Pixma MP520 repeatedly indicates paper jam. First, there is no paper jam anywhere on machine. Second, after all paper is removed from input and out put tray error message will not reset.
  • 5 more comments
  • solarricht Sep 15, 2008
    Yeah, so my cannon mp520 is also saying its jammed over and over, when there's no Jam too. What am I going to do?
  • Freeji Nov 24, 2008
    Yup me to, i have a paperjam error but there is no paper jam at all. The error still keeps coming after a reset
  • alort Nov 26, 2008
    My mp520 does the same thing, resetting does not work.
  • gustin85 Dec 10, 2008
    Same thing, someone please help me
  • Anonymous Dec 28, 2008
    I have the same problem on my MP810
  • timdietz Feb 27, 2009
    This printer keeps telling me there's a paper jam in the output slot. I have tried to search for that bit of paper numerous times, but it was never there. The Canon is out of order as long as the error keeps popping up. Sucks big time...
  • astabjorg Mar 21, 2009
    The same problem here, always saying a paperjam at the output tray even though it is nothing there.
mickblu
  • 12 Answers
SOURCE: Clear Paper Jam error -- but there is no paper jam!
Sometimes while clearing the jam (if there was one) you may leave a bit of paper left behind which obscures a sensor causing it to think there is paper still in the paper path, or sometimes even paper dust can do it. Try a bottle of compressed air and blow the path out very well. Get a bright light (good flashlight) and very throroughly eyeball the paper path for any "foreign" objects...
Posted on May 31, 2007
I have the same problem. Answer? PUt the piece of junk in the trash and never, never buy brother products again. I called Brother and they had a refurb for more than what it cost me originally!!!!!
Posted on Sep 09, 2008
manojro
  • 495 Answers
SOURCE: error 5c00
check in inside the fusing unit by the roller.
Posted on May 12, 2009
samadhan_law
  • 54 Answers
SOURCE: canon pixma MP620 paper jam
i think u r roller of the pixma is getting hard so loose it means scroll it by u r hands for one or two times and then try
Posted on Jul 25, 2009
  • 117 Answers
SOURCE: canon pixma ip1980 service error 6000.. it flashes
your canon pixma paper jam open the printer caling
Posted on Oct 07, 2009
Paper is jammed
Only 2 things can be done. Switch it on or off repeatedly, the paper will automatically come out. Second, disassemble it and take out the papers.
Audi Headlights
Aug 27, 2012 | Canon PIXMA MG2120 Photo All-in-One Inkjet...
The printer is not printing receipts and the error indicator is blinking on and off, what is the solution to this?
Flashing (approx. once every second): Out of paper
Flashing (approx. twice every second): Mechanical error (Buzzer sounds once.)
Most likely your paper feed is giving you the error. Remove the current feed, ensure there are no paper jam & insert fresh paper.
If
Mechanical Error :: Quick blinking Buzzer Sounds continuously for a pprox. 1 second :: Reset the Power
switch
Paper End Blinks.:: Buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Paper Near End Blinks.(Once a second) :: buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Mechanical Error : If the printer mechanism has a greater load due to a paper jam, etc., the buzzer will sound and the SEL/ERROR lamp will blink to stop the printer mechanism.
Paper End : If the printer has run out of paper, the paper sensor in the paper path near the print head will detect the end of the paper roll, turn on the buzzer, and blink the SEL/ERROR lamp to stop the printer mechanism. If the paper is inserted into the paper path, the paper will be loaded.
Paper Near End : If the paper is running out, the paper near end sensor will be activated to turn on
the buzzer and make the SEL/ERROR lamp blink. Even after the paper near end is detected, a command can be used to print by the specified number of lines. (See a description on the command for setting the number of print lines after paper near end detection)
Finally
Backup Data Clear : When the power is turned on, depending on the SEL switch operation, the
backup data in the input buffer will be cleared according to the flowchart on the next page.
To clear the input buffer, turn on the power while pressing the SEL switch.
The following messages will be printed.
"Clear Data in Buffer"
"Cleared Data in Buffer"
To print the data in the input buffer, simply turn the power on.
The following message is printed and the data in the input buffer is printed.
"Power Down(Data in Buffer)
Dec 13, 2010 | Citizen iDP-3550 Matrix Printer
Paper jammed under roller small piece of paper keep saying jam e3
Good day, I will give you the procedure how to clean the roller or canon pixma mp160.
Procedure:
1. Press [On/Off] to turn on the machine, then remove any paper from the auto sheet feeder.
2. press [maintenance] repeatedly until <b> appears.
3. press [black] or [color].
4. repeat steps 2 to 3 twice.
5. open the paper output tray.
6. load 3 or more A4 or letter-sized paper in the auto sheet feeder.
7. repeat steps 2 to 3 times.
the sheet paper is automatically fed in and then out of the machine.
have a nice day.
Aug 01, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Error message 5100 problem with printer mechanism
SOME SMALL PARTICLES ARE THERE. CAREFULLY OPEN IT REMOVE IT
Apr 05, 2010 | Canon PIXMA MP520 InkJet Printer
It says "Check printer" error message "6A00".
paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 11, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Canon mp520 printer says paper jam but there is no paper there
open the back rear of printer and close it again. check for debris.
Feb 07, 2010 | Office Equipment & Supplies
NO I have the same problem as listed here "the canon pixma MP520. It says there's a paper jam but I can't clear it and the paper wonlt go through. I've got a horrible feeling something fell in and got...
You can try putting and index card or something stiff like that back thru the paper path to push back whatever is stuck. Look real close with your torch thru the spaces in the white guides that are over the long gray platen roller. Also the gray roller could have scratch marks in the area where the object is jammed. Be careful not to push back the sensor lever that is on the right side behind the white guides.
Feb 01, 2010 | Canon PIXMA MP520 InkJet Printer
Printer indicates paper jam every few pages, but there is no paper anywhere in the paper path. If I open the top cover and close it, it will print a few more pages, then indicate another paper jam
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 08, 2009 | Xerox Phaser 6180N Laser Printer
LCD Error message: Paper output slot. Thye paper is jammed. clear the paper and press OK.
A jam sensor may be stuck or have something stuck on it, causing the machine to think it is jammed. These sensors are normally located where the paper feeds into the printer, and where the paper exits the printer. Try forcing a sheet of paper through the machine in the direction paper normally. feeds. This may free up the jam sensors.
Jul 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
452 people viewed this question
jasbo
jasbo
