This depends if the cables were plugged in or not...If they were, probably the jack for the defective input has had the solder to the board broken OR the cable has been damaged. Move the kick to a tom inout and see if the trigger works... If it does, then the Kick inout connector is probably broken away from the solder. Unit will have to be opened for inspection to find the defect. If the kick doesn't work at all in the other position, the cable from the kick MAY have been stretched or brolen.
