds and it centered) If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must insert the drip tray and dredge drawer, close the door and turn on the machine without having the brew group in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray, and test.
Apr 08, 2011 | Saeco Incanto Sirius Espresso Machine
I was cleaning the grinder and brew cup. When i went to put the brew cup back in place i accidently pushed the PUSH button. Now i cant get it back in the machine. The gears to the brew cup seam to be off...
Hi
Apr 05, 2011 | Saeco Incanto Classic Espresso Machine
Hi i took out the brew group to clean and it wont go back in
Hi
You may have released the hold mechanism and it needs to go back. Follow these directions.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. (You can insert your key into the hole in the front and twist the key to return the brew unit to the center. Line up the 2 diamonds and it centered) If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in, but you must have your drip tray and dredge drawer in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray.
Feb 08, 2011 | Saeco Vienna Espresso Machine
When cleaning my Gaggia Titanium the brewunit got stuck and cannot move. It feels like it is askew with the right hand side (looking from the front) loose and the left side locked. The release lever is...
Remove the dredge drawer. Open the door. On the left side and towards the back of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly with a quick ****. The brew group should come out. There is a piece that remains in the machine. Slide the piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position. If your brew group did not come out please call your service center.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not just push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and insert the brew group. Done
Dec 23, 2010 | Gaggia Titanium Espresso Machine
I took the brewing out of the machine and tried to cleanit. By accident it clicked as it brewed coffee. Now I need to click it back so I can put back the brewing component to the machine. How can I...
This is for a Vienna but they are close and it should work.
Remove the dredge drawer. Open the door. On the left side and towards the back of the brew group, there is a single screw. Remove the screw. Squeeze until it clicks like you are going to remove the unit and pull carefully, but firmly with a quick pull. The brew group should come out. There is a piece that remains in the machine. Slide the piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position. If your brew group did not come out please call your service center.
Nov 24, 2010 | Saeco Incanto Classic Espresso Machine
Spidem brew group stuck in machine in wrong position.
Hi
Remove the dredge drawer as far as you can. Open the door. On the left side of the brewing unit, and towards the back of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly with a quick ****. The brew group should come out. There is a piece that remains in the machine. Slide the piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position. If your brew group did not come out please give us a call.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in, but you must have your drip tray and dredge drawer in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray.
Jan 09, 2010 | Spidem Cappuccino Instantly Espresso...
The brew group to my Vienna Deluxe is out of sync. I cannot get it to fit into the machine and then add the dump box for the grains. They do not fit. I do not want to force the brew group into place....
Problem: Brew group is out of sync. Brew group insertion. Brew group alignment.
Answer: Common to all Saeco superautomatics. After removing and cleaning the brew group, it will get onto the supports but will not lock into place as the gear is not aligned. With the brew group on a clean, well lit table, use a pair of chopsticks and a friend to assist. There is a small lever arm on each side that is accessible from the outside of the brew group. As the carriage slides down towards the correct position, the arms are seen 1" above the drive gear and towards the handle side of the brew group. Gently push in the lever so it slides inside of the locking bar. Both sides need to get pushed in at the same time so it helps to have a friend hold the brew group and push in one side while you pull down on the carriage and push in the other lever. The chopsticks insert into the half-moon on each side above the locking mechanism.
Jul 31, 2009 | Coffee Makers & Espresso Machines
Saeco Vienna De Luxe Espresso Machine Logo
196 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
