Question about Honeywell Programmable Thermostat Heater
Wiring diagram I am looking for a wiring diagram for an eneroyal furace that has honeywell controls it has a 24v transformer and relay set up with this lettering configuration on it C R Y G W
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
C--=common r-red=power y-yellow=cool g-green=fan w-white=heat..!
Posted on Sep 09, 2008
?Location and photo of the transformer for a gaffers and sattler wall furnace model S 90 FE.
No. The transformer "transforms" 240 volts to 24. Meaning the high voltage coming into the machine. Normally has a "c",208,240 written on one side. Follow your main power wire into the machine. Branches to heater and transformer. Look at wiring diagram
Mar 01, 2017 | Heating & Cooling
Wiring a Honeywell V8043E for two zones
Honeywell posts pdf manuals.
Google seArch Honeywell V8043E .pdf
Include .pdf in search parameter to find manual with wiring diagrams.
http://www.forwardthinking.honeywell.com/related_links/water/5000_series/install/95c_10932.pdf
Oct 26, 2012 | Honeywell V8043E1012 Zone Valve 3/4 Sweat,...
How does a honeywell L4064b2236 work? It is set up on a Gas hot air furnace with the jumper removed, Three wire connection, black to common white to fan and red to limit. The furnace has a tranformer on...
If the jumper has been removed, then the control is working in the low voltage circuit. Black should be 120v in, White the 120 going out to the fan, and the red or limit wire is (should be) in the low voltage control circuit. Have you looked at the wiring diagram for the F and L Control? If not I will provide a link for you. https://customer.honeywell.com/techlit/pdf/69-0000s/69-0117.pdf
Hope this helps
Nov 16, 2010 | Honeywell L4064B2236 Fan/Limit Control...
I get no water through the selinod. I replaced it
First check to see if you have power at the transformer, that controls the humidifier. If you have 24v there, check to make sure you have 24v going into the humidistat, and 24v leaving the humidstat. If all this is correct, and the solenoid is not getting power, you may have an isolation relay wired into the blower motor (only in some applications) that has gone bad. Check the blower cabinet for this relay. Hope this helps
Jan 30, 2010 | Honeywell HE365 Humidifier
AC, Fan-Auto, Fan-On... nothing works. the request from the Thermostat doesn't engage anything. Thermostat Dispay works. How do I know if it is getting the 24volts from the relay? I presume the display...
Open the air handler. Locate the low voltage transformer. One side is 220 volts input. The other is 24 volts output. Take your VOM and touch the test leads to the input to verify 220v in. Then touch the other 2 leads to verify 24v out.
If you have power in and no power out, replace the lv transformer.
Jul 08, 2009 | Honeywell Heating & Cooling
When I set tstat to call for a/c, compressor outside comes on. Blower on furnace does not. When I manually rotate fan limit switch on furnace wall, blower comes on, blows cold air, and then goes off when...
blower relay bad or no call from stat on green wire to run fan jump red on stat to green if fan comes on stat bad if no look for fan relay turning the well switch bypasses the relay hope this helps
May 24, 2009 | Heating & Cooling
Honeywell RTH3100C
You need to go into the installer setting to change it from heatpump to single stage gas heat.Go to www.honeywell.com if youve lost them.
Dec 13, 2008 | Honeywell Programmable Thermostat Heater
Wiring in a new thermostat
On the usual 24v gas heat and cool system, the red is the 24v, or power from the transformer, the white is the heat, the green is the fan (the ON setting on the thermostat not the auto) and the cool is either yellow or blue. You can connect the red to rh or rc, if the new thermostat has this, just put a jumper wire between them. If your new thermostat has a c and o connections, you may have the wrong type.
Jan 16, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
316 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
