Question about Toshiba 20AF43 20" TV
No power my tv just went dead on me, could it be the fuse inside the tv gone
    Sergeant:
    Champion:
  • 346 Answers
Check the fuse
Posted on Jan 17, 2009
Tv set went off wont come back on, devo, bluray still work all on same power strip
Please provide a brand and model number so I can attempt to help here---if set total dead with no power suspect fuse that power cord goes to inside the set or the power supply inside the set itself.
Dec 02, 2012 | Televison & Video
I have a Vizio Model P50HDTV10a and it suddenly went dead. Their is no led nothing. Its a year and 4 months old.
Is the tv still under warranty? possibly a blown fuse if you don't get anything at all, you could inspect the power area, but be aware there are dangerous voltages inside.
Jul 22, 2008 | Televison & Video
I have a hitachi 42hdt79 and yesterday the power just went off. the power button on the tv does not power it on nor does the remote. just dead.
The internal fuse, if you are lucky, may have gone. It is situated before the on off switch and mains filtering circuit board.
Jan 01, 2011 | Hitachi 42HDT79 42 in. Plasma Television
Heard a pop then screen went blank. Now TV wont turn on.
Sounds like your fuse.
If not the fuse in your plug, then the internal fuse in the TV. to get too this you need to open the TV by taking off the back plastic panel and look at the fuse.
the fuse is the glass tube on the board, will no doubt be near where the power cord connects to the TV. and are easy to replace with another fuse. you will know soon as you open it if its blown as the little glass tube will be blackened or the little wire inside the tube will be missing or severed.
Fuses in TVs are actually designed to blow over time with ware (usually to last a bit longer then the warranty time frame) so after the cover has ended the TV can go in for repair work at extra cost. Its a little known fact.
Jan 02, 2010 | Sony KDF-E42A10 42 in. LCD Television
My tv went dead during a lightning storm. I heard
The sound could have come from one of your power capacitors. You could tell if one of them is no longer operational by looking at them; they will be burned, or blistered, or will be bulging. If this is a CRT type of TV ensure that you only look inside if you are fully aware of how to deal with the lethal voltages that are stored on the inside of the unit.
Aug 09, 2009 | JVC AV-32850 TV
Philips 47PFL7422 Flat Screen no power
Check the main fuse
If that is ok look for puffed up capacitors on the power supply
Check the 1000ufd @ 35v change them to 1000uf @ 50volts
Good luck
Feb 08, 2009 | Philips 47PFL7422D/37 Television
My TV is completely dead, no power (F25645)
I would suggest buying a new power supply from ebay or other places.
Dec 31, 2008 | RCA F25645 25" TV
Tv went dead will not turn on
take the back panel at the bottom of the tv off and inside there there is a fuse most likely the problem, mine just did the same thing yesterday
Aug 03, 2008 | RCA P61930BL 61" Rear Projection...
Went dead after power outage all other components ok
Hi there!
Power surges are common after the electricity is re-established. The reason some and not all are damaged is because the closest point or the weakest supply is normally taken out first. A job for a repair technician if your are not familiar with the inside of a TV. May just be a fuse if you are lucky. If the led comes on in standby only it is normally more serious. Good Luck,JUS004
Dec 17, 2007 | Sanyo DS35510 35" TV
Toshiba 20AF43 20" TV Logo
61 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
