Question about Proscan 19LA25Q 19 in. LCD Television
Hi blue eyes, whichone worked finally??
Which one (remote) finally worked weird but worked some???
at least i can get that one, i only need volume and channesl, the rest i can do direct on the set, thanksssss
    New Friend:
  • 42 Answers
One for all and radio shack remotes do not have a device code for this tv. Your best bet is remotes.com.
Posted on Oct 11, 2008
Screen remains locked on Blue background welcome screen when it finally comes up. Status light remains blinking green. Over the past 7-10 days it took several tries powering on then off before picture...
Tv manual PCB control buttons all work?Like power on/off,volume - + and chanels + - all work than it not the manual PCB board control IR is parts of this board.Not the IR problems,when tv is finally on the remote work fully everything buttons?No,could be remote control have problems.Tv might have DM power supply board problems.
Feb 08, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
Went blank sound and picture went off will not turn off with remote or tv button. I have to unplug it to turn it off. when i first turned it back on it was just blue screen now still having to unplug it...
Most LCD tv's having a lot of bad caps in the power supply ,that makes for really weird things happen, since they work like a computer during boot. For that 2-3 second "boot" the processor in the set checks for a combination of things and if those caps go bad in the supply the set will show a wide variety of symptoms.
Usually the set won't start for a minute or two and sometimes longer, after that comes some weird things like lines and what not and the set finally just won't come on period.
I could write a book about how simple fix like changing a few caps causes all kinds of phenomena..lol
Apr 08, 2010 | Vizio VW42LF 42 in. LCD HDTV
While watching TV the volume will suddenly mute.
Hi. Were you able to get this remote working again? I am going to suggest you try a firmware update, since you didnt mention that you had tried that. I find that usually solves weird problems like this one. You can do that by going through the following steps:
1. Connect your remote to the computer.
2. Launch the Harmony Remote Software, and log in.
3. Click "Downloads" at the top and click "Firmware"
4. The remote will go through the firmware update.
5. Select "Yes", and click NEXT to update the remote.
Voila! Hope this can help.
Dec 29, 2009 | Logitech Harmony One LCD Touchscreen...
Volume changes when other buttons are pressed. Randomly the remote drastically changes the volume on the receiver when you press another button.
Hi. Were you able to get this remote working ? I suggest you try a firmware update, since you didnt mention that you had tried that. I find that usually solves weird problems like this one. You can do that by going through the following steps:
Hope that helps :)
Dec 18, 2009 | Logitech Harmony 550 Remote Control
Bravia KDL40W2000 Remote and manual controls no longer work
check to be sure your remote is sending IR signal, with
a smart phone camera hold remote IR eye in front of camera and click any buttons on remote, you should see
a light coming from IR eye. If no light emitting, remote needs to be replaced.
Oct 29, 2017 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My pioneer deh-p5500mp Car Radio
hmm.. thats a nice radio, not too shaby heheh...
Well your car radio should have a Blue wire with a white stripe for the remote, in case you are interested in the user manual (wich im guessing you dont have)
Go to:
http://www.nodevice.com/user_manual/pioneer/car_audio/deh-p5500mp.html
it has a diagram of the harness and it shows a blue/white remote wire, so im guessing that you bought it used and probably got a different harness with your car radio... but then again thats too weird
you could do a check to see if thats really the problem... just feed 12V From the power terminal of your amp to the remote terminal, that should turn your amp on and you should be able to listen to your car radio's output (id suggest not setting the volume all the way up when doing this XD)
Hope it helps
Jun 23, 2009 | Pioneer DEH-P5500MP CD Player
Optical eye
LOL, optical eye? OK, that’s the problem, there is no such part. However, you did not say if any other buttons were working on your remote, ie ch up and down, input, power on and off, ect. If so, it will not be your remote. If you the volume is not working, check you menu setup, under the audio setup.
If no remote functions are work, you can try the inferred Receiver. Its only about 20.00 to replace and can be found at most part stores. Cheaper if you change only the IR block itself.
TV tech
Jul 24, 2008 | Zenith E44W46LCD 44" Rear Projection...
Advent tv/dvd 27 inch flat screen. Weird Cable and power and volume problem
I have read that if you unplug the unit for more than about 4 hours, it will reset to the factory settings, and that wont be a problem.
this is at:
http://www.remotecentral.com/cgi-bin/mboard/rc-remote/thread.cgi?7770,1
I quote one guys fix below:
JazzyDaveNew Member Joined: November 2008 Posts: 1 View Profile
The factury remote that came with my 20" Advent lost many of it's functions. I recently purchased the Phillips Remote SRU4105WM/17 and it works perfectly with the Advent as well as my other equioment. Buy has it fo $8: http://www.buy.com/retail/product.asp?sku=208673201
Jul 02, 2008 | Recoton Advent Advent DV1418A 14 in....
Blue screen
Hi..there,
Well, your screen changed colors....due to defective AD board. Need to replaced a new AD board.
Apr 28, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Tv not responding to remote and now will not turn back on!
if the remote eye on the tv it will do all kinds of strange stuff once the eye on tv gets dirty the the tv will shut off after 2 seconds try cleaning it and see what happens the eye on tv is hard toget to so get a can of air to blow it out i took my pocket knife to clean mine i know that was ruff on eye but thats all i had if this dont work try unpluging your control board on front of set board may be bad or buttons are stuck email me at rjp5765@msn.com if this helps
Nov 01, 2007 | Mitsubishi WS-55613 55" Rear Projection...
Proscan 19LA25Q 19 in. LCD Television Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
