Question about Whirlpool LER4634J Electric Dryer
Ghost in my dryer????
I have a Whirlpool LER7646JQ0 dryer. I replaced the heating element in it about a week ago and everything seemed fine. Now, the dryer will run and heat but now it will stop during a cyle. It won't turn back on unless I unplug it and wait a few minutes. (When the dryer won't turn on, the timer doesn't click and the light inside the tumbler won't come on.)
I tested the Thermal Fuse by bypassing it. The dry will worked, but after I ran it a few minutes I stopped it and it won't restart...unless of course I unplug it again and wait. UGH!!!! What in the world is going on???
  • 1 more comment
  • swiggins988 Sep 06, 2008
    Thank you very much for your replies. I appreciate that.
    The wall plug and cord checked out fine.
    I have cleaned all ducts (and they needed it!) and still had the problem.
    I believe the start switch might be defective because I can hear a slight "pop" when I press it and then the dryer just stops all together. No heat build up or anything like that...it just stops.
    I took the start switch to my local dealer and he checked it and said it "had bad spots". Of course, they don't carry the switch and I had to order it.
    I'm curious, is there some kind of safety mechanism in the start switch that would stop the dryer if it were defective? That's only thing I can think of. Perhaps there's a safety "shut off"?
    I will post on Tuesday when I get the new start switch and install. Please let me know if you have any other thoughts on the Ghost In My Dryer. Thanks a million. I do appreciat you taking the time to help me.
  • swiggins988 Sep 10, 2008
    Good greif. I'm totally frustrated now!
    I ordered, bought and installed the new start switch this afternoon. I press the start button and....nothing. I unplug the dryer and turn the timer (it's ticking) and open the dryer and noticed the light is fluttering. Closed the door, hit the dry button...nothing. Unplug again, reconnect, check the light (full on now and not fluttering) and hit the button and it started.
    Good heat...no noises. I let it run for about 10 minutes and advance the timer to cool down and let it end the cycle. Restart...it's all good again.
    However I'm noticing and "electrical smell". Nothing overly strong, but still, you know it when you smell it, right? I let it run for about 20 minutes and monitor it the whole time waiting for it fizzle--pop-- crackle....nothing like that happens. (Still smell the electical though). I stop the dryer let it cool for about an hour and turn it back on. No problem.
    This time, I stop the dryer, put some clothes in it for weight... hit the start button and bam, it stops as soon as I hit the start button. I unplug, hit the button again and the same thing happens...it stops immediately.
    Of note here is that when it stops, the light on the inside will not come on nor will the timer tick.
    What do you think? Is it the wall socket? When I checked the cord earlier (it was fine) I did notice that one of the prongs was discolored. Is this a sign of something or normal wear from 240 current flow?
    Is this a faulty motor???
    Seriously, I appreciate any and all advice/help.
    I'm running out of clean clothes!!! SOS!
    Just wanted to follow up on this for those who might be interested.
    The problem is solved and the dryer is working like a champ. The culprit? One of the positive wires to the 240v outlet had actually pulled away (wear?) from the connection screw. About 1 inch of the plastic shielding had melted (the smell) and was arcing like a madman. There was actually a small pile of ashes below it. Obviously, this could have been disasterous.
    It took me all of 20 minutes to install a new outlet and for good measure, I replaced the power cord from the dryer to the wall. Life is good and I'm on my way to some clean clothes.
    Many thanks to those who offered up solutions. Oldfixer....you were spot-on my man! Thanks a mill. As a means of troubleshooting, the "fluttering" light in the hamper is really what gave it away to me. HAD to be a power issue at that point.
    I hope this helps someone else who might had a ghost in their dryer! Thanks again.
