Doesn't make a good copy, all grey, not a clean copy
    New Friend:
  • 159 Answers
Change the drum unit
Posted on Sep 06, 2008
Hi my bizhub Di3510f copier is making copies and printing with like one vertical black thin line and like lighter grey lines all over the paper. The papers are eligible but it looks like the page is...
Sounds like your cleaning blade & drum. First try to clean the glass(small ruler size & large one) and if that doesn't work you will need to replace the drum & blade.
Sep 02, 2011 | Minolta Di3510f Bizhub Copier
When printing a text (black), i get horizontal bands of black and grey printing, abouth 2 lines black, 2 lines grey, ... to solve this, I must print in high quality, but that's time consuming and ink...
Clean the head where the ink comes out.
its tough, you can rub it good.
Then there are the electrical contacts.
Get a pencil eraser, and polish them up shiny.
on the cartridge too.
Make sure all ribbon cables are in tight.
Aug 30, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Xerox 4150 my paper is a light shade of grey, what can it be thank you
Giacomos,
Is the paper a shade of grey with no image? or is there an image with a grey background?
If there is a image with a grey background you should try a new toner module. If that doesn't resolve the issue, clean the xerographic drum, make 10 blank copies, if the cleaning doesn't resolve the issue than install a new xerographic module.
Hope this help.
Apr 05, 2011 | Xerox WorkCentre 4150 Black and White...
Copying from upper tray - line on the copy - good copy but has a solid thin line, about the size of the roller.. -- copying from glass is fine..--if it is the roller ! how do I clean upper roller and etc....
hello, you said this was a copy, have you tried making copy from the glass, and not thru the doc feed, just to see if the output us the same. if not, open up the doc feed area, and clean the **** glass. now if your prints from the computer are the same as the copies, then its possible that the problem is pressure rollers above the ashpalt grey platten roller. alittle harder to clean but can be cleaned off.
Oct 11, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Copies have a grey ink shade on them
Have you cleaned the optic's? How about has the drum & cleaning blade & developer been changed recently? If not I would start with that first. Good Luck
Sep 11, 2010 | Minolta EP1083 CS/PRO Copier
Bad copies/grey lines
hi do u have cleaned the scanner miror and the coppy glass may be coz of that u having that grey line
thanks
May 11, 2010 | Canon imageCLASS D761 Copier
Minolta ep 1080 copies have vertical grey stripes with a white halo around the text
You need a drum cleaning blade. This blade cleans the drum between copies.
You can verify this by opening the "clamshell" or lifting the top half of the machine like you do when removing a paper jam. Then look under the top half of the machine on the inside. You should see a reddish or greenish colored cylinder called the drum. It is about in the middle from right to left. If you see the same black bands on the surface of the drum as you do on your copy then the drum cleaning blade is bad.
This cylinder should normally be clean.
Good Luck.
Nov 18, 2009 | Office Equipment & Supplies
Printing illegible, very faint
I run "clean printhead" and that solves the problem when it happens to me.
Mar 26, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
On normal contract my copies are very dark.
The optical area of the copier need some cleaning. Consult a technician for support. This is a minor problem.
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
128 people viewed this question
jasbo
jasbo
