Question about Sony KV-32S42 32" TV
Sony KV-32S42 TV wont stop searching channels
When i turn it on all it does is search through the channels and show snow... keeps scanning though channels non-stop. Can't even get it to stop on 3 or 4 to use VCR or anything, power button works, no other buttons affect it.
4 Suggested Answers
SOURCE: sony trinitron tv kv-32s42 has no volume
Change the audio amplifier Ic
Posted on Nov 04, 2008
SOURCE: tv has a mind of its own
Just had the TV repaired for the same issue. According to the shop it was a bad channel up/down switch. That impacted the other functions (menu not working, remote malfunction) because they're all intertwined. Only about a $75 fix here in the DC area, so maybe cheaper elsewhere.
Posted on Jan 12, 2009
  • 668 Answers
SOURCE: Sony TV not turning on
Chances are the Power Supply failed because the Horizontal circuit failed. It would not be out of line if the repair cost ran 250.00 plus.
It is probably not worth fixing due to the age of the set.
Hope this helps,
Skyassoc
Posted on Jul 17, 2009
How can I turn the screen voltage up?
from description you are on the right track--screen con inside will either be on the crt circuit board or on the high voltage transformer, on or the other--lots of the older Sony sets when the picture tube gets weaker need this done.
Dec 15, 2012 | Sony KV-32S42 32" TV
No picture, but sound
tried to hooked up with an air antenna. if you can not get any channel and just a white raster or snow, it could be the tuner get fried.
Jul 22, 2012 | Sony KV-32S45 32" TV
Sony tv Kv-32s42 flashing stand by light non stop, sound but not picture
You probably took out the Horizontal Output. A repair like this is between 150-195 dollars.
Jun 06, 2011 | Sony KV-32S42 32" TV
When I turn the tv on (vega fd trinitron) the scren is all snow. There is no signal.
Hello
Have you tested it with auto tuning progremme process. If it snow there, your TV may be working properly. Sometimes its signal input path is not Ok. Without any signal, all TVs may show either snow, or a plane blue raster if its blue back function is on. You just do the automatic tuning process once again after connecting it with an external or internal antenna. There is a socket provided there in the back side of your TV, and marked as VHF/UHF. Connect the signal source to it first.
And set your TV to autotune by slecting it from the menu of your TV. The TV will search for all the channels available at that time, and after searching is completed, it will stop and show the first channel received. Afterwards you can chage or delete or skip unwanted channels. You may have its manual with you. All the descriptions are there in that manual. Ok.
Oct 30, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony Trinitron KV-32S42 keeps blinking on and off
This can be a symptom of the picture tube starting to fail or a power supply problem. Can you please verify the model number and I'll then be able to give you a few options.
Thanks,
Dan
Nov 11, 2008 | Sony KV-32S42 32" TV
Adding a audio jack to KV-32S42 sony TV
yes, just tap in at one of the speakers. The jack should have an internal switch so that the internal speaker is hooked up when the headphones are not in. Most TVs are now stereo (even though analog broadcast signals are mono) so may want to get a stereo jack and tie in from both speakers.
Jan 10, 2008 | Sony KV-32S42 32" TV
Sony kv 32s42 32 tv
turn up your master screen control on flyback transformer. if when sceen gos black ,the timer light will be blinking. this means your picture tube is week. by turning up the screen control you may give it more time.
Aug 05, 2007 | Sony KV-32S42 32" TV
Can't get any tv reception
My friend, you need to hook up a signal source such as an antenna or cable . The channels wont come in and it will all depend on where you live and how close to a major city on what and how good you will get the stattions. then once an antennena is connected, do the auto programming again. Good Luck
Aug 18, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Open Questions:
See all Sony KV-32S42 32" TV Questions
Sony KV-32S42 32" TV Logo
27 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
