Question about Dell Inspiron 1100 Notebook
Dell Inspiron Labtop 1100
I have a new AC adapter and power cord, and a new battery and my labtop will not power up. Do you have any suggestions
  • Coss May 11, 2010
    What does it do when you try to power on?
    Any lights? and beeps?
    Did you change the adapter and battery because of this problem? Or because it was just time to replace them? (like the battery wouldn't hold a charge)...
    Genius:
  • 2,028 Answers
This is generally due to a failed component in the power management system on the motherboard. I suggest that you take it to a service center in your area to have the exact problem area traced. Power issues dealing with the PM system can be created by several different components, some are replaceable, and some require motherboard replacement to fix, so, this will be an issue that will be near impossible to diagnose on line.
Posted on Sep 05, 2008
My laptop got error 2000-0334 google and every thing is freeze and my keyboard not work properly
Hi there!
Error 2000-0334 is related to an error with the video. I suggest you uninstall and reinstall the video adapter.
Hope this helps.
Apr 28, 2011 | Dell Inspiron 1525 Notebook
I Dell Labtop is not turning on. 3 lights blink continuously
do you still have your battery working? if not, you may have a problem with the adapter. could be a partial contact from the main adapter or at the charging port on your laptop. use a tester and check for continuity on the adapter cable and also check the power output going into the laptop.
Jul 22, 2010 | Dell Inspiron B130 Notebook
Dell Inspiron 1100 won't power up with battery & power pack both conected
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Nov 09, 2009 | Dell Inspiron 1100 Notebook
Unable to boot dell inspiron 1525 labtop
get a new battery and try that but check your power supply before you plug it in. Most laptops will work directly off power supply even with no battery present. If these solutions don't work for you then you need professional technicians help or a decent bin.
Aug 02, 2009 | Dell Inspiron 1525 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
No power
The laptop should power up with the AC Adapter plugged in, if it works, and you want to be mobile, buy the battery pack for it. Battery's sell for around $75 in some places on-line.
Have a nice day!
Dec 22, 2008 | Fujitsu Siemens AMILO Pro V1000 Notebook
Labtop not charging
Try removing the battery and see if the laptop powers on. If it still doesn’t power on then either the motherboard is defective or the AC adaptor may have a broken wire in the cable.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 03, 2008 | Dell Inspiron 6000 Notebook
Compaq Presario needed a new battery was installed labtop will not charge up!
When you install a new battery and remove a battery always make sure the laptop is completely shut off and have the power cord removed so that you avoid any possible power surge.
Batteries generally don't last much longer than a year and I have found removing the power cord or battery when it is off to be a good practice.
Before you charge a battery make sure it is run most all the way down. Recharging a battery when it is not run down can give it a memory and you may only be able to charge it up to the point you started charging it.
Anyway, if the computer won't charge a new battery then you could have a bad motherboard. To be sure try another battery.
Sep 09, 2008 | Compaq Presario Notebook
Dell Latitude D600 new battery won,t charge
the charger in the laptop is not functioning. pc will need repaired
Dec 28, 2007 | Dell Latitude D600 Notebook
Power Problem
A very common problem with dell laptop's are the "batterys" I suggest calling dell and order a new battery for your labtop.
or
It may be that your psu "power supply unit" may be bad as well.
I hope this solves your problem
Nov 12, 2007 | Dell Inspiron 9300 Notebook
Dell Inspiron 1100 Notebook Logo
82 people viewed this question
Alun Cox
