Question about Proscan PS27108 TV
Set up menu
The set up menu comes up on the screen while we are watching the tv. It stays on a few seconds then goes off only to come back on a few minutes. We called tech support and they said to unplug the set and then plug it again and it would go through automatic programming. This hasn't worked. We called tech support back and the second guy said to take it to a service center.
Any help?
    Sergeant:
  • 226 Answers
Your set could be losing the 5v to the system control chip, or the keys on the remote or front panel may be sticking. You could also have a power supply with diodes or capacitors that are dying.
If you don't know how to service this, don't even bother opening the cover.
tom
Posted on Feb 27, 2009
My Dynex 32" LCD tv seems to turn on and off
The blue light merely indicates that power is getting to your TV. It has internal power supply problems.
Nov 30, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
Periodic static while watching TV
Check the cable connection from the wall to the TV.
Nov 04, 2012 | Samsung Televison & Video
Screen blanks after 30 to 60 seconds
change 22mf-200v near fly back .
Apr 10, 2010 | Sharp 25K-M100 25" TV
My magnavox 42mf438b lcd tv will be fine for about 10 minutes when i turn it on, then the screen goes completely black but it still has sound. it stays like this even if i turn it off and back on. i can...
that set is highly rated by users .. it first came out in early 2009 (i think) so you might check to see if any warranty remains ... the display is illuminated by several lamps .. each lamp has its own high voltage inverter .. all the innverters are powered by an output of the low voltage power supply (often 18 volts)... i would suspect a problem with that low voltage power supply.. either a bad capacitor or a thermal issue .. .. ..
Apr 10, 2010 | SNK Magnavox 42MF438B/27 42 in. LCD TV
Syntax Olevia flat screen tv video goes off then on
Hi, Replace the bulging capasitors on the main power supply board. Thanks.
Sep 22, 2009 | Insignia 37" LCD Flat-Panel HDTV
Dvd problems
The issue might be that you have to send the LHT854 Back to the manufacturers and have the playback feature replaced. The playback feature is controlled by a device that is internal and very important to the overall function of the unit.
Mar 28, 2009 | LG LHT854 Theater System
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Set up menu
Check to see if something was spilled on the screen of this set
or using too much cleaning solution.
As it will run down on to the tac switches and create problems with the cpu.
Thanks guy
May 24, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Problem with my Aquos lc32d40u
Your inverter/lamps are bad. Those are only available with the LCD panel as an Assembly, and that is worth more than the TV.
Mar 21, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
43 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
