Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
Compressor not working
I just changed my motherboard in model gsh22sgress. Both fans now work, but compressor does not start.Compressor tries to start then the overload trips.Compressor gets very hot.Took amp draw of compressor when it tries to start its 6.8amps. Any sugesstions? Stuck compressor? Maybe start relay. I know a little about how everything works but never messed with a refrigerator
  • 62 Answers
Why did you change the mother board? Was the compressor working before the change? If it was, then you need to check the new board and see if there were any wires that need to be cut when it was installed. If it wasn't running before the board change then you might try the overload on the compressor first. Also it should be checked with a compressor checker to determine if the comp is at fault or not
Posted on Sep 06, 2008
Unpluged compressor fan and light worked is there a fuse for compressor
There is a relay, overload and run capacitor on the compressor but you need to have someone check the windings in the compressor and the fan before changing any of those parts. Sounds like you have a short circuit with your description of the problem. What is the model number of your refrigerator? Could be a motherboard problem also
Apr 22, 2016 | Refrigerators
My Daewoo freezer is not working since yesterday, we tried to change the fuse but it just works for 15 seconds then,it stops we don't know why can you help please?
I would think that the compressor is either overheating, or faulty and cutting out on a Thermal overload cut out device fitted to the compressor.
If it is overheating, then it could be due to several problems:
1] Ventilation to the compressor is poor, or blocked.
2] compressor Cooling fan failed ( not fitted on all models)
3] Condensor blocked ( Not fitted on all models) This looks like a small car radiator in the compessor compartment (if fitted?).
Turn the fridge off, and leave it for up to 2 hours to cool, once cool, ensure that the ventilation is good around the compressor compartment, and try it again. If it starts and runs as normal it may have just overheated. If there is a fan fitted in the compressor compartment, then observe if it is working or not when you turn it back on.
If the compressor cuts out again, as you have described, trhen it is more than likely that the compressor has failed and needs replacing.
This is not a job that a novice can do, and will be expensive to have replaced by a Refrigeration engineer.
I hope this helps?
Feb 22, 2016 | Daewoo Refrigerators
How do I remedy the problem? It seems to be related to a fan trying to start up, but takes 10 or 12 tries before it keeps running.
model # AGE ? needed to give you better detail
If this is fan at compressor area it may be wired with compressor
compressor may be kicking out on overload.
stopping fan as well Change start relay at compressor
if that don't cure it looking at compressor
Apr 25, 2015 | Refrigerators
Why samsung refrigerator does not run model #RS261MDWP/XAA
if nothing is working - no fans running, no compressor running and no "clicking" sound of compressor trying to start, you probably have a defective control, which in your case probably means a bad control panel.
before trying to order one, unplug the frig and try to reset the panle.
Aug 18, 2014 | Refrigerators
Frigidaire PHSC3EHSS1I change the motherboard because its full of water and will damage. when change the new motherboard now the display and fan is on, so the compressor not start. i thank you for your...
Good Morning Edwin,
I see that you changed the motherboard in your Frigidaire refrigerator, model# PHSC3EHSS1I, due to it being full of water and would damage. I would suggest contacting your local authorized technician for further assistance. They will be able to diagnose exactly why the compressor will not start after you changed out the motherboard. Hope this is helpful.
-Best Regards-
Mar 15, 2014 | Frigidaire Model: PHSC39EHSS
GE model Pfs22miwww. Condenser fan and compressor not running. Tested start cal it is ok. Changed ontology board. Condenser fan now running. Still no compressor
Have you changed out the WR55X10942 Motherboard? Here is a link to test points on the motherboard HERE and here is a service manual HERE I don't mind helping answer your questions so feel free to contact me, Thanks Sea Breeze
WR55X10942 Main Control Board
Mar 22, 2013 | GE G.e Refrigerator Wr55x10942 Motherboard...
Same model as alot of others posting FRT04L5DB0 COMPRESSOR will not kick on all else works fan is on and with freezer door open and goes off with fridge door open and closed light is on evap is...
Hi this is either a shot compressor or start relay for the compressor, relays are $25-50.00 you could try that first if ifts the compressor your looking at $500+ to have it changed.
Mar 28, 2011 | Refrigerators
Freeezer with no compressor activity
If all fans are running, but not compressor You could try to install 3 N 1 start kit, thats might help 50/50. If it will start compressor - be ready for compressor to go out soon. might work for a year.
Dec 13, 2009 | Kenmore Freezers
Refrigerator has a clicking sound and does not run
Replace the motherboard (part # WR55X10942) but be careful to check that the evaporator fan (inside the freezer) turns on when you power up the refrig again. A bad evaporator fan motor can take out the motherboard. If compressor starts with new board but not evap fan, unplug immeadiatelly and replace the evap fan motor to save new board.
Sep 11, 2009 | Refrigerators
Please help our ac compressor wont come on
Hi, did you change, capacitor for compressor too. check compressor overload switch,(relay) normally located on compressor terminals, (where you connect wires to compressor) that's the device that goes klix when compressor goes to start, could be faulty, or maybe low voltage from your mains(house panel) check line voltage, with digital volt meter, some compressor won't start if voltage drops to low, yes fan will work, could also be, your compressor has a lock rotor, (hard start), you can buy a compressor hard start kit, from appliance store, and try to start compressor, or maybe compressor internal winding, are damage, especially now in summer, when you got a lots of voltage drops, check compressor winding, check compressor winding for short circuit, remove cover on compressor, remove 3 wires from compressor terminal, use ohm meter, put one tester lead on copper tubing that's connected to compressor, and next lead to compressor terminal, one by one, if you get beep (continuity) from anyone of those compressor terminal, you got a short- circuit in compressor, you will have to replace compressor, but if there's no short, them try hard- start kit, replace overload relay, you will see it at compressor terminal location, after you remove cover. good luck.
Aug 10, 2009 | Heating & Cooling
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
278 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
