Question about Macplay Baldur's Gate II: Shadows Of Amn for Mac
Error 89 Whenever I try to load a new map/area from the graveyard district in Baldur's Gate II, I get a dialog box that says file error: error 89. What the heck is it talking about?
  • Kajica Sep 16, 2008
    Thanks for the advice, though oddly enough the problem fixed itself. The only thing I did different was I started from an earlier save that wasn't in the graveyard, then reloaded the game I was trying to play and it worked. I'm guessing that one of the files corrupted and that it fixed itself when I loaded the earlier game. I'm not for sure on that, but it's the only thing I can think of...
  • 51 Answers
Error 89 is probably something wrong with it actually loading the new map. Theres probably a script error with the transition 'compasses'. I suggest cleaning the disk as well as possible (if you havent already tried), and, if that doesnt work, i think its a good idea to get a new disk.
Posted on Sep 13, 2008
I can't restart the canon MX366
My canon mx366 cannot import a scanned file...... whenever i scan i always get a dialog box saying "error in importing the file. and i have to choose between try again, skip the file or skip all error importing file" can somebody help me to fix it...
Oct 22, 2011 | Canon Pixma MX360 Printer
Whenever we try to open skype a dialoge box apppears showing fatal error failed to load library d3d9.dll.
You will have to re-install the Skype application in order to get rid off the error.
Please follow the below step:
1. download and install the Revo uninstaller application online(It's free).
2. Look for the "Skype" application and select the "uninstall" option.
3. Select "Advance" scan and remove all the remaining files of skype.
4. Reboot the computer.
5. download the d3d9.dll file from the following website
6. Copy the d3d9.dll file and paste it at the following location C:\windows\system32
7. You will have to register the dll file before installing the skype application. To register the dll file:
Click on "Start" menu and select the "Run" option or Simply Windows key+R
Then, type regsvr32 d3d9.dll and click 'OK" .
8. Once the dll file is registered, you can install the Skype application and continue using it.
I hope this should fix the issue.
Thanks, Vicky
Dec 27, 2010 | Compaq Presario 5000 PC Desktop
The Update Assistant keeps opening a dialog box stating that it has no access to the router. But whenever I try to do anything in the dialog box--click a button or close the dialog--an Internet Explorer...
1.Press Windows logo key + R, type winver and hit Enter key.( Check the version details of Windows 10 installed on your computer).
2.Shutdown your device ,restart it back and then initiate the upgrade to see if goes correctly this time.
If any third party Antivirus or Online security software is installed, then try to disable it for a moment then try to initiate the upgrade to see if it goes correctly.
In case problem still persist, then try to upgrade it in Clean Boot state.
1. Press Windows Key, type msconfig in the search box, and hit Enter.
2. On the Services tab of the System Configuration dialog box, tap or click to select the Hide all Microsoft services check box, and then tap or click Disable all.
3. On the Startup tab of the System Configuration dialog box, tap or click Open Task Manager.
4. On the Startup tab in Task Manager, for each startup item, select the item and then click Disable.
5. Close Task Manager.
6. On the Startup tab of the System Configuration dialog box, tap or click OK, and then restart the computer.
Apr 08, 2017 | NetGear WNDR3300 - RangeMax Dual Band...
Ignore the error and continue printing. The print job might still be acceptable even if the paper size and paper type settings are not an exact match.
  1. Press Enter on the control panel to clear the error message.
  2. Try the print job again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
    Use the HP product software, also known as the printer driver, to change the print settings for your paper size and type depending on your version of Microsoft Word.
    1. In Microsoft Word, click File , and then click Print .
    2. Make sure that your HP product is in the Name drop-down list box, and then clickProperties .
    3. Click the Features tab, or the Paper/Quality tab.
    4. Select a paper size from the Size drop-down list.If the required paper size is not in the drop-down list, follow these steps to create a custom paper size.
      1. Select Custom from the drop-down list.
      2. In the Custom Paper Size dialog box, type a name for the new custom size.
      3. In the Width and Height boxes, type the dimensions.
      4. Select the unit of measurement, and then click Save .
      5. Click OK to close the Custom Paper Size dialog box, and then click OKagain to close the Properties dialog box. NOTE: You must exit the Properties dialog box to apply your changes.
