Can you use a digital camera to view your remote to see if it is sending out signals when it should not? It might have dirty buttons from food or other dirt. This can cause it to send signals even when the buttons are not being pressed.
It part of the caption functions is on.Tries find in ur tv menu,goto captioning functions like CC1,2,3 and Text 1,2,3.Turn it all off.These radom black boxes and trying typing somethings,should stop.
The menu button on the TV itself is bad and must be replaced ( or removed ). Alternatively the whole front button assembly can be disconnected. Just follow the wire back to the main chassis and unplug it.
It could be dirt/dust has accumulated behind the buttons causing a false contact so it looks like a ghost is operating your tv making things appear and disappear.If this isn not the problem then there is a faulty component on the board where the buttons are located. If you are able to do the cleaning of the buttons yourself use a cleaner that de-greases as wel and make sure everything is bone dry before re-assembly. If not find a competant technician. Hope this helps.
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
how to fix the time on a toshiba model 32A43
