Question about True 19 cu. ft. / 538 liter Commercial Freezer T-19F
Wiring daigram looking for a wiring diagram for a true t-19f freezer can you help mvp59@verizon.net
  • True Master
  • 1,218 Answers
Go to "truemfg.com". You can fill in your info on the home page and gain access to a 24 hour, on-line tech support. Worth a try.
Posted on Mar 07, 2009
110v surge protector that conserves power for freezer
A surge protector for a freezer is a good idea. To conserve energy? On paper it looks good but seriously only real savings are on bigger equipment.
Apr 25, 2014 | True 19 cu. ft. / 538 liter Commercial...
Door swing
yes any door swing can be reversed.take a good look and you will see the screws covered up with plastic covers .the door has to be removed first but check it out and you will see its not a big job get everything ready and it can be done within 10 minutes.adrian,,,,
Jun 29, 2010 | True 19 cu. ft. / 538 liter Commercial...
Need wire diagram how to install 3 N 1 start relay on a true t12f freezer
The two stripped black wires connect to power.
Black tabbed wire to common.
Red tabbed wire to run.
White tabbed wire to start.
Looking at pins on compressor, read like a clock. Common clockwise to Start clockwise to Run
Apr 29, 2010 | True 12 cu. ft. / 340 liter Commercial...
What could cause an evaporator coil to freeze up on a true t-19f. Also what is the suction pressure on this model.
Hello
Could be low on freon,i belive this model uses 134A.
So the suction pressure should be 31 to 35 psig,for a temp of 36 to 40.f
Also check the defrost timer and the door seal. The eveap should have a drain line on it, make sure this is working and not plugged.
Apr 07, 2010 | True 19 cu. ft. / 538 liter Commercial...
IM CHECK THE 72-F OF A CLIENT AND ALL WIRING IN THE EVAPORATOR ARE DISCONECT.I NEED A DIAGRAM
i think the best thing to do is call true mgf. and ask them to fax or email the diagram for you they might want a serial number as well
Toll Free: 800-325-6152
hope this helps
Mar 29, 2010 | True 72 cu. ft. / 2039 liter Commercial...
Condensing unit terns off but won't come back on kicks off breaker
If it runs, turns off, then tries to restart and kicks breaker, look for bad start components. Check start relay, start capacitor. It may be trying to restart too quickly and the compressor over amps and breaker trips. The system needs to have at least 3 minutes of off time before trying to restart. This allows the pressures in the system to balance enough so the compressor can overcome the high side pressure and start. I've seen where people turn the control up and down very quickly causing the compressor to over amp and trip breakers and over loads.
Hope this gets it for you.
Oct 22, 2009 | True 19 cu. ft. / 538 liter Commercial...
I NEED A DIAGRAM FOR DEFROST SWITCH ON T-72 F TRUE FREEZER
Go to www.truemfg.com and it will take you to their web site. They have a 24 hour, ask a tech a question. I could not find any wiring diagram on your particular unit but maybe they can help you via their tech hot line.
Good luck and hope this helps.
Apr 22, 2009 | True 72 cu. ft. / 2039 liter Commercial...
True 19 cu. ft. / 538 liter Commercial Freezer T-19F Logo
376 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
