Question about Sport & Outdoor - Others
1989 MOTO 4 YAMAHA 250
ENGINE IDLES BUT STALLS ON QUICK EXCELARATION.
  • jcoyne87 Mar 18, 2009
    engine idels good but after 5 min. of riding around engine dies
  • r_giles May 19, 2009
    1982 kz250 can't get it to go over 40mph down hill, my son bought it because it ran smooth in a parking lot, but when we got it on the road it can go faster in a parking lot than on the hyway
How much oil does sump hold
Posted on Sep 16, 2008
Head torque specs on 1987 Yamaha moto-4 350 Quad
Try this manual hope it helps,
http://www.maultechatv.com/techguides/Service%20Manuals/YAMAHA/Bruin%20350.pdf
Aug 09, 2016 | Yamaha Motorcycles
Where does the positive wire go from the battery on my 1988 yamaha moto 4 250cc?
Hi, Kenny how about a wiring diagram for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $8 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
1988 yamaha moto 4 250 wiring diagram Google Search
Yamaha Moto 4 250 service manual repair 1989 1991 YFM250 Download Manuals...
http://www.yamaha-motor.com/assets/service/manuals/2001/lit-11626-14-09_246.pdf
Jun 25, 2016 | Yamaha Motorcycles
What makes 2003 pt cruiser idles bad changed coil ,spark plugs,wires, timing belt and injictors
Fuel is metered based on a signal from the coolant temperature sensor. When the sensor fails the engine is slow to start.When the sensor gives a false signal of over heating it causes problems like yours
Aug 31, 2014 | 2003 Chrysler PT Cruiser
Need connecting rod big end bearings for FZR 250
Hi, Carel for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Yamaha FZR 250
http://fzronline.com/forum/viewtopic.php?f=8&t=11899
Yamaha FZR400 1988 1989 Service Manual
OEM parts for Yamaha
Feb 16, 2014 | Yamaha FZR 250 Motorcycles
2007 yamaha virago 250 starts, idles ok, bogs at acceleration
Hi, Anonymous and the usual suspects are:
1. Throttle cables misaligned or misrouted.
2. Damaged or restricted fuel tank venting system.
3. Intake system air leak.
4. Vacuum piston malfunction.
5. Pinholes or torn diaphragm.
6. Accelerator pump leaking or no output.
7. Plugged bowl vent or overflow.
8. Fuel level in bowl too low.
9. Restricted fuel supply passages.
10. Plugged jets or passages.
11. Worn or damaged needle or needle jet.
12. The enrichner valve not seated or leaking.
http://www.starbikeforums.com/forums/18-engine-work/5238-engine-bogs-past-1-4-throttle.html
Bike idles perfect but dies when given the slightest amount of throttle 93...
Yamaha XV250 Services Manual
Yamaha VIRAGO XV250P Owner Manual
Nov 09, 2013 | 2007 Yamaha Virago 250
Yamaha star 250 stalls when the throttle is applied
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
https://yamahaclub.com/forums/topic/15251-idles-fine-but-dies-upon-throttle
Yamaha XV250G Supplementary Service Manual
Yamaha Star XV250X Owner Manual
Oct 20, 2013 | 2010 Yamaha V Star 250
I need a blueprint assembly of the yamaha fzr400 engine
Hi, Glenn_tapaya for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. For more information about your issue and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
1989 1994 Yamaha FZR400 Service Manual FZR 400 Moto Data Project
http://www.dropthecheese.com/manuals/FZR400_Service_Manual_Ch23.pdf
Yamaha FZR400
Tips and Tricks for Motorcyclists
Apr 27, 2011 | 1989 Yamaha FZR 600
What other year plastics will fit a 1992 yz 250?
Hi, Smiley1984rb for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
1989 YZ250 what year plastics will fit Yamaha 2 Stroke
http://www.vitalmx.com/forums/Moto-Related,20/YZ-plastics-conversion,1275415
YAMAHA YZ250 LC Owner Service Manual
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Feb 17, 2011 | Yamaha YZ 250 Motorcycles
Engine oil plugs?
Just oil,The same you run in the rest of the engine.
May 14, 2009 | 2004 Yamaha YZ 250 F
Sport & Outdoor - Others Logo
807 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
