Question about Kenmore 74292 / 74294 / 74299 Top Freezer Refrigerator
Kenmore 74292 How do I locate and change the water filter for the interior filtered water dispenser.
  • 62 Answers
The water filter, according to the model number shown for which you listed this request, is located at the botton of your ref. Open the door and look in the grill area about the center, you will see a opening of a round whole. Twist the cap to the left 90 degrees and pull out. make sure when the filter goes back in that you dispense about a picture of water so that the air in the line is removed or you will have a run on of water untill all the air is out.
Posted on Sep 06, 2008
Water dispenser not working on Kenmore refrigerator
Is it making any noise when you press the flapper if no then change water inlet valve
Dec 17, 2014 | Kenmore Side by Side Refrigerator
Where is the water filter on kenmore coldspot 106.9505712
On the front bottom of your unit you have a grill. On the grill there is a round knob. Turn the knob 1/4 turn counter clockwise and pull the filter out. Note the slot on the back of the knob that holds the old filter. Slide the old filter out of the slot and replace with the new filter.
Reinsert the filter with the knob into the filter housing. Turn the knob 1/4 turn clockwise to lock it in.
Now, the new filter has air in it. At your water dispenser, fill cups with water. There will be a lot of air and water coming out. Continue this until all of the air is out of the filter and there is just water fill.
When to change your water filter - Your unit has a water filter change light. This light is not tied into water pressure. It is like a egg timer. Every 6 months it will light. This does not mean you need to change your water filter. Change your water filter when your ice cubes start to get small or the water coming out of your dispenser is of a low flow. Depending on your family size, you may not need to change your water filter for several years.
My name is Peter. I am a retired Sears Home Services refrigeration technician.
Oct 24, 2014 | Kenmore Refrigerators
How and where do you change water filter
From the KitchenAid Manual:
The water filter is located in the upper right-hand corner of the
refrigerator compartment.
Replacing the Water Filter
To purchase a replacement water filter, model 67003523 Part
Number 4396395, contact your dealer or call 1-800-442-9991
U.S.A. or 1-800-807-6777 Canada.
IMPORTANT: Air trapped in the water system may cause water
and filter to eject. Always dispense water for at least 2 minutes
before removing the filter or blue bypass cap.
1. Turn filter counterclockwise to remove.
2. Remove sealing label from replacement filter and insert the
filter end into the filter head.
3. Turn the filter clockwise until it stops. Snap the filter cover
4. Flush the water system. Depending on your model, see
"Water Dispenser" or "Water and Ice Dispensers."
NOTE: The dispenser feature may be used without a water filter
installed. Your water will not be filtered. If this option is chosen,
replace the filter with the blue bypass cap.
May 16, 2014 | KitchenAid KFCS22EVMS French Door Bottom...
Changed my water filter on my Kenmore refrigerator. Now the water dispenser keeps dripping? The water filter is located at the bottom of the frig.
You have air in the line from the new filter . Run about 1-2 quarts of water thru the dispensor to remove the air in the line .
Jun 13, 2010 | Kenmore 57029 Side by Side Refrigerator
HI. When a filter has reached its filtering limit, it must be replaced. Once the filter has reached its filtering limits, it will not allow for proper water flow. This will affect the operating status of the dispenser. With that being said, there are other issues that will affect the dispensers abilities as well. These issues are a faulty water inlet valve assembly, and frozen inlet lines. If you are having issues with the dispenser, make sure you inspect these areas as well. Your filter should have an installation date on the label. check to see that it is not over a year old. if so, it should be replaced.
The filter is located behind the front lower grille work. The grille should have a cut out space for it to slide into.
Nov 12, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water dispenser dispenses particles into the water. Drained about 7 pitchers of water. Particles are smaller but still coming. Restaurant water looks better than this. What's happening and what can I do?...
first; turn the water of to the machine next, remove the water line in front of the filter using a large bowl place the loose hose into the bowl and turn the water on for a minute turn the water off and, check the bowl for particles then reattach the filter and do the same thing on the other side of the refrigerator if this water is clean the interior refrigerator filter must be checked usually it is the carbon filter inside the refrigerator that is bad you can find the drawings location and, procedure for this part at:
Apr 25, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
New filter but water dispenser still not working
Check the water valve if its working most probably watewr line inbetween the water valve and the water dispencer is frozen. Un plug the refrigarator for four hours and try again.
Mar 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Can't identify "water filter indicator light"
the indicator light could be on the control panel inside the refr section if your controls are there, or it is most likely on the front of the dispenser panel. it only comes on when you draw water from the dispenser and thats when you will see it be green, filter ok, yellow, filter at 80% life, or red, time to replace the water filter.
also you dont need to shut off the water when changing the filter as it is made with a shut off device in the filter housing already and is automatic.
by the way filters are expensive, go online and check prices. google "water filters" and find a good price.
Dec 13, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite - Interior water dispenser stopped working
Frozen water tank, some of these had an insulation kit that will prevent this from happening. Make sure you have water coming out of valve to tank, if so it will probley be a frozen tank. Make sure fridge is on factory settings. If it doesnt thaw out, check into the frozen tank kit...
Jul 14, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Interior Water dispenser not working
if you have not yet used it you will need to bleed the air out of the tank in the refrigerator hold the button in for a few mins to flush this out
Jan 23, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 74292 / 74294 / 74299 Top Freezer Refrigerator Logo
57 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
