Question about RCA D52W19 52" Rear Projection Television
Symmetry How risky is it for an ameteur to fix picture symmetry ? My picture is not centered and bowed on the sides. I know this reguires changing settings, but have heard it can be easily messed up.
  • hakstone Sep 07, 2008
    more ametuer than that seeing I don't know what that is.
    I try to stay away from projects that could kill me, high voltage, etc...
    I was under the impression that it was code driven.
    Getting into some techie menu and changing values, which could have bad results.
  • 85 Answers
Yes fairly easy to mess up sounds like a pin bow problem have you checked ay circuits
Posted on Sep 06, 2008
  • hiwatt Sep 07, 2008
    yes indeed if a circuit has malfuctioned then all the menu driven adjustments made will be useless i suggest you could see if there was an electrical problem first then if not the menu adjustment may fix. Do you have schmatic RCA puts them on CD rom and you must know the code to get into the service alignments.
Center bow on picture top and bottom with 1" black showing
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba TN55X81 55" Rear Projection...
Borders bowed inward,blurred red,blue, & green
the next time it is not working go into the customer menu with remote and call up the convergence grid and look---there---if convergence is way off and or comes and goes---this set uses 2 Stk-392-570 ic's and it is quite common to see them become intermittant.
Aug 03, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Skewed picture
you need ned convergance chips
Mar 22, 2009 | Mitsubishi VS-60621 60" Rear Projection...
Pioneer SD-532HD5 - Picture Bowed on sides only on 1080I
The problem you are describing is known as a pincushoin problem. I'm a bit surprized that you only see it on the 1080i signal though. I've inquired at my Pioneer contact about this and will update this soon.
Stay tuned...
Dan
Jan 07, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Toshiba CX32G60 1/2" vertical inward bow center of video
change the electrolytic capacitors in the vertical section of tv. you do need a qualified tv tech to do this repair for sure
Nov 30, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
TV Turning on and off, left side of picture is not lining up, bowed in center
Most likely you had a power surge issue that caused the tubes in your crt projection to malfunction. I would recommend having a service call done to find out the issue
Apr 22, 2008 | RCA P61960 61" Rear Projection Television
Picture is suddenly "bowed" and the convergence is askewed at everypoint but center.
the problem is the EW cicuit of the deflection cicuit. this is a component level repair call a tech. the EW or East West correction is apart of the horizontal deflection. IC431 is the pin amp.
Feb 06, 2008 | Akai PT5598HD 55" Rear Projection...
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Sudden discoloration, ghosting, bowed horizontal lines in top and bottom of picture
The convergence ICs probably have a cracked solder joint on the foil side of the circuit board. Re-flowing the the solder would help. I will always replace the convergence ICs when doing this job. The labor remains the same and you will have to pay a few extra bucks for the parts. To fix this yourself, you will need to be able to identify the two convergence ICs, have a basic knowledge of electronics and be able to use a soldering iron. You will also have to do an alignment through the service menu.
Apr 01, 2007 | Samsung HC-P4752W 47" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
94 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
