Question about Dell Photo 964 All-In-One InkJet Printer
Printer makes clickn sound
Benimur ,
when I turn on my printer , It makes a clicking sound...
I used to be able to pint any way but now nothing
thnks Wolfman
  • Start
  • type paint
  • Select file
  • from camera or scanner
  • select how you want to scan
  • DONE!
Posted on Sep 06, 2008
  • mball2400 Sep 06, 2008
    This is for the question about being able to scan and it just sitting there. Sorry seldom.
Printer will not print. Only "printer not responding " No error code. I have rebooted and still nothing. Any help you could provide would be appreciated.
Please make sure you are selecting the correct printer. Sometimes you may have two of the same printers installed on your computer. Turn printer on, connect to computer, and go to our "devices" folder to see which one it is. You may be sending pint jobs to wrong printer.
Jun 05, 2017 | Office Equipment & Supplies
Dragon NaturallySpeaking 9 preferred will not work, Microsoft Excel
i do not understand your problem, can you please reexplain
Nov 29, 2007 | Computers & Internet
I changed myfront brakes n my 1997chevy tahoe,but nw is making a clickn sound on my left drum
I'm guessing you would have disk brakes on the front of a 97 Tahoe not drum brakes right? It could be as simple as you put the break pad clips in backwards and they are making contact to the rotor plate. Check all the clips and make sure your caliper bolts are very tight.
Apr 15, 2015 | Cars & Trucks
My car was stuck in mud a 1999 buick regal when i
replace your cv axel more then likely when you got it stuck you ripped the rubber boot that hold all the ball bearings into place and that's what caused the bearings to fall out so now when you put it into gear you have the inter shaft turning but nothing to help turn the outer shaft
Sep 25, 2014 | 1999 Buick Regal
Wont turnon making clickn sound
i guess people are starting to realize that all this new tvs are garbage i am a tech for more than 25 years i have not seen so many new sets in the repair shop like in the last couple of years , my friend your problem is the power supply, please post the make and the model number to tell you exactly what to do
good luck with this raw technology
Jul 18, 2009 | Samsung Televison & Video
Mazda RX8 starting problem
Check that your battery is fully charged. If it does not sustain a charge , replace it. Clean the cables and battery posts with baking soda and water mixture. About 1/4 cup to a pint. If it still does not turn with a fully chared battery, it is probably the starter that is bad. It will have to be replaced. One click usually means the starter is bad. Several clicks usually means the battery is bad.
Feb 20, 2009 | 2005 Mazda RX-8
Printer sharing problems
Can you see the printer from the networked computer? Have you gone into the printer properties and set it to share? Right click on the printer in printers and faxes and select properties. Click on the sharing tab and clickn on the circle next to share this printer. (Windows xp)
Jan 12, 2009 | Lexmark Computers & Internet
Configuration of DP300u in a LAN over Windows 2000
You just need to installe the . Inset the Printer Driver CD. It will Autoplay. Click on install the Driver.
After successfully installation of Driver, Go to Start-->Setting--> Printers and Faxes
You can find your printer here.Right Click on Printer --> Click on Sharing --> Give the Printer Name in Share Name.
You can installe the printer on client Machine by following way:
Go to Start-->Setting--> Printers and Faxes--> Click on Add Printer --> Check mark on Network Printer-->Clickn on Browse printer. It will Automatically discover your printer. Just Right click on it and clickon connect.
Sep 13, 2008 | D-Link DP 300U (DP-300U) Print Server
When i try to start my computer it gives me the option to repair or start windows normally....when i try to repair it gives me this error code: 0xc00000e9..... and then when i try to start normally it...
where is asking for start normally look for another option called last known good configuration select it and see.
if he does not work insert your window cd into drive it will tell you press any key to boot from cd rom you press then it will get to a sgtage it will ask you press r to repair or press enter to continue you press r it will take you to dos environment type chkdsk it will scan and recover all lost data then type exit to restart then it wil work
May 31, 2008 | Toshiba Computers & Internet
Cannot delete previous printer from PC
make sure there is no pending document in the printer, go to printers and faxes and right click on the icon that you want to delete, click on cancel all documents on the drop down menu and then if you see use printer online click on that as well, if that doesnt help. Click on start, then click on run, on the open box type in services.msc then on the window that will pop up look for printer spooler, right click on it click on stop, then right click back then click on start. then close out of everything and restart computer.
Pls dont forget to rate as Fixya, thnks!!!
Apr 17, 2008 | Lexmark Z715 InkJet Printer
Dell Photo 964 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
