Samsung HDTV HPS5053 - Picture snow?
My TV has a strange problem where pixels will lose sync and not update anymore. It starts off slow and after a few minutes you can barly see the picture behind the mis behaving pixels.
Happens with all video inputs HDMI, DVD, etc.... and also with the TV's own menus.
What could possibly be going on?????
  • 1 more comment
  • treehead Sep 06, 2008
    I'll have to look into it - the TV is 1 month out of warrenty.If I opened the TV up, would this be a simple adjustment to make and what would the optimal voltage be?
  • Anonymous Mar 07, 2009
    Out of warranty, any chance of know what board or parts are meesed up?
  • Anonymous Mar 19, 2014
    I use Virgin cable and this past few weeks the TV (LG) picture keeps breaking up into Pixels its ok for a few minutes then it breaks up again. I have checked scarts etc and they seem to be as they should be
  • 21 Answers
Sounds like a diffusion problem, if the tv is still inwarranty call 1-800-SAMSUNG, it needs a voltage adjustment
Posted on Sep 06, 2008
Model LNT4061FX/XAA Intermittent snow then picture. Is there a cure?
Intermitant snow means your tv is not getting signal continuously. Please check the input signal connection and source to your tv.
Dec 26, 2013 | Samsung LN-S4041D 40 in. LCD HDTV
My Sam sung TV has a pixel problem how do I fix it? What do I need?
Pixel problem? do you mean one pixel does not display or the picture is poixelated. like they do when TV stations blank out a face for privacy?
Sep 25, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung LN-S3241D HDTV LCD snowy display
The main board may cause this problem. If it wass happened when you play DVD, so the main board needs replacing.
Aug 16, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Bottom half of picture cuts out?
This is most likely a "cold" solder joint on one of the components, i.e. capacitor, inductor, ect. If you are handy with a solderiing iron and disassembly and more important reassembly, then you could reflow the cold joints. I hope this helps. Good luck :)
Jun 16, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
What can I do to fix the flipping of the screen from snow to prog
the tuner is getting a weak signal and that is why the vertical sync signal is weak and the picture is rolling .check the cable on the back
May 23, 2009 | Samsung Televison & Video
P50 VIZIO WHEN ON HDTV I GET SNOW
it's probably the Time Warner cable box that have issue and not the TV. Try using a DVD player and test the same input, it should work fine.
Nov 15, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Samsung HPS5053 Plasma TV
It may due to the Logic board, or Logic Scan board, or the Panel failure.
Apr 19, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Sharp 36K-S400
Check the tuner input mode it has (air, cable,hrc,irc) with new stations updating to HDTV the demodulation at the tv sometimes looses the color burst sync. I have seen this with more and more tv's with pip tuners , it resets to the default of air ( rabbit ears ) at 75ohms and the low band snow, when you go to the high band (56+) it finds the color sync and resets the vestigial sideband offset, it happens more often if the SAP or CC is also trying to aquire the proper offset. good luck.
Nov 17, 2007 | Sharp 36K-S400 36" TV
Only snow dots on the screen no picture
Does on screen display come up when you hit the menu button?
Oct 12, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Televison & Video Logo
287 people viewed this question
Top Televison & Video Experts
