Question about HP Pavilion ze2000 Notebook
Ze2000 hp pavilion fan motor?
My laptop is only a couple years old but has a nasty noise when the fan kicks on to cool. I have never taken a laptop apart but am thinking it needs a new fan motor. If it is not the fan I don't know what it would be.
If it is the fan does this cost a lot? Do you recommend circuit city or those type places? should I try to do it myself?
  • smallfidget Dec 15, 2008
    I have a similar problem ... the fan is the culprit! The moment the laptop heats up (and boy!, ze2000 heats up fast) ... it kick starts the fan. It even disrupts chat sessions.
    Kindly advise, which fan model is the best replacement ... quietness-wise and compatibility-wise.
  • Anonymous Mar 31, 2009
    any change since someone replace fan ?
    Champion:
  • 200 Answers
Ok my friend as u mentioned its mostly the fan but lets put in mind the Hard Drive also because some time when you the HDD starts failing it will give the grinding sound
and since its a laptop i dont recommend that you take it apart unless u know exactly what r u doing
and yes u can go to circuit city or try best buy (geek squad) its up to u
cheers
Posted on Sep 05, 2008
Ram upgrade
no you have to use pc2700 for the pavilion ze2000. Max Memory 2gb (1gb x 2).
Aug 23, 2013 | HP Pavilion ze2000 Notebook
Got noise from fan told its fan on hard drive worn is this fault with them only 2 years old
The hard drive does not have a fan. There is a fan on tht CPU heatsink and a fan in the power supply. You may have a case fan for additional cooling, but this is not always installed.
Noisy fans are easy to replace, but not the one in the power supply.
Jan 13, 2011 | HP Pavilion dv9000z Notebook
HP Pavilion ze2000 Laptop won't turn on
Have you tried removing the battery and seeing if the laptop will then run?
Jan 18, 2010 | HP Pavilion ze2000 Notebook
Loud fan noise from hp laptop pavilion dv4.
Try to modify your power plan, i modified the value of process power management and fan noise came down havily. This can be found under advance setting in Power plan.
Jan 09, 2010 | HP Pavilion dv4-1140go Laptop
HP Pavilion ZE2000 shuts down after HP Logo Screen
try putting a virus scanner boot disk or its because of mabey your laptop needs a new bios chip mabey?
Dec 31, 2009 | HP Pavilion ze2000 Notebook
Cooler fan does not work in a HP pavilion ze2000 laptop, how can I fix it? Thank you
if the fan is not turning you can check in your power options to see if you have your fan is configured to run all the time. if this does not work you will need to replace the fan.
Oct 29, 2009 | HP Pavilion ze2000 Notebook
HP Pavillion ZE2000 screen badly damaged.
Actually I got a HP dv600 widescreen for $98 and $17 shipping and handeling from ebay and it's new with a warrenty just do a search on ebay and you can get new don't get used it's not worth the headaches.
Happy Holidays
Dec 24, 2008 | HP Pavilion dv9000z Notebook
The fun does not rotate
Hi!
Try to vacum the dust way from the fan, and try to blow the dust u cant vacum whit compressed air.
If that dosent help you need to buy a new fan. Be carefull so your laptop dosent overheated, the heat cam make big damages inside your laptop.
Good Luck
Nov 20, 2008 | HP Pavilion ze2000 Notebook
HP ZE2000
Dust on the CPU Fan, or rear casing Fan. Or Hard-Drive wear to fluid bearings.
Mike @ compurepair.
Jul 08, 2008 | HP Pavilion ze2000 Notebook
Hot temp
There service manual, which you can download for free from hp's website has directions on how to replace the fan. Here is link to the manual (pg 161):
http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
Also, I would suggest purchasing one of those laptop cooling fans that set underneath the laptop and plug into the usb. They do a fantastic job of helping to keep the laptop cool and they are not too terribly expensive.
May 14, 2008 | HP Pavilion DV1010 Notebook
HP Pavilion ze2000 Notebook Logo
160 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
