Question about NEC (SPPL1067) Projector Lamp for MT840, 1040, 104
Lamp brightness It appears that the projector is not as bright as it used to be - is this a bulb problem?
    Novelist:
    Champion:
  • 277 Answers
Most projector lamps last approximately one thousand hours. Other possiblity might be the filter that has darkened due to heat.
Posted on Nov 27, 2005
SOURCE:
I have a Kodak Ektagraphic with no model listed on it at all. How can I find a replacement bulb, all I can find look wrong.
Supplied with 82V, 300W EXR lamp Projection Lamps Quartz-halogen 82 V projection lamps- Here is service manual link http://resources.kodak.com/support/pdf/en/manuals/slideProj/manual/ektagraphic_sm.pdf Several different Models all say EXR 300W As CORRECT Bulb : EXR, 300 W (35-hour lamp life at full lamp/medium-brightness) Sampling of other lamps: EXY (200 hours/less brightness) EXW (15 hours/maximum brightness) FHS (70 hours/medium brightness) Use combinations of lamp brightness, plus half- and full-lamp settings to approximate image brightness in multi-projector presentations. Lamp Tips • Projector operation on line voltages above 125 volts greatly reduces the lamp life. • Unplug the projector before changing the lamp. • Allow for unrestricted flow of air to the exhaust vent to prolong lamp life. • Gently wipe off any fingerprints with a soft cloth moistened with rubbing alcohol.
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
Jun 27, 2016 | Kodak ATS Ektagraphic Slide Projector
Brightness Flickering
1,the mother board is good
2,the lamp ballast is good
3,the lamp is defective, replace it with a new bulb ,
you need a new Original lamp (USD290)
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 24, 2014 | Sharp Office Equipment & Supplies
The image is very dim, even on maximum brightness. We are considering replacing the bulb, but bulbs for this projector are very expensive and we suspect that since there is some image, the bulb is not the...
Yes, as bulbs age they will begin losing brightness. Most projectors have a bulb life hour clock, that measures the number of hours a bulb has been used. Usually you can pull that up within the menu of the projector. Also that particular model has what is called "Eco-Mode" and when engaged dims the bulb by 25% to cut down on power consumption.
Typical life for a lamp in that projector is:
3000 hours on Normal mode
6000 hours on Eco mode
You can expect a brightness loss of 50% when you are approaching end of a lamps life.
Mar 07, 2011 | Hitachi Cpx2510 Projector Cpx2510 Xga...
We have had this projector for 2 years. The projector will not turn on. It will turn green for 3 seconds then turn red and the lamp light turns red. I feel like the lamp could not already be worn? I was...
Whether or not you need to replace the lamp depends on how many hours of use it's had. You should be able to find the lamp time somewhere in the menu on the projector. Lamps for this projector are rated for 2000 hours (bright mode) or 3000 hours (Eco mode). In my experience they usually need changing at approx. 1500 to 1600 hours (bright mode). On Page 54 of the owners manual ( http://www.projectorcentral.com/pdf/projector_manual_4177.pdf ) are instructions for changing the lamp and zeroing the timer once it's changed. The lamp is Type number : DT00911. You should be able to get one from the manufacturer, the dealer you purchased the projector from, or specialty bulb and lamp stores. Be prepared. They aren't cheap, but it's better than having to buy a new projector.
Jan 14, 2011 | Hitachi CP-X450 LCD Projector
I replaces my bulb in the sony vpl-hs10 and it still will not turn on after I reset it what do I do now? the lamp light is still lite it turns on but the lamp does not project anything
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS3.
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
Nov 19, 2009 | Sony Cineza VPL HS2 Multimedia Projector
Sony vpl-hs20 cineza projector- reset lamp counter
Jul 19, 2009 | Sony VPL-HS20 Multimedia Projector
Image brightness
go into the menu under service and status and check the lamp hours. the lamp is good for 2000 hours.
Jun 14, 2008 | InFocus Proxima DP1000X Multimedia...
Optoma EP732H Projector - Image is Whitewashed
Hi tourblack
I wouldn't think that this is a lamp issue , as the lamp will make the picture fade away in brightness and wouldn't look white washed.
Check if the brightness is set to 50% and the contrast on 50% as well.
This could be a colourwheel that is in need of replacement.
May 12, 2008 | Optoma EP732H EZPRO DIGITAL PROJECTOR...
Infocus LP240 Projector
The bulb won't do that. What you're describing sounds like a light tunnel failure.
Feb 05, 2008 | InFocus Lamp Projector Lamp for LP240 [...
My picture brightness is uneven - there is a persistant bright field on my screen.
I have the exact same problem with my AE700. It a started about the same time, around 2500 hours for me. I lived with it untill I could afford a new bulb which arrived yesterday. The old bulb was still working at a 3603 hours when I installed the new one. But the new bulb didn't fix the problem for me either. I may try to take it apart this weekend and give it a good cleaning. Andy
Jan 07, 2007 | Panasonic PT-AE700U Multimedia Projector
96 people viewed this question
Top NEC Office Equipment & Supplies Experts
Jaime Hernandez
Adorjani Laszlo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
