Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Please help i have the sandisk 2.0 gb mp3 player and its worked good for about 2 weeks and yesterday it just shut off and it wont cut back on and when i try to plug it into my computer the computer wont recognize it and nothing happens
  • mastermarth Sep 21, 2008
    My computer wont recognize the device, the device freezes upon being connect, and the computer doesnt even pickup that a device has been connected. It also freezes upon bootup. I can occasionly get it to boot up, and listen to some music, ironically, i have gotten it to format, but when i disconnected it my music was still there. I've tried MP3 doctors solution, but when i try to install device recovery it fails, i cant install firmware because i can get the computer to rcognize the device, and i cant format it again for some reason. Nor is the system recover mode working for me. But i have seemed to notice that if i hold in the silver button in the middle when i boot it up, i'll get the monster screen before it freezes, if i dont, i just get the blue light around the silver button and the power/menu button, and the screen stays off.
  • 8,596 Answers
Substitue REC for Volume + in the below:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Sep 06, 2008
Need help
The only solution is to delete some songs, if it is a 2 GB and it is a Sansa Clip then the max songs you can get is 450-550
Feb 08, 2009 | SanDisk Sansa Fuze MP3 Player
Connecting sandisk mp3 player to a computer
try going to www.sansa.com click on support and then click on your model player. Go through the troubleshooting questions and find your problem. there should be a few solutions for you to try. Good luck :)
Jan 27, 2009 | SanDisk Sansa e250 MP3 Player
Wont stay on.
Please check to make sure the hold button at the very top is not activated...that would cause it to shut down..
I hope that helps
Please rate accordingly
Thank you
Computerrep
Jan 27, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
How do you unlock a sansa m250 mp3 player
OK, I don't mean to be obvious, but on the bottom of the device (as you're looking at the screen), there's a switch that locks it. If you can see the red, it's locked -- if you slide it over, it unlocks. Again, you may have tried that, but since it says "Hold" and not "Lock" under the switch, it's not entirely obvious. Hope that helps?
Nov 18, 2008 | SanDisk Sansa m250 MP3 Player
Sandisk Cruzer micro 4 gb
try to connect it firs to other computer, if other computer can detect it,format it..if not,that means your sandisk wont be usable anymore.
Oct 16, 2008 | SanDisk Cruzer Micro MP3 Player
Sansa c150 not working properley please repair it
I have 1 g used and it wont let my load anymore and all the songs come up as A is my player dead
thanks
Oct 02, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa 250 2 gb
your USB might not be getting charge to it. might be, but see.
May 22, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Its dead with no special reason
try pressing the down button followed by the power button. the idea is this unlocks "reserve battery" so the player can tell you what the problem is.
May 16, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
HELP ME PLZ
That's a pretty weird problem. The only suggestion I can give you is to check to make sure the music you put on was 1) in mp3 or wav format and 2) if this is music you have purchased, to ensure you have the rights properly set to play the music
Aug 06, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
35 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
