Question about RCA HD52W59 HDTV Projection Television
TRANSFORMERS I bought this TV about 2.5 years ago. All the sudden I turn it on and I hear what sounds like an electrical short and I smell electrical burning. I currently have it in the repair shop and they tell me it is the flyback transformer and a high voltage transformer. Cost of repairs including pickup is $582.00. I would like to know just how difficult it is to repair this myself. They tell me parts are only $122.00 and the rest is labor and pickup/delivery fees. HELP!
  • RCA Master
  • 8,617 Answers
You can get the parts at the following link and they provide free online instant messaging for free. or they can rebuild your entire deflection board for just a little more than what the parts cost and guarantee the board for 6 full months. Heres the link. you can leave them a email if you would like more info.
http://servicemanuals.vstore.ca/
Posted on Sep 06, 2008
My kettle is all other sudden not heating up water
Sounds like the heating element has burned out or is shorted, they don't repair this type of appliance they just replace it.
Oct 14, 2016 | Cuisinart CPK17 Electric Kettle
I was watching my television, then suddenly I hear a "pop" noise and the screen goes blank with no sound. I then hear a faint, repeating electrical "clicking" noise toward he front of the television. ...
Hello
Your TVs LOT [Line Output Transformer] may be got shorted. It can be replaced. There is no need to replace the picture tube. The noise you hear from your tv is due to this short. Contact any service technician or authorised service center.
Oct 18, 2010 | Sharp 36F-830 36" TV
My samsung tv went out.
There are a few other problems like the ballast or color wheel. Hear any sounds? Smell anything?
Feb 04, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
It won't turn on
The smell of something burning is not a good sign. The clicking sound you are hearing could be a relay or breaker kicking in and out as a result of whatever is wrong.
This could be cause by:
1. A problem in the power supply.
2. A problem with the Horizontal Output Stage.
3. The Flyback transformer.
Someone gave me a TV once that had the same problem. I determined that it had a bad flyback transformer. I replaced the transformer and the TV worked about 5 secs before I saw some black smoke come out of the new flyback. I turned it off right away and realized that something else was bad that caused the original flyback to burn up. The same thing was causing the new flyback to go as well. It turned out to be a shorted, 50 cent hi-speed switching diode. Fortunately, because I had turned the set off quickly when the 2nd flyback started to smoke, once I replaced the diode, the TV was fixed.
If you want to get it working again, you'll need to have it serviced.
Good luck,
- Jim
Jan 26, 2008 | Zenith B27A11Z 27" TV
TV won't turn on.
The buzzing sound could be due to either a bad filter capacitor in the power supply or a shorted component further down the line keeping the power supply from running at the correct frequency.
Jan 12, 2008 | Sylvania 6427FF TV
TV working, then suddenly no picture, no sound
could be flyback transformer cracked need replaced 48.00 for part or board replacement usually done at about $200.00 , part number is 9-2022
Nov 24, 2007 | Zenith A25B33W 25" TV
Rca d52w15
Possible short and safety is keeping the set from burning up. A service man should be able to find the short hopefully in a small amount of time.
Nov 05, 2007 | RCA D52W15 TV
LG colour TV RI32CZ10RX problem with picture
My LG tv has suddenly got a problem with the picture. Whilst watching the tv with no problems at all, the picture was suddenly reduced to a thin vertical line down the centre of the screen and an awful smell seemed to come from the tv There is a short ckt in your tv in horl. section. 1 isolate power from horizontal section. 2 check for normal output from power supply. 3 check parts in horl output section a hor.output transistor b diode & cap in h/output trnsformerckt. c check for print. d if all are ok check for eht transformer. e if every thing becomes then reconnect hor output section supply. f put on the set.
Sep 23, 2007 | Televison & Video
Philips 27PT6442/37 power
Sounds like you have a short in your power supply load. Probably the high voltage transformer and/or horizontal output transistor. Stargazer P.S. I've found that a lot of the newer sets are prone to high voltage transformer failure.
Aug 11, 2007 | Philips Magnavox 27MS343S 27" TV
Loud electrical sounds
It sounds like the Power transistor that drives the High Voltage Transformer shorted out. The rapid clicking sound you are hearing when pressing the power button now is that of the power supply starting to come up, detecting a short circuit and shutting back off again, preventing further damage. It is likely that the HV Transformer is shorted as well which usually causes the Output transistor to fail. Since the set is only 2 1/2 years old, it is probably worthwhile getting it to a repair shop as long as you have been very satisfied with the picture quality up to this point. If the picture size was larger than you needed, you might consider going down to a 37" LCD HDTV set. Toshiba is tops in this category IMHO.
Mar 30, 2007 | Zenith R40W46 40" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
77 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
