When I try to dub a ttile from hard drive to DVD the machine tells me the disc is dirty, yet I have tried several brand new discs and get the same message. The machine formats the DVD with no problems
Check whether the discs you are using are compatible with the machine. I've just had the same problem using 8x DVD+R DL (Double Layer) discs, and after checking the users manual found that the machine only supports 2.4x DVD+R DL. I am now trying to find out if there is some sort of firmware upgrade available.
After formatting the RDR-HX710 says 'Disc is dirty' and don't wanna copy. Brand new discs of several...
(More)
After formatting the RDR-HX710 says 'Disc is dirty' and don't wanna copy. Brand new discs of several brands gave the same problem. Yet I don't have a solution.
I can connect my Sony KDL40V4000 tv to my Sony RDR HX710 DVD recorder using scart lead and scart...
(More)
I can connect my Sony KDL40V4000 tv to my Sony RDR HX710 DVD recorder using scart lead and scart socket to record Analogue TV. (Line 1 ON RECORDER) If I change scart sockets on the TV from scart one to scart two, the connection becomes "smartlink" but when I try ro record from Line 1 on the tv, the pictire is blank.
Any suggestions?
My Sony RDR-HX710 don't recognise DVD-RW formatted with Nero. I can use them on the PC but not with...
(More)
My Sony RDR-HX710 don't recognise DVD-RW formatted with Nero. I can use them on the PC but not with the Sony recorder that don't recognise them and so I can' format them. What must I do? I use mainly verbatim 4x DVD+RW but happens the same with all other brands... Carlos jcmat@aeiou.pt