    Genius:
  • 1,028 Answers
Ck wall plug and dryer cord for discoloration possible bad connection breaking down after heating up ..also possible door switch ..if you have jumped out the white thermal fuse on the blower housing and still have the problem forget fuses or thermostats they only control heating
Posted on Sep 06, 2008
  • 706 Answers
Here are a few ideas of what might be wrong.. based on your description.. You've bypassed the thermal fuse and the dryer worked however once you removed the bypass, did it work after that? based on your symptom.. it appears that one of the auto-ressting 'overtemp snap switches' may be your problem and may be shutting your system down because it is tripping from excessive heat or it is prematurely tripping because it is defective. I've included a website link that shows assembly drawings and parts breakdown for you to examine but I suspect that you have a bad overtemp switch.. ( I assume that you've cleaned out all lint etc from the vent system both inside and outside the dryer) If you haven't... then you may not get adequate air flow and you truly are getting an overtemp condition.. Good luck.. Here is the link http://www.pcappliancerepair.com/model-display.php
Hope this helps !
Posted on Sep 05, 2008
  • Rick Gelin
    Rick Gelin Sep 06, 2008
    The 'bad spot' that was mentioned on your start switch is the contact surface. Over time, the electrical contacts inside the switch may build up carbon on them when they 'make' or break' the electrical circuit and that bulid up becomes resistive. As it becomes resistive, the contacts no longer short together the way they are supposed to when you press this momentary switch and your dryer will not start. I am glad that you are on the right track and should have things operational shortly.. Regards !
Whirlpool dryer bad heating element AGAIN
Hi Warren Fink
Try this solution to your problem
A vent clogged with lint can cause the dryer to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Oct 18, 2012 | Whirlpool Dryers
Dryer has stopped producing heat
I have a Thin Twin manual that will give you an idea of where to start:
THIN TWIN SERVICE MANUAL
Jul 12, 2010 | Whirlpool WHP1500S Electric Dryer
My whirlpool dryer is not heating....has good airflow and everything else seems fine. It's an older model - kingsize.
i would say the heating element has burnt out replace it and you should be right to go
May 13, 2010 | Dryers
Gas dryer heating element won't come on.
There is a controller problem to turn on the gas manifold to produce heat. Since you have it only one week old, let's take the advantage of the warranty to have a new controller unit replaced.
Jan 03, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool dryer wed5200tq0: I have to run cycle
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
****(((Please disregard step three if this is a GAS dryer)))
Aug 21, 2009 | Whirlpool Dryers
Not heating
Hi, Check the thermostats and the fuse. Make sure the 4" vent to the outsideis cleaned. If it is plugged, it will cause elements and thermostats to go bad.
The thermostats and the fuse must have continuity. If they are open, replace them. All these parts are located in back on blower housing and element housing.
I hope this helps. Please let me know if I can assist you further.
Thanks
Vic
May 27, 2009 | Whirlpool LER5636P Electric Dryer
How do you test dryer heating element on GEQ9800LW0
Ok maybe the heating element got old and brittle over time and finally gave up the ghost. But it may not be the element. It could be one of the safety Hi-limits have blown.READ MORE...
Apr 10, 2009 | Whirlpool GEQ9800L Electric Dryer
Whirlpool dryer heat not working
DO YOU HAVE A METER? FIRST CHECK THE DOOR SWITCH,SECOND REMOVE THE BACK PANEL AND CHECK ALL FUSES AND THE HEATING ELEMENT,LET ME KNOW WHAT YOU FIND AND WE CAN GO FROM THERE-MIKE
Feb 24, 2009 | Whirlpool LER5636P Electric Dryer
WHIRLPOOL DRYER STPS SPINNING AFTER A FEW MIN OF USE.
I would check the belt and the motor. The temp gauge has to do with the heating of the system. You can locate both of those at the back of the unit
Feb 11, 2009 | Whirlpool LER5636P Electric Dryer
Now no heat after working for a few weeks with a new heating element.
By the time a dryer has worn out a motor and element, the wire connections are old too. You are going to have to check every connection, especially the push-on type for tightness and corrosion.
Nov 09, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
316 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
