Question about Technics SA-AX710
Overload on Technics SA-AX710 Receiver
A few days ago, my Techincs SA-AX710 Receiver stopped fucntioning properly. As I turned it on, it started to show the tuner and the radip station number and all suddenly within seconds it dissapeared only to display the word "overload" sequentially. I pushed the Help button and it only tells me to switch power off, I have done so and so far it keeps getting me the same message. Any suggestions?
  • 3 more comments
  • Brudez Feb 22, 2008
    I have the same problem on a SA-AX810. Plays for about 5 minutes then kicks off with the overload error. I thought it was getting too hot and replaced the factory fan with a 110v "always on" fan. Still no luck, 5 minutes and it's in overload again. Any suggestions?
  • Dragon1369 Feb 24, 2008
    As long as i have the bass knob in the middle and keep the volume knob below a quarter of the way it will stay on. As soon as i cut it up it says overload.
  • rongofrey Apr 18, 2008
    my problem is precisely what is described on the previous page
  • Anonymous Jun 14, 2008
    My SA-AX710 overloads intermittently. The problem is a broken solder joint between a pin on one of the power transistor modules and the circuit board. To fix it, I removed the circuit board from the case and resolder the borken joint. Opening the case is easy. First remove the top of the case. Then remove the 3 screws in front. The front panel can then be pulled off. After that, remove all screws holding the connectors on the back. The circuit board can be detached from the case by removing all the screws from the top of the board. Broken solder joint is probably one of the most common problems with modern electronics.
  • sean atton Jul 15, 2008
    I have exactly the same fault with my AX710 - 5 mins of playing and I get an overload error and the amp cuts out.
  • 95 Answers
Turn it off...remove all the speakers and turn it on....If it goes into the protect mode. you have a bad power amp. That's the big black flat things attached to the cooling fins.. one or both is shutting the system down. If it doesn't trip out, plug a head set into the phono jack and see if you can hear the music there. Can you turn it up without tripping.... if it's still ok...hang one speaker on the system, if it trips thats the bad leg...check the speaker/wire
Posted on Oct 23, 2009
    Novelist:
    Champion:
  • 277 Answers
First of all, check all the capacitors. Other than that, it needs a repair guy to have a poke about inside it with a screwdriver. Has anything happened to it lately that could have upset it a little bit? such as a powercut or had anything done to the plug? (e.g. change of fuse, and put in one that was a different rating) And is it plugged into a surge protection socket, or a plain old fashioned electrical socket?
Posted on Nov 22, 2005
SOURCE:
Have Denon AVR-2313ci receiver. FM tuner quit working; will tune in 50 MHz steps, on every step "stereo" and "tuned" are lit but no sound comes out whether actual station or not.
There is no module per se. Tuning is accomplished by applying a voltage to the tuner chip and their associated circuits. It needs to be repaired by a Denon service center.
Oct 25, 2016 | Denon AVR2313 7.2 Channel A/V Receiver
Pioneer SX-950
back in the day techs used to spray tuner cleaner on these things. not sure what they do now.
Jul 15, 2017 | Pioneer AVIC-S1 GPS Receiver
How do I change the radio station on my pioneer vsx-d903s
Welcome to FixYa.
You need to use the remote control to access the radio station frequencies.
Follow the instructions below:
Thank you for using Fixya. Have a great day!
Jas247
Jul 23, 2011 | Audio Players & Recorders
I just picked up a used Onkyo TX-SR502 receiver that has no audio output on any of the channels. I obtained a service manual for it and have tried a few things, but dont know the source of the problem...
I have the same problem, how did you initiate debug mode ?
The receiver worked perfectly until a few days ago, then one day it didn't work when I turned it on but started working after a few minutes. The next day it did the same thing and the folowing day it didn't work at all. Have tried the power reset and also had the top off to see if there's anything really visibly burnt - nothing.
This receiver never got bad treatment, left on overnight a few times but not with sound running out, just powered up. It's a bit enclosed I guess so maybe overheated but I find it hard to believe.
Anyway, can someone advise how to initiate debug mode and also what to do with it.
Thanks
Oct 04, 2010 | Onkyo TX-SR502 Receiver
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
Dec 21, 2008 | Audio Players & Recorders
Tuner Omits No Sound - Onkyo TX-SR605 7.1 Channels Receiver
Make sure your receiver is hooked up to proper AM and FM antennae. Try switching to AM, scan stations. If you hear AM static and/or weak signals the problem could be antennas are not hooked up. FM has AFT which blocks out weak or noisey stations and you wont hear anything without ant.
May 06, 2008 | Onkyo TX-SR605 Receiver
Receiver
My SA-AX710 overloads intermittently. The problem is a broken solder joint between a pin on one of the power transistor modules and the circuit board. To fix it, I removed the circuit board from the case and resolder the borken joint. Opening the case is easy. First remove the top of the case. Then remove the 3 screws in front. The front panel can then be pulled off. After that, remove all screws holding the connectors on the back. The circuit board can be detached from the case by removing the screws from the top of the board. Broken solder joint is probably one of the most common problems with modern electronics.
Mar 03, 2008 | Technics SA-AX710
Technics SH-AC300 Connection to Power Amp & Pre-Amp
Hi!
The problem is, that your SH-AC300 needs an amp with 5.1 input (but no decoder). For this purpose technics delivered SA-AX710.
So if you'd like to use your current equipment it would be impossible.
The only option is for you to buy 2 more Power Amps (SE-A900S), so that each of 3 amps would take care for one part of music. (one for FL, FR; one for RL, RR; and one for sub and center).
Another option is for you to buy SA-AX710. Then all the problems would be solved with it.
Jan 15, 2008 | Technics SA-DX950 Receiver
2,876 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
