Question about Bissell Powersteamer 1694 Upright Vacuum
Is this free? i have a bissell carpet cleaner and i cannot get the soap and water to come out. it will **** up the dirty water however. i just found the belt is broken but i can see no way of how to put a new one in. is a broken belt the reason no soap is coming out?
    President:
  • 1,673 Answers
If it is the flat belt that broke, that is the pump belt, the pump can't work without it. To replace the belts, turn the unit over, remove the red holder, has one screw, pull it out, then the brush roll will come loose. You can replace the belts thru that opening.
Posted on Oct 03, 2008
My Bissell carpet shampooer will not dispense water or cleaning solution, nor is the "flow indicator" spinning
most of the Bissell carpet cleaners that have the water heating feature stop pumping water at one time or another. Make sure the belt is still on the pump and if it is then the problem is probably in the heater core in the handle. Hard water deposits plug the tiny little water ways inside the heater core. Pull the heater core and take it apart and clean it with a strong scrub brush and I think vinegar works for cleaning I was told. I just use soap and a brush. Then flush all your lines with hot water. The cause is from hard water deposits or leaving the soap in the cleaner after you use it. Both will stop it from pumping water
Apr 29, 2014 | Bissell 1698-1 PowerSteamer ProHeat Plus...
Water not getting to cleaner head when pushing down the pedal. Cant find any blockage, motor sounds ok
some times the tip /nasal git plugged from soap, it gets crystallized. can try running clean hot water in place of soap. Hope this helps please feel free to let us know if you would like more info. Thank you , Have a good day
Aug 02, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Does not spray cleaner
It helps to always run hot water in the soap holding tank after you have cleaned the carpet to make sure the soap does not dry inside and clog. Make sure that the dirty tank water filter is clear of debris, I have noticed that if it is clogged it won't spray out solution. Another thing to try is, it usually will always spray out of handheld cleaning attatchment. steve
Jun 06, 2010 | Bissell 1699 ProHeat Clear View Upright...
Bissell carpet cleaner not sucking up.
I have a Proheat 2X and had the same problem. I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying somethign else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 24, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
I have an older model Bissell rug shampoo machine, model # 1631. I have several bottles of Bissell 5 One carpet formula to use in this machine, however I have lost the measuring bottle that tells me the...
I have a older mod. Bissell carpet machine plus mod. 1630-5 and need a floor nozzle part num.013-6194 and grip tube w/button part num.014-4181 and trigger part num.010-9406 and tube
Mar 22, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Whare does the dirty water go in the bissel 12 amp pro heat carpet cleaner
the clean water goes into a "Bladder Bag" that is located inside the tank. The way it is designed to work, as the clean water dispenses from the bladder bag, the outer part around the bladder bag fills with the dirty water. It never touches the clean water. Seems wierd, but it works! I hope this helps, if it does, please give feedback, as it helps me to gain ratings. Thank you! Remember to have your cleaners serviced every year by a qualified tech! Rene (The Vacuum Doctor)
Nov 06, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell 9300 carpet cleaner
You put hot tap water (never boil water) into the clear bag through an opened hole in the canister. The dirty water will be correct outside of the bag. You remove the dirty water by open the valve at the bottom of the canister.
good luck
Sep 01, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Powersteamer 1694 Upright Vacuum Logo
189 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
