Question about Lands Phones
I need to punch down a 200 pair phone line to a 110 block. Whats is the color code for this?
  • Ronald Mueller
    Ronald Mueller May 11, 2010
    can you be a little more specific.
  • Lands Phones Master
  • 2,460 Answers
If you have to ask, you probably ought to be giving the job to someone else. It's the same color code as a 25-pair, there are just more binders.
Carl
Posted on Sep 06, 2008
  • Carl Navarro
    Carl Navarro Sep 06, 2008
    How about this one. The color code:
    Bell Operators Give Bad Service
    Why Run Backwards You Varmit (or You'll Vomit)
    That translates to Blue Orange Green Brown Slate and White Red Black Yellow Violet. If you look at a 25 pair cable, those are the 10 colors used. The first pair is White/Blue Second White Orange and so on. The 13th pair is Green for the number and Black for the count. Now, in a 200 pair cable the first 25 pair binder will be wrapped with a Blue/White trace, the second with an Orange/White trace...are you picking up a pattern here :-)
    There are 8 traces, so the last 25 pairs will have a Red/Green
    trace.
    The point of this is that if you've never done this before, you can really end up with quite a mess. Or you could pay someone a half-day's wages to terminate the 200 pair and put the clips on with the proper tools. Did I mention there's a multi-punch tool that puts the C clips on?
    The tool is about $100 most places and that would pay for the first 90 minutes or so of an installer's time.
    Carl
I recently switched to the comcast phone service from ATT. I have a structured wire set up. I also kept an ATT land line so I'd have a telco line in an emergency--like an earthquake. On every phone in the...
Assuming you have 2 line phones, what happens if you swap lines? If your structured wiring is the 568B standard, which is the most typical, the second line must be punched down to the white/green pair instead of the orange/white pair for 568A wiring. It sounds like the second line may be daisy chained in the panel so you have to see how it's wired and troubleshoot from there. Sometimes a pair is connected to a power supply to provide power for a phone or light but that's not typical any more. Sorry I can't be more specific but if you have more info or photos of the panel and jacks I'd be happy to help further.
Apr 26, 2010 | Lands Phones
It doesn't let me punch in the code of 0000. other phones are easier to pair.
Go to settings/ pair with phone/ other phones. it will then give you the code to use, then search for new paired device from your phone, when it finds parrot, click pair and enter code shown on parrot screen. Make sure you delete all other paired devices from parrot first. instructions can be found at parrot.com
Oct 30, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
How do I wire up a cat 5e socket to extend my network.
hi, good morning, i'm here to help, the modules should be color coded and the cat 5e will have the same colored wiring when you strip off the jacket, you should use a puch down tool, punch down the 5e wires into the corresponding colors of the module, strip a small portion of the 5e jacket but not the inner pairs of cable, untwist the inner cables and insert and punch down the pairs, the modules should come with some kind of instructions, please let me know if i can be of anymore help
Mar 19, 2009 | Computers & Internet
Adding new extension to Nortel Norstar Meridian Phone System
They should have terminated your voice on a block in your phone room. If that is the case you now need a punch down tool and a spool of cross connect wire. You would punch down one side of the cross connect wire on the tip and ring of the switch pairs and the other end of the cross connect wire on the blue pair of your station cable.
Jan 15, 2009 | Lands Phones
New phone wire from box to home need diagram to show how to
The phone company should make that connection. Use a phone jack assembly with alligator clips to find the dial tone. The first line color should be a pair, blue&blue-white, 2nd line, orange& orange-white, then green followed by brown pairs which would be 4 line numbers in that color code order. Each line is just a single pair. Thank you. Jer
Feb 25, 2008 | Lands Phones
Lands Phones Logo
79 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
