Question about Kenmore Dryers
Kenmore dryer drum
Hello, I have a kenmore 6281100 dryer. I washed a heavy load of towels and know it sounds like the drum may have come loose. How can I get to the drum? I took the top off and the back off but I think the belts may be on the bottom? Please help me.
Alice
Thanks Fixya,
After reading many of the posted messages eventhough I didn't see my model, I decided that since it's not working, what harm can I do? So I took the front off as described in someone else solution and it worked for me. It wasn't the drum, it was a piece of plastic that broke loose from somewhere :) Guess it didn't need it cause it works just fine.
Thanks and keep up the good work.
Alice
Posted on Sep 06, 2008
Why does my Kenmore front loading dryer which is only a year old shreds our clothes!
call sears and gripe about it seems I read about one that the fins were loose and they had to replace the outer drum the wet clothes put too much pressure on them and they flexed
Mar 09, 2015 | Kenmore Dryers
Heavy duty super capacity plus
You dont. If it is making noise drum bearings or idler needs replaced
Nov 03, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series Mod:110.23832100 top load that with heavy clothes (towells robes) won't drain and leaves excessive water after spin cycle. Everything appears to function otherwise, no odd noises. No...
When you are putting the heavy clothes (towels robes) the sleeves of the towels will come out easily and get stuck in between the drain out valve so it will not sent the water out properly please avoid heavy clothes(towels robes) try to give a normal load
Dec 23, 2009 | Kenmore 15864/15862 Top Load Washer
Our Kenmore front load washer 41741042000 was getting noisier and noisier doing the spin cycle. Then I heard a loud sound- almost like a bump or snap- while the machine was in cycle. I stopped it and now...
The struts usually only break if the loads are too heavy or unbalanced. So try doing slightly lighter loads in future. Try weighing you dry laundry just so that you can see how much the machine will really take. You may be surprised. You might also find a loose spring or two as well. So if they are disconnected just connect them back up. Also with wet washing, especially towels and blankets, they tend to clump together in the drum and force the drum off balance and at high speeds this puts extreme stress on the unit and hence maybe why you have a broken strut.
Oct 30, 2009 | Kenmore 43142 Front Load Washer
Drum seems to be loose. Metal to metal sound each time it rotates
the rear bearing is bad and maybe also the glides on the felt need to be replace they sell it as a kit
Aug 22, 2009 | Kenmore 98702 Stacked Washer/Dryer
Wet towels & blankets stacked on working dryer
This won't affect drying time unless the load is so heavy it causes the cabinet to warp and disturb the door seal. If you haven't had any problem with this so far you can probably keep doing it. (The machine is designed to support the weight of a wet load in the drum, and should have some safety margin. But why not invest in a roll-around laundry cart like you find at laundromats and keep the wet load there until the dryer is clear?) You might need to be more concerned about rust starting on the top of the cabinet if the enamel is scratched, since it's not usually subjected to wet loads being piled there. You should also check your vent pipe frequently to make sure it stays clear with all the drying you do. Clogged lint screens and vent pipes will definitely lengthen drying time.
Feb 18, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Wont always spin with a medium to heavy load
seams like you need to check your belt
copy n paste this ;
http://www.youtube.com/watch?v=6XIsK3W_Qcg&NR=1
"Was this helpful?"
Jan 16, 2009 | Kenmore 22622 Top Load Washer
Kenmore Dryer Drum is very loose and noisy.
It sounds like one of the rollers has a bad bearing. You will need to take the front off the dryer, unhook the belt, and remove the drum to check the rollers.
Nov 20, 2008 | AEG T57800 Electric Dryer
Washing machine
check to make sure the machine is properly balanced. an off balance machine will vibrate causing that sound.
Aug 16, 2007 | Kenmore 9387x Top Load Stacked Washer /...
Dryers Logo
78 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
