Question about RCA HD52W59 HDTV Projection Television
Hdtv dlp 52 inch loss of picture and loud buzzing noise
We bought this tv 3 yrs ago and we lose picture and befor it comes back on it makes a loud buzzing sounds we've cleaned it and nothing seems to be working please help TV turned off without warning. We managed to get in on every once in a while but it turns off within 10 minutes. It turns on and off several times rapidly before turning off for good. Its 2.5 years old. I unplugged and let it rest for a long time that doesn't help
  • benseman102 Dec 14, 2008
    I have a Rca hd44lpw62 it sometimes works and there's a picture and is quite then there is a picture loud noise and sometimes there is no picture loud buzzing noise and sound on speaker and suggestions email me Benson_muraya@yahoo.com
Please see http://www.fixya.com/support/t1011937-transformers. It sounds like your flyback transformer is not properly soldered down/is failing.
Posted on Sep 06, 2008
Loses picture and shuts off and on
I once had an HDTV with a similar problem. If I turned it back on, it would make a loud BUZZ-BUZZ-Buzz noise for about twenty seconds before coming back on.
I can only guess that the problem is the TV drawing too much power from a circuit that can't support it. Do you have many electronics plugged into the same socket? Is the TV going into a splitter? Try isolating the connection and the TV might have better luck. No guarantees however.
If it's the same problem I had, then it will do this no matter what you hook up to it, as you seem to have at least partially discovered.
Jan 29, 2018 | Sony BRAVIA KDL-46XBR3 46 in. LCD HDTV
My Samsung HLP6163W started making a loud buzzing sound and the picture is distorted. I've read around and have come up with two possible solutions: replacing the lamp or replacing the color wheel. ...
100% this tv problems it is the tv colors wheel it is defective require replacing.The loud tv buzzing noises sounds are the sounds came from the tv wharp colors wheel it is spinning out control wildly and off of it motor axis and by hitting it to the wall of it steel box holding it.The tv distorted colors pictures are came from out of the reflections of a badly worn out of the tv colors wheel.
Jul 08, 2011 | Samsung HLP6163W 61" Rear Projection...
3 lights blink and a loud buzzing sound.
Color wheel you can get one at the following link with instructions on how to replace it
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Vizio 42'' HDTV flatscreen
The TV usually hums when the backlight setting is too low. So turning it up should get rid of the problem. To do this please follow these instructions:
1. Turn the TV on.
2. Press the Menu button on the remote, located right below the channel changing button.
3. Press the down direction button, located at the middle of the remote. Press that button until the backlight is highlighted.
4. Press the right direction button until the backlight is at 100.
5. Press the OK button and then the Exit button until you get back to your picture.
Oct 22, 2008 | Vizio GV42L 42 in. LCD Television
SOUND
I am having the same problem. My tv is 3 yrs old and doing the same thing. Any suggestions would be appreciated.
Thanks
Jul 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Loud buzzing noise from compressor area and freezer not cold enough
I have a 1.5 year old GE refrigerator and freezer. This unit had not given me any problems until 2 days ago when I constantly heard a loud buzzing sound coming from the freezer. I called GE and Best Buy (bought it there) and asked to troubleshoot this over the phone. They suggested sending a technician over for $100 just for the visit + labor + parts which could add up to hundreds of dollars. So, I researched the web and blogs like this. The answer to my problem was simple. Something that I placed inside the freezer was blocking the air circulation vent. So, I turned off the whole refridgerator and I removed everything from my freezer. For good measure I dislodged some ice and frost that had developed over the vent. I carefully put back everything into the freezer, but this time being careful not to block the vent. I turned on the power and voila! No more buzzing sound!!! I hope this works for you too.
Oct 31, 2007 | Refrigerators
Buzzing after 1 hour
Is the buzzing coming from the back of the TV, staying loud even when the volume is turned all the way down, or is it coming from the speakers?
Sep 04, 2007 | Mitsubishi CK-35306* TV
RCA HD52W59 HDTV Projection Television Logo
155 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