      6. Open the Properties dialog box again, and then select the new custom size from the Size drop-down list.
    5. Select the paper type.
      1. In the Paper Type or Type is drop-down list, click More .
      2. Click the desired paper type, and then click OK .
    6. Select the paper source from the Paper Source drop-down list.
    7. Change any other settings, and then click OK to close the Properties dialog box.
    8. Try the print job again.
      Paper mismatch errors occur because the printer scans the width of the paper before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the printer, the printer reports a 'Paper Mismatch' or 'Paper too Narrow ' error.The error message might also display when you load the correct paper, just reinstall the printer driver if above procedure does not helps. Thanks. keep updated for any more can rate this solution and show your appreciation.
Jul 10, 2010 | HP PSC 2210 All-In-One InkJet Printer
Whenever I open a new spreadsheet now it automatically opens up a spreadsheet calles PERSONAL. Why is that and how can I get rid of it... I think it started after a did a macro but I am not sure. Thanks,...
You're right - it was caused by recording a macro. When you record a macro you are given the option to store the new macro in "This Workbook", a "New Workbook" (the default), or in a "Personal Macro Workbook". It looks like you selected "Personal Macro Workbook".
The recorded macro is stored in a special workbook called "Personal.xls". This workbook is loaded every time Excel is loaded. If you don't want this workbook loaded, then just delete it or rename it.
The file is buried deep in Microsoft's application data area. On my Vista computer it's in C:\Users\frogfund\AppData\Roaming\Microsoft\Excel\XLSTART On my Windows XP computer it's in C:\Documents and Settings\frogfund\Application Data\Microsoft\Excel\XLSTART. Depending on your computer your Personal.xls might be in a slightly different location. You might need to do a search using Windows Explorer.
If you are still having troubles finding personal.xls 1. Open Excel, 2. Open the Visual Basic editor (hit Alt-F11 or click Tools-Macro-Visual Basic Editor) 3. Click Tools-References to bring up the references dialog 4. Click on VBAProject in the list. The file location will be displayed near the bottom of the dialog box. Sometimes this might be cut off at the end, but it should give you a good idea where the file is located. 5. Click Cancel to close the dialog.
Sep 23, 2009 | Microsoft Office Excel 2003 for PC
How do I realign my hp photosmart c4480 printer?
To align the print cartridges from the HP Photosmart Software
1. Load letter or A4 unused plain white paper into the input tray.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
2. In the HP Solution Center, click Settings.
3. In the Print Settings area, click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Features tab, and then click
Printer Services.
box. In the Print Properties dialog box, click the Features tab, and then click the
Printer Services button.
The Printer Toolbox appears.
4. Click the Device Services tab.
5. Click Align the Print Cartridges.
When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
press the button next to OK.
The product prints a print cartridge alignment sheet.
7. Load the page print side down on the right front corner of the glass, and then press
the button next to OK to scan the page.
When the On button stops flashing, the alignment is complete and the page can be
removed. Recycle or discard the page.
Jul 18, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Whenever I tried to login in the Yahoo Messenger, an error appears 81003004
error 81003004 is a connection problem,
Connection Problems;
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.check connect directly to internet then click ok
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
Jul 10, 2009 | Yahoo Messenger
How to locate and remove automated programs
Whenever u use internet close the dialogs box which appears when using internet. they causes errors .
Especially when u click on the dialogs box which appears free antivirus scan.
1.try find out in program files . windows->press alt+ctrl+del->windows taskbar manager appears->under processes tab->find your program
best of luck
Jul 02, 2008 | Microsoft Windows XP Home Edition
Mirror image
Printing Iron-on Transfers
Load the iron-on transfers.
With your document open, click File, then Print. The Print dialog box appears.
In the Print dialog box, click Properties, Preferences (or Options).
Select a print quality:
In the Print Properties dialog box, click the Quality/Copies tab.
From the Quality/Speed area, select Normal or Better.
Select a paper type:
In the Print Properties dialog box, click the Paper Setup tab.
From the Type area, select Iron-on Transfer.
If your software program does not have mirror or iron-on settings, select a print layout:
In the Print Properties dialog box, click the Print Layout tab.
From the Layout area, select Mirror.
Click OK.
To print your iron-on transfers, click OK.
NOTE: To prevent smudging, remove each iron-on transfer as it exits the printer and then let it dry before stacking.
Mar 29, 2008 | Lexmark P4350 All-In-One InkJet Printer
Macplay Baldur's Gate II: Shadows Of Amn for Mac Logo
505 people viewed this question
Top Macplay Video Game Consoles & Games Experts
James Wishart
Are you a Macplay Video Game Console and Game Expert? Answer questions, earn points and help others
