Admiral Wall mounted 14,500 btu air conidtioner safety circuit trip button keeps tripping. Unit is on its own 20 amp circuit
TJBENGR
  • 121 Answers
SOURCE: my ac circuit breaker keep tripping
If your outside condenser has a locked rotor or short circuit, than the unit WILL trip the breaker - as it should. On the other hand if a breaker is tripped a few times it will have less of a capacity that the rating, (this is designed in it). You will need to determine if the unit is locked (and broken) or the breaker has become too sensitive.
Posted on Apr 22, 2008
22yooper
  • 828 Answers
SOURCE: RV ROOF TOP AIR CONDITIONER TRIPS BREAKER
Possible low voltage condition would cause that kind of a problem. To small a cord without the ability to carry and maintain the voltage would cause a voltage drop. I would test the voltage supply and make sure it is within 10% of that required for your A/C to operate properly.
Posted on Jun 16, 2008
  • 143 Answers
SOURCE: My split system airconditioner made
Something has exploded. Look inside to see what it was.
Posted on Jul 24, 2008
localwonder
  • 6784 Answers
SOURCE: Circuit Interrupter trips.
there is some moisture that is leaking near the power supply board in this unit. its a internal leak of some sort. it will need service soon. The musty smell is a dead give away when concerning an internal leak.
Posted on Mar 10, 2009
  • 398 Answers
SOURCE: Can I mount a Samsung AC unit thru wall rather then window?
as long as the vents are completlyeyt covered. and cove rit in winter
Posted on Mar 18, 2009
Trips when plugged in
What trips? If you are referring to the circuit breaker then I suspect the breaker is not sufficient for the power the unit draws. Beware installing a higher amperage breaker. First be sure the wiring and all bomponents are adequate.
May 21, 2015 | GE Zoneline In Wall Ptac Unit Air...
Ac unit keeps tripping the reset button
Good Afternoon Friend,
I understand your Frigidaire air conditioner, model# LRA074AT7, which keeps tripping the reset button. I see that it will start up and then trips the reset button after a minute or two. First, be sure the electrical service is adequate for the model you have chosen. This information can be found on the serial plate, which is located on the side of the cabinet and behind the grille. Secondly, be sure the air conditioner is properly grounded. To minimize shock and fire hazards, proper grounding is important. The power cord is equipped with a three-prong grounding plug for protection against shock hazards. Lastly, your air conditioner must be used in a properly grounded wall receptacle. If the wall receptacle you intend to use is not adequately grounded or protected by a time delay fuse or circuit breaker, have a qualified electrician install the proper receptacle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 20, 2014 | Frigidaire 6500-BTU Window Room Air...
My braker keeps tripping with only the tv on and electronics that barely use a lot of juice. it doesn't seem like it pumping out enough cool air for 14,000 btu's either
14,000 btu is a very large unit it should be on a dedicated cuircut of either 15 or 20 amps all by itself.check the rating plate for correct amperage
Jul 21, 2011 | Soleus LX-140 Portable Air Conditioner
A picture fell off the wall & hit the plugin, the unit went off. I tried the reset button but it still doesn't come back on. any ideas?
Check your circuit breaker. It may have tripped. It will be in the main circuit box, probably a 15 or 20 amp breaker.
Jun 26, 2011 | LG Electronic Window Air Conditioner
I just purchased a souleus 12000 btu portable air conditioner. The unit works fine but keeps tripping the circuit breaker in my apartment. What causes this and can it be fixed or is it just the wiring in...
First, you need to determine what, besides the Souleus, is on that electrical circuit, and whether the circuit is 15 or 20 amp.
12,000 BTU A/C's tend to pull 10-12 amps, and they can peak just under 15 when the compressor starts. So a new, right off the shelf unit will max out a 15amp circuit. An older model with a worn out starting cap will demand even more amps at compresser startup.
Aug 14, 2010 | GE APN08AA Portable Air Conditioner
34000 btu, outside condenser unit keeps tripping breaker. Unit was manufactured 02-20-2005
Hi, It is tripping the breaker because the compressor is locked up and will not start..
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 11, 2010 | Haier Heating & Cooling
5000 unit working great, moved and it wont come on, yep got power at plug in. just dead and tripping breaker.?
Probably the breaker is not big enaugh for that a/c unit ,read the tag it sohuld said what's the maximun circuit breaker for that unit ,usually with a 20 amp breaker works.
Aug 25, 2009 | Haier America Manual-Control Room Air...
Everstar portable ac 10000 btu
The everstar 10,000 BTU unit will require a dedicated 115 V 15 amp circuit. if there are other things pluged into outlets and running from the same breaker then the 15 amp breaker will trip. Or, these units also have a GFCI plug adapter. Be sure it has not been tripped due to an improperly grounded outlet, or wet location.
Aug 22, 2009 | Heating & Cooling
GFI on cord trips out.
Probable cause is a single pole gfi opposed to a double pole gfi.
* Do not use a single pole GFCI ON A MULTI WIRE CIRCUIT, IT WILL NUISANCE TRIP IMMEDIATELY
Use a two pole GFCI circuit breaker on such circuits.
May 20, 2009 | LG LWHD1800R Wall/Window Air Conditioner
Heating & Cooling Logo
104 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
