Question about Canon PowerShot S1 IS Digital Camera
Flash is jammed down.
What can one do to fix the flash that will not pop up without some manual physical help?
I've had this problem myself... I can get the flash to come up if I help it a bit by pushing the shutter button a bit (not all the way, but just so the flash tries to come up) and then lifting the flash myself. However, the flash won't take unless the camera thinks it came up on its own. Once the flash IS up, turn your camera off. Turn it back on, and it should work like usual :)
Posted on Mar 12, 2007
    Novelist:
    Champion:
  • 277 Answers
Hi, 1. Check that batteries are fresh. 2. Check that camera hasn't been set for no-flash mode. There is nothing more you can do to fix it, call for service sorry.
Posted on Nov 24, 2005
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Nikon D40. How do i force the flash to work in daylight?
First, you have to be in one of the PSAM modes; in the other modes the camera decides whether it needs the flash and in daylight it will decide there's enough light without it. So, after turning the model dial to one of the PSAM positions, press the flash button on the front of the camera to pop up the flash. In these modes the camera will fire the flash if it's popped up, and not if it's down.
To change the flash mode, hold down the flash button (after it's popped up) and turn the command dial. Depending on the chosen exposure mode, your choices may include Fill flash, Red-eye reduction, Rear-curtain sync, Slow sync, Rear-curtain plus red-eye reduction, and Rear-curtain plus slow sync. Refer to the "Flash Mode" section of the manual for full details.
Jul 30, 2011 | Nikon D40x Digital Camera
I was using the D80 with an SB-800 Speedlight and at one point the buit in flash popped up. I now cannot get the built in flash to lock in the down position.
This must be because the SB800 was not seated in properly or was turned off when you used the cam.
Use one of the manual settings (A or S) and you should be able to keep the built in flash down (unless it was physically damaged that u need to bring it to the repair shop)
Dec 21, 2009 | Nikon D80 Digital Camera with 18-135mm...
The flashgun doesn't pop up when it should. It remains jammed.
Ok
Its not clear how you are using the camera.
Check the settings on the left. Some settings (Landscape for example will not allow the use of flash)
Set the camera to P,S,A OR M and it will. In Auto it will pop up if it needs it. It It still won't work Look at the menu settings for Flash Mode two settings 1) TTL and the other Manual. I have my D50 set to TTL using the built in flash and manual when using an external flash mounted in the shoe.
Hope this helps
Dec 12, 2009 | Nikon D50 Digital Camera
Canon eos flash beeps 3 times and won't pop up. error 5 comes up on lcd screen. tried turning off, removing card and battery still have problem.
Typically this happens when the pop up flash is jammed. Go into P mode and press the manual release on the left side to pop up the flash. Wiggle and giggle it. It seems to happen after being packed with something resting on top of the flash unit. I thnk it simply gets slightly out of alignment.
Good Luck.
Feb 22, 2009 | Canon Cameras
Nikon d 80 flash will not pop up while in auto mode
The flash up button is located on the left hand side of the camera right near the top.   You should use this button to pop up the flash. Prying it up could/has broken this button.
Also, depending on what setting you are using, the flash doesn't always pop up automatically.   Check to see what mode you are in, on the round dial on the left -- ie  Auto, Portrait, Manual, etc.   I can move sometimes without your knowledge, and this may be the problem.
Apr 15, 2008 | Nikon D80 Digital Camera with 18-135mm...
Canon XTi Built in Flash
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Feb 09, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Disabling Auto Flash
Nov 21, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Automatic flash problems
I have the same problem as Irichard, in that the flash won't pop up automatically, the camera wont work when you pop it up manually all all modes that allow flash photography do not work.
Nov 01, 2007 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Nikon coolpix 5700
The red dot beside SB means that the flash is not ready. If the flash does not pop-up, I would say something is jamming it -- and not allowing the flash to pop-up. If the flash does pop-up, but the red dot stays on, there is a problem with the flash. The simplest might be a battery that is almost dead. The flash has to "charge" before it will fire. I have to admit, you would notice this rather quickly as the camera would power down within a few shots -- even if the flash didn't fire.
Check the pop-up flash position and get back to me. I hope this helps! Please post rating, if it does.
Regards,
Char1ieJ
Sep 16, 2007 | Nikon Coolpix 5700 Digital Camera
No flash popup on my rebel XTI
May 14, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon PowerShot S1 IS Digital Camera Logo
65 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
