Question about Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L)
Bios HI,,I DONT KNOW WHY .BUT I CAN ONLY START UP MY PC IF I CLEAR CMOS,,AND NEED TO PRSS F1 AND IT STARTS,,,AND GOES TO DEFAULTS,,I CNAT START IT UP NORMAUL,,PLEASE HELP
  • carmyt Sep 05, 2008
    I WILL TRY THAT,,THANKS,,LET YOU KNOW IF IT WORKS
    Problem Solver:
  • 53 Answers
The small, on system board, battery that maintains the flash (CMOS) settings is probably kaput and needs replacing .
Posted on Sep 05, 2008
    Genius:
  • 1,027 Answers
You probably need to replace the on-board battery.
Dell Inspiron 530. At start up gives CMOS checksum error defaults loaded. Options press F1, F2 or F12 computer does not react. Has new CMOS battery. RAM OK. Did CMOS clear and password reset. What else can...
When a Power Supply is plugged into power, there is a constant 5 Volts present. The 5 Volt Standby Power.
You press the Power On button.
This in turn presses against the Power On switch, located inside it's plastic assembly.
The Power On switch is a Momentary Contact Switch.
Temporary closing it activates the Soft Power On circuit.
A 5 Volt circuit that utilizes the 5 Volt Standby Power.
The Soft Power On circuit 'excites' the Power Supply, and turns it on.
(Sounds like a seedy novel)
The first chipset (Integrated Circuit) to receive power is the BIOS chipset.
The Basic Input/Output System program is initialized.
BIOS looks to see what devices are connected, does a Ram Memory count, turns the Processor on, and hands the computer over to the Operating System.
A checksum is computed as an error-detecting code, to protect the BIOS settings stored in CMOS.
Each time the computer is turned on, this number is re-computed; and checked against stored values.
If they do not match an error message is generated, to tell you the CMOS memory contents may have been corrupted; and therefore some settings may be wrong.
Your BIOS assumed the settings were incorrect, and loaded BIOS default settings; stored in BIOS.
(Default = factory settings)
CMOS Checksum Error Defaults - Loaded
New battery? Nope didn't help.
Clear CMOS, and password reset? Nope didn't help.
Leaves Virus as the problem, or hardware component/s on motherboard; are bad.
My thoughts?
Bad motherboard.
("BAD motherboard. NO,...........you know you have been bad,....don't give me that look. You're a bad motherboard."
Lol!)
That's my diagnosis.
(Unless you put the CMOS battery in upside down.
+ goes UP)
Regards,
joecoolvette
Mar 17, 2013 | Dell Computers & Internet
Gateway gt5220 has cmos checksum error - defaults loaded
Open the cpu cabinet cover then pull cmos cell from motherboard for 10 minutes then all settings defaults.Then when you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios then set bios settings.Let me know if you need further assistance.Thanks for using FixYa
Nov 18, 2011 | Gateway GT5220 PC Desktop
Cmos checksum erroe defaults loaded
press del to enter setup.then choose default bios setup. then save and exit.pc will restart.
Nov 17, 2011 | Gigabyte GA-945GCMX-S2 Motherboard
BIOS Lock preventing reload on Tiny PC
For that you need to RESET your bios settings to factory defaults.
Open cpu cabinet cover and pull cmos cell from motherboard for 10 minutes then all settings goes to defaults.
You can also reset settings with jumper it is near cmos cell it has 3 pins 1-2-3 put jumper in 2-3 position then power up the computer then all settings defaults.
Then if you want to boot your computer with disk then when you power up the computer press F1 or F2 or del key to enter in bios then go to boot menu and set first boot device as cd/dvd rom then save settings and exit.
Then it boot with your disk.Then follow the procedure on screen then you can reinstall your windows or recover old windows.
Thanks for using FixYa.
Mar 13, 2010 | Computers & Internet
How do you rest the bios on a ASUS p4vp-mx mother board
it has a coms jumper in side coms battery 1-2 jumper normal position 2-3 clear coms choice 2-3 then *********** board reset
Nov 22, 2009 | ASUS P4VP-MX Motherboard
Unable to get into my bio settings to change from linux to windows please help
for that when you power up the computer press F1 or F2 or "del" key to enter in bios.
Then you can see bios setup screen.
But if you still not able to access then open cpu cabinet and pull cmos cell from motherbord for 10 minutes then refix it then all settings goes to defaults.
Then check with again F1 or F2 ,"del" ,F12,F8 or TAB or enter key.
Let me know if you need more assistance.
Thanks.
Oct 23, 2009 | Computers & Internet
Bios pass word
You can clear bios with factory defaults reset.
For that open back cover of your laptop.
Then pull cmos cell from motherbord for 10 minutes so all bios settings are defaults.
Then put again cmos cell in it's position then it not ask password.
Let me know if you need more assistanse.
Thanks.
Sep 18, 2009 | IBM ThinkPad R40 2681
I need to clear he bios password in a toshiba satellite pro L40
  1. Remove battery.
  2. Remove memory.
  3. look at the side of the memory at the top left side and locate the little brassy coloured dots with the lettering JRST1 at the side (jumper reset 1).
  4. Touch something metal across them for a few seconds.
  5. thank me because no where on this stupid internet has anyone got a solution to this and I had to find it out on myself.
Good luck, Bowling Crony.
Sep 08, 2009 | Computers & Internet
I have a sony vaio vgn-a290 laptop and im trying to reset the bios password. Ive found the dipswitch on the mother board but dont know witch one resets the bios password. could anyone help me
Pull cmos cell from motherbord for 10 minutes so all settings are goes to defaults.
Also you can reset its settings with jumper settings.
You can see 1 jumper onmmotherbord near cmos cell.
Read carefully on bord you read there RESET or CLEAR bios.
it has 3 pins.set jumper in 2-3 position then power up .
Then again set to its original position 1-2.
Then all settings defaults.
Thanks.
Sep 01, 2009 | Computers & Internet
**** RTC battery is low or CMOS checksum is inconsistent **** Press [F1] to set Date/Time
Hello
Please reset cmos to factory defaults.
Then enter the bios setup and configure it and save changes.
Apr 20, 2009 | Computers & Internet
Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L) Logo
110 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
