Question about Dryers
Used maytag electric dryer installation question
We bought a used Maytag dryer, model LDE8406ACM. We need to connect the pigtail to it, but the colors on the wires on the dryer do not match the red, yellow, white and black of the pigtail.
Can you tell us how to connect this?
  • 706 Answers
First off, you should be wiring your power cord directly to the terminal block inside the dryer. If someone just cut off the cord that is terminated inside the dryer, and you are attempting to splice the new cord onto the old one.. you are making a mistake.. take the new cord and bond it directly to the terminal block inside the dryer. If you have a new 4-wire power cord, you are probably dealing with a red/black/white and green wire. ( assuming it is a four prong plug).. The black and red wires are the power lines themselves and should mate with the red and black wires inside the dryer. The green ( is frame ground) and is normally bonded to a stud near the terminal block or the dryer frame. The white is the neutral line and is normally tied to the terminal in the middle and between the red and black tie points.. In line splices should not be done on this appliance.. Hope this helps..
Posted on Sep 06, 2008
How do we change a 4 wire pigtail to a 3 wire? The 3 wire doesn't have color coded wires?
Hi.
Here is a tip that shows you how to hookup your 3 prong dryer plug...if you don't have colors the black wires are interchangable...
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
Aug 18, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
How to connect a four wire pigtail
The white wire goes to the middle terminal post on the dryer.
The red and black wires go to the outside terminal posts.Doesn't matter which.
The green ground wire needs to be attached to the outside metal case...anywhere. The easiest way is to put the eyelet on the screw that attaches the terminal cover plate when you put it back on. Sandwich it between the screw head, the plate and the case.
Hope that helps. Let me know if you need more info
Best, G
Aug 02, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
I am in the process of trying to hook up a 3 prong electrical cord to a 4 prong but dont know which colored cords go where? any advice?
Get an qualified person to do it. If you do not have any idea how to do it, you are better off having someone else do it. If you have a 3 prong receptacle, you need a 3 prong pigtail. And if you have a 4 prong receptacle, the dryer needs a 4 prong pigtail. The green is ground, white is neutral, red and black are both hot (L1 and L2). If you put a 4 prong pigtail on, remove the ground strap between the center post and the case. The green ground goes on the case, white neutral in the center, black or red to the left, what's left on the right. You can interchange the red and black but NOT the white or green. If you use a 3 prong pigtail, the center is the neutral (same as white on the 4 prong) and you will need the ground strap between the neutral (center) and the case. The wires do NOT cross over on a 3 prong pigtail.
Dec 31, 2009 | Maytag Dryers
Maytag (2002) electric dryer quit working, has no power.
Part number LA-1053 is a high limit t'stat/fusable link kit. A restricted vent is the number one cause for failure of these components.
After making sure vent is thouroughly cleaned you may want to have a pro come out to install the kit. If you decide to tackle it yourself, mmake sure POWER IS REMOVED from dryer, prior to attempting repairs.
Nov 04, 2009 | Dishwashers
How to hook up a cord to the maytag neptune dryer color codes
these are single phase so just copy red to red black to black white to white and green is ground
May 04, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Atlantis MDG8400AWW Dryer Runs Cool
I had a similar problem years back. It was the ignitor. The ignitor is a ceramic like piece that heats up (glows red) that ignites the gas. Typically when that goes, you will see some white residue build up where it cracked, thus breaking the electrical connection. This thing works like a heating element on an electric stove, but rougher looking.
The part was about $30 at my local parts store. I bought an extra one just in case so I have it on hand. I installed it with common tools.
You can check it to see if you lost connection by using a volt meter.
Good luck.
Dec 29, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
MAYTAG DRYER ELECTRICAL CONNECTION
how do you change a 3 prong plug to a 4 prong plug when the colors dont match on the wires to the dryer?colors on the wires are red white black and green. colors on the terminal of the dryer are a black and yellow tied together a white in the middle and 2 blues tied together. this is a maytag atlantis dryer. thankyou chad....
Jul 30, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Correctyly wiring power supply to Kenmore dryer
A three wire pigtail is connected thusly. The two outer wires go to the two outer terminals on the dryer, the center lead goes to the center of the dryer terminal block. If its a four wire pigtail, the outer leads go to the two outer terminals on the dryer, the white goes to the center terminal. The jumper strap on the center is removed and the green goes to chassis ground.
Sep 16, 2007 | Maytag Neptune MDE7500AY Electric Dryer
Dryers Logo
222 people viewed this question
Top Dryers Experts
