Question about Qualstar (3414S) Tape Drive
Load fault 35 FWD or REAR tips are not working
Can you give us more details?
Posted on Oct 23, 2006
Have a kenmore elite washer f35 fault code help!!!!!!!
this is to do with a pressure switch ..take the pipe of and blow in to it ..then blow into the switch..put together..and put on rinse a few times...ifstill the same change the pressure switch
Mar 18, 2014 | Kenmore HE2 Plus Front Load Washer
VCR not working--initially accepts a tape--can hear it set up to head but releases after a few seconds. No fast fwd, no rewind.
This canbe due to many faults and need a full check up but I can fill up with few tips.
1. if the cassette loads and the take up spool does not turn then the machine will shut and rewind.
2. If the take up spool rotates but then it shuts down then the reel sensor at the bottom of the forward wheel can be faulty- there are opto devices or proximity sensors/magnetic type.
3. If the drum does not rotate it will shut down as well a fault in the SERVO section.
4. Defective HALL IC can shut the switching and so the servo will shut down the processor.
5. fault in the power section to deliver the correct voltage to the circuits/loading servo to take up.
6. Finally if the loading is not to the MODE swittch point or failure of mode can make the loading to trip back to rest.
Hope you are able to check these tips.
Jul 20, 2011 | Sansui VRDVD4000 DVD Player/VCR
Is a 98 cadillac deville front wheel or rear wheel drive
fwd i believe have worked on one in awhile but 98 99 were both fwd if i remember correctly
Jul 10, 2010 | 1998 Cadillac DeVille
I have just aquired a 1998 xj8 but when the car is parked up an intermittant fault occurs where as the rear wheels lock solid in both fwd and reverse,is this the handbrake mechanism at fault?
are you using the handbrake ?? ,if so try it without it ,have a funny feeling that this is a auto box problem and lock pawl for park isnt releasing
Mar 17, 2010 | 2004 Jaguar XJR-Series
Check abs system lite on how do you find the code list
ABS Fault Code List 1991 Corvette (C4)
Code Definition
21 Right Front Wheel Speed Sensor Fault
22 Right Front Toothed Wheel Frequency Error
25 Left Front Wheel Speed Sensor Fault
26 Left Front Toothed Wheel Frequency Error
31 Right Rear Wheel Speed Sensor Fault
32 Right Rear Toothed Wheel Frequency Error
35 Left Rear Wheel Speed Sensor Fault
36 Left Rear Toothed Wheel Frequency Error
41 Right Front Solenoid Valve Fault
45 Left Front Solenoid Valve Fault
55 Rear Wheels Solenoid Valve Fault
61 Pump Motor or Motor Relay Fault
63 Solenoid Valve Relay Fault
71 Electronic Brake Control Module Fault
72 Serial Data Line Fault
75 Lateral Accelerometer Fault (Short ot Open)
76 Lateral Accelerometer Fault (Signal out of Range)
Mar 12, 2010 | 1991 Chevrolet Corvette
Lost rear traction on 03 Impreza AWD
I have the same car. Mine is automatic. What is yours?
Possible scenarios:
1/ Is the FWD on the dash panel lit up? This will tell you that only the front wheels are engaged without power to the rear wheels. The manual tells you if you have a flat tire in your car, you have to make it into a FWD by inserting a fuse in your fuse box. Check and see if the circuitry isn't shorting out your awd which is making it fwd.
2/ Because the car has open diffs in the front and rear axles, you (or your friend) might see only the front wheels spinning and not the rear wheels. The power is transfered to the wheel with lowest resistance. With the front wheel spinning, one of the rear wheel(s) should also spin. Might not be a solution but maybe you can't see the rear spinning wheel because it's spinning on the other side.
Nov 30, 2008 | 2003 Subaru Impreza
Grinding
try putting oil in ur rear axle
Dec 02, 2017 | 1991 Audi 90
Sony FWD-42PV1 Board Y-SUS 6871 QYH O50C
Hi there I got a YSUS ZSUS Control board kit off ebay. It is supposed to fix the problem. $35 from ebay and $230 from Sony. Lets hope it works
Apr 01, 2008 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
Qualstar (3414S) Tape Drive Logo
62 people viewed this question
Top Qualstar Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Qualstar Computer and Internet Expert? Answer questions, earn points and help others
