Question about Brother Office Equipment & Supplies
My brother fax personal 575 fax machine is making a line from top to bottom on my copies
  • Leroy Elliott
    Leroy Elliott May 11, 2010
    Lift the feeder cover and look for wite-out on the scanner glass.
  • 24 Answers
Press function * 2864 with in 2 seconds.............. then feed the white document and press 55............after feedout the paper press 99............. may ur problem solved
Posted on Sep 29, 2008
I need amanual for Brother Fax-575 Also does it
Yes, the Brother Fax-575 does have answering machine capabilities, in fact it recommends using an answering machine on a shared line. To download your User Guide, click on the link below. Best of luck and thank you for using Fixya!
Greg
Brother Fax-575 User Guide
Nov 12, 2009 | Brother FAX-575 Plain Paper Thermal
Brother fax 575. need oem manual
Look on pages 12-9 thru 12-11 in this link to Brother for your Fax 575 for ribbon / cartridge installation instructions.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_FAX_575_EN_75.PDF
Nov 11, 2009 | Office Equipment & Supplies
Comm error on a VOIP line
Fax cannot send on a VOIP line unless the VOIP line has T.38 fax protocol service.
Sep 25, 2009 | Brother FAX-575 Plain Paper Thermal
When I fax the recieptent is getting 2 big black lines..........ive tried cleaniung it but not sure if im cleaning the corredt parts..........there a little glass part that looks like there may be ink
Open the auto sheet feeder (where you place your originals), look underneath and you will see a narrow "scanner" glass that the originals are scanned across. Clean this thoroughly with glass cleaner (or water) - there is probably correction fluid or some other foreign dirt on it. If you make a copy for yourself (before and after) it gives a good indication of the quality you are sending to fax recipients.
good luck, and please rate solution
Apr 28, 2009 | Brother FAX-575 Plain Paper Thermal
Faxing on pulse line Brother Fax-575
HELLO! YOU WILL NEED TO GO INTO THE SET OF THE MACHINE, THERE IS SECTION THAT WILL ASK YOU PULSE OR TONE PUSH TONE THEN THE SET BUTTON GOOD LUCK
Feb 01, 2009 | Brother FAX-575 Plain Paper Thermal
Phone line ports
HELLO, THANKS FOR YOUR REPLAY TO MY BROTHER FAX -575 , WILL BUY NEW ONE.THIS ONE IS OUT OF WARRANTY.COST MORE TO FIX THAN TO BUY.....
Nov 04, 2008 | Brother FAX-575 Plain Paper Thermal
I have problem with a quality of fax
Make a COPY and see how the copy comes out. If you see the same black vertical lines that other people are seeing, then you probably have something like whiteout on the scan glass.
Open the fax top cover where you feed your originals, and then look inside for a piece of glass about 10" long by 1/2" wide. Then I would try cleaning the glass with rubbing alcohol and also go over it again with windex.
After cleaning the glass, try making another copy to see if it has improved. If it has, but still has more lines, then try re cleaning the glass.
Hope this helps.
Good luck.
Mac
Mar 08, 2008 | Brother FAX-575 Plain Paper Thermal
35 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
