Question about Microwave Ovens
Microwave not heating up
We moved the unit to our new home, after that it stoped working (heating up food). I noticed door a little loose, Unit is a MAGIC CHEF model
"MCO153UW" I think a little old and can't find manual online.
Thanks,
Dean Magic Chef 56478 stopped heating food. Everything else works. I have not attempted any repairs.
  • Microwave Ovens Master
  • 19,396 Answers
If the microwave is not heating check magnetron connections, probably you will need to replace the magnetron.
Posted on Sep 06, 2008
Samsung microwave turns on when open door
The switch assembly is somehow staying "closed" satisfying the interlock and enabling it to run.
Disassemble the unit, beware specially of the high voltage capacitor, if you aren't comfortable or competent, buy a new microwave. If you are mechanically inclined, disassemble the unit until the switch assembly is accessible; it will have the door latch attached to it.
The switch is either broken or something? exogenous is keeping it closed. It may have come loose due to the door slamming?.
It's a simple fix. I am certainl you will be successful.
May 04, 2017 | Samsung Microwave Ovens
Siemens HF26066GB plate is moving when door closed and not moving when open
Have a shop look at this---there usually is a recessed safety switch inside the jam that will prevent the unit from working with door open--sounds like the problem may be with it.
Nov 03, 2012 | Siemens HF26066GB 1000 Watts Microwave...
Electrolux microwave buzzes and food doesn't heat up
If the unit operates correctly except heating the food, then the unit needs a new magnetron.
Aug 29, 2012 | Electrolux EI30BM55H Microwave Oven
Microwave oven not heating
This a good indicator the magnetron is gone, sometimes leaves odour that is destinctive.
Jun 19, 2012 | GE Profile PVM1790DRCC Microwave
Once I place food in to get re-heated, I noticed that my microwave did not heat the food, even though everything else worked...can you help
time for a new one. the microwave unit is dead, no the oven. the microwave unit is the heart of the oven. so, if that goes, everything else goes.
Apr 07, 2009 | Maytag MMV4205 Microwave Oven
Microwave does not heat/cook
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 19, 2008 | Whirlpool MH6150XMS Microwave Oven
Magnatron is suspect. Need to put a voltmeter on the input (primary) side to the high-voltage transformer (big heavy iron thing in there) Should be getting 120Vac when it goes to cook cycle. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing either the magnatron or the high-voltage capacitor and diode. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Jan 03, 2008 | Magic Chef CMV1000B Microwave Oven
Microwave oven
This is usually caused by a bad door switch or loose door switch mount but other common causes of a failure to heat are:
- problem or loose conneciton on the control unit circuit board
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 09, 2007 | Emerson MW8778 Microwave Oven
Microwave oven not working model sharp R-38ST
Nov 07, 2007 | Microwave Ovens
Microwave
Oct 13, 2007 | GE Countertop Microwave Oven
Microwave Ovens Logo
384 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
