Question about Maytag Neptune MDG5500AW Gas Dryer
Runs fine, no heat. Not clogged. Any thoughts?
  • jwillar1 Oct 06, 2008
    I have the same problem, but have already previously removed the lent screen on the outside when it failed to heat before. I have cleaned the exhaust line from inside the dryer to external the house. Still nothing! The exhaust it blowing lots of air, but the burner just won't light. Any suggestions? Thank you!!
  • gardenbug73 Oct 12, 2008
    Maytag Neptune gas dryer, removed and checked the dryer vent cleaned the sensor, still have no heat.
    Novelist:
  • 166 Answers
Friend,
ngfam1 At your service!
Sometimes this can happen when the vent line is clogged.
CHECK ALL these spots!
1. Check if the lint filter is full and needs to be cleaned.
Try this first.
2. Then check if the outside screen covering the exhaust vent is even half blocked with lint there will be no heat! This screen is to keep small animals out!
Try checking this second and if it is clogged or the spring loaded door is stuck closed try to clean the lint out of the corners of the flap door, and or remove the screen permanently!
I DID AND NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE!
2 years that mine is off and it's all is fine.
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Sep 06, 2008
Maytag Neptune MDG5500AW gas dryer takes long time to dry
Check the dryer vent ducts for clogs, internal and external.
Oct 23, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My neptune mdg 5500 dryer starts and runs but will not get hot
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 10, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My dryer runs but no heat, working fine the ohter day, is there a pilot to be lit ?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Neptune MDG5500AW Gas Dryer: gas dryer will not heat...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
May 18, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Does not heat up
maytag neptune gas dryer runs but does not dry clothes i smell gas initially when i turn it on
May 07, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I have a gas Neptune dryer. It runs but there is
More than likely your glow coil has failed and you will need to replace it.
Mar 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune mdg6400aww heats up for 1-2 mintutes then not heat
Make sure there are no major airflow obstructions. If not, replace the coil packs on the gas valve.
Aug 29, 2009 | Maytag Neptune MDG5500AW Gas Dryer
No hot air for dryer
this is most likeky thermostat you can find here http://www.partstap.com/
Feb 25, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Intermitten heat
We have a Neptune Gas dryer,my husband changed the belt cause it was making noise,now the heat hardly works,i put the dryer on for 40 minutes and usually it is dry,now i did that twice and clothes is still damp,would you know what the problem is please help
Jan 12, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
69 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
