Question about Samsung TXP2675WH 26" TV
Samsung TX-P2675WH Green Hue..Missing Blue?
I have a 26" Samsung TX-P2675 HDTV. The picture has more green than anything. Red seems to be working fine also but Blue isn't working right. I changed all three Video Amplifiers ICs (TDA6111Q) thinking one was bad but didn't fix the problem. Can anyone help me figure it out? I went through the service mode and tried to adjust it but also didn't work. Any ideas? Thanks for any help.
-Sam sung Blues
4 Suggested Answers
  • 458 Answers
SOURCE: Samsung CRT HDTV - Color Problem - Red, Blue, No Green
This will be a lack of green drive caused either by the green output transistor having failed or no green output from the driver IC. As to which you have depends on how old the TV is. These are located on the CRT base (square type board connected to the neck of the CRT. You would need a multimeter to check the voltages going to the green output on the crt. It is also very possible the CRT is internally faulty giving no green, if this is so, you will need the crt (tube) to be replaced,it is not very economical to do this now a days.
Posted on Jul 06, 2009
  • 10 Answers
SOURCE: Samsung CRT HDTV - Red, Blue, but No Green.
If their is no green chances are the chip for RGB on the tubebase has packed up its usually something like a TDA 6107Q
Posted on Jul 07, 2009
  • 7 Answers
SOURCE: yesterday my 46" dlp samsung
you can not solve this by your self you must have technication to open the set,,,thir must be some thing wrong,may be deg plug had moved from its place
Posted on Dec 23, 2010
Samsung HLR5067 has no green color in picture
I know this may seem dumb but if you are using component video (the red green blue with the white and red audio cables) it could very well be that the green cable (carries the green signal) is the problem. try changing the configuration (ex: use blue to carry the green signal and vice versa) if the green starts to work and the blue stops then its just your cable.
Oct 18, 2012 | Samsung HLR5067WX 50" Rear Projection HDTV
Sony 60" HDTV Plasma WEGA....Picture Problem
My guess is that you're not missing the color it just appears muted... That problem is a common one in both the 50 and 60 inch models. And if you change video mode with nothing hooked up you'll see a faint color where none should be...
That's simply dust in the optical block on one of either the red, blue or green lcd panel. Wipe it down with a non-linting cloth and a "light" amount of windex and you're back in business...
But check it out by switchin through the video modes with nothing hooked up.. The faint color you see if the lcd panel that's having the most problem and the one that's muting your green.
Bill
Nov 10, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Yesterday my 46" dlp samsung
Dec 23, 2010 | Samsung DLP HL-P5663W 56" TV
Color is all wrong on tv all of a sudden. Is missing some color, skintones are not right and lips are dark and colorless. Tried changing video hue/saturation, but it doesn't do anything to correct the...
If you are connected with a component cable (Green/Blue/Red/White/Red) then check the connections on the back of the TV and on the back of the input device (ie cable box or DVD player). Sometimes if one of these get loose then they can throw your color off.
Good Luck and please rate this solution....
Jan 08, 2010 | Westinghouse 26" LCD Flat-Panel HDTV
Philips 55P8288A tv has a dull color and a red hue.
This sounds Like the the coolant for your piture tube has become cloudy and needs replacement (usually blue or green tube - thats why the image seems ovrely red).It's a big job (labour wise) since completee dissassembly is required ($200-300). It can be done youreself - check out TVrepairkits.com to get the coolant and instructions.
You can confirm that this is the problem by dissassembling the unit to the point where you can view the face of the CRT's (red green and blue) directly.
Nov 28, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Samsung HLP5063 the blue and green seem misaligned
you have what they call guns in the back of the tv blue/green and red and sounds like they have came out of adjustment. as far as the picture being black and white you should get a tv technician to check it
Aug 04, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Color is weird.
Component Video Jack was loose.
Dec 14, 2008 | Sony KP-48V45 48" Rear Projection...
A GREEN HUE!!!
U have to make sure your xbox 360 is set to the HD pixels as your tv.
Dec 13, 2007 | Microsoft Xbox 360 Console
Samsung TXP2675WH 26" TV Logo
74 people viewed this question
Henry  Thomas
Henry Thomas
