Question about Hoover S3639 WindTunnel Bagged Canister Vacuum
Hoover S3639 Suction Failure/Turns itself off and restarts later
After a hard workout (ranch house with dog cleanup) the machine has turned itself off only to restart again after it has cooled down.  The bag full indicator does not work so bag is not usually changed in a timely manner.   The motor runs now, but suction is so weak there is no pickup function.
Machine was dismantled and cleaned out.  Filters were cleaned and  reinserted.  After reassembly the motor runs energetically but suction is still weak.  Exhaust exits through the top (at lid closure) and side vent. There is no blockage in the hose.  I removed the motor and used a shop vac at the front to remove any debris but did not open it up.
I once solved this problem by cleaning the filters but this time there was no success with this procedure.
Can this vacuum ever work again?
  • liz317 Sep 06, 2008
    Thanks.  I suspected as much but glad to have this theory verified by an expert.
    Next question:  are motors with more longevity available for the Hoover S3639
    and, if so, where can I find one?  I have owned this machine for approximately three years and bought a Hoover again after the previous Hoover canister model I had
    wore out after FIFTY years!  (It was a wedding gift from my parents who paid $50
    for it.)   I would like to repair the machine if practical to do so.
    Sergeant:
  • 264 Answers
If the Motor is not providing enough power it could be an issue with the motor winding. I think you should take it to a repair shop
Posted on Sep 06, 2008
  • Hoover Master
  • 19,396 Answers
If you did all this already the motor is not having power, must be replaced.
I installed the Hoover Wind Tunnel Central Vac in my new home. After connecting the wall outlets and successfully turning on the system from the hose control, I discovered there is lots of air flow t
I would recommend checking your wall outlets where the hose plugs in for any type of clog in the tubing. If the vacuum itself has great suction but when you go to the wall outlets that is probably something in the hose that is stuck. If cleared it will most likely have excellent suction throughout the entire system in the house.
Jul 21, 2012 | Vacuums
Repair manual for Hoover Vacuum
If you would like a repair manual, we can special order one for you for your Hoover S3639. Call us at AAAA TEVA Monday through Saturday from 9am to 6pm MST. Our number here is 303-770-6321.
Jul 18, 2012 | Hoover S3639 WindTunnel Bagged Canister...
My Hoover Steam Vac Spin Scrub aw/ Clean Surge
Greetings,
A few more things that you can try on your SteamVac. First remove the dirty water solution tank from the machine completely. You should see where the solution tank was just sitting, a plastic casing with a whole in it. This is actually where the suction from the motor goes into. Turn the machine on and feel the hole there for any suction coming out. Did you feel suction coming from the hole? If yes, then your issue is going to be something with the dirty solution tank, because without the tank it's sucking fine. If you didn't feel any suction from this hole, it may indicate that there is something more serious that needs to be taken care of.
One other place you may look on your machine (as long as the upholstery hose for stairs and furniture is already attached to the machine, and you don't have to hook anything up to the dirty water tank to use the attachments) while the dirty solution tank is out of it, is where the attachment hose makes connection with the vacuum. If you recline the handle down while you have the dirty water tank out, look in the back of the handle housing for a hose that enters the housing 3/4 down the housing. Now follow the hose on the inside of the handle not the outside, follow it up to the point where it goes into the neck, near where the suction hole is. Right at the end of the hose, right before the hose cuff, is this ripped, or damaged here?
Please feel free to request a clarification to this repair if you still need addtional help. If you can leave me the model number exactly that would help me help you, lol. I hope that this was helpful to you. If this was helpful to you, may you please click the helpful Thumbs Up Icon in the lower right hand corner of this repair?
Thank you so much,
Chris J.
Mar 21, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover suction
I had a fur ball stuck in the pipe.  I took the end off and used a broom stick to clear it out.
Jan 13, 2010 | Miele Cat & Dog 326i Bagged Canister...
Hoover s3639 vacuum...cord does not rewind
I had the same problem with my Hoover s3639. The cord rewinder started squeaking, and retracted less and less of the cord each time, until it finally stopped retracting the cord at all. Here is what I did. I hope it will work for you as well. Open the covered tool storage and remove the tools. You should see three screws. Unscrew the screws. Remove the cover. You should see the motor for the vacuum and the cord rewinder. Between the vacuum motor and the white wheel where the cord is, you should see two brass wheels that turn into each other in order to operate the cord rewinder. Spray a small amount WD-40 between the two brass wheels. This should solve your problem.
Dec 29, 2008 | Hoover S3639 WindTunnel Bagged Canister...
How do you open hoover s3639???????
Take out all the tools out of the tools compartment. The screws are "hiding" under the tools.
Jul 29, 2008 | Hoover S3639 WindTunnel Bagged Canister...
NO SUCTION
took mine to repair shop for this problem. Dog and people hair caught up in housing you can't reach.
Oct 28, 2007 | Hoover U8143-900 Upright Vacuum
MY CLEANER CUTS OFF
My Hoover S3639 on/off switch stopped working. I don't hear the 'click' any more. I removed the top of the vacuum but can't determine how to replace the switch.
Aug 18, 2007 | Hoover S3639 WindTunnel Bagged Canister...
Hoover S3639 WindTunnel Bagged Canister Vacuum Logo
136 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
