Question about Sanyo DS24425 24" TV
Sanyo DP19648 my tv/pc has no sound when in pc mode. all tv sounds work. called Sanyo assistance number, but support said i should talk to a pc person??? 800 number states, We can Help!!!! i'm not a techie, but want to hear speech on you tube. thanks so much!
PC connections do not transmit sound unless the system is equipped with the newer sound-format inclusive video cards and running HDMI.
You will need to use the computers speakers..if you have any.
Posted on Oct 27, 2008
Have lost picture with power outtage, sound still perfect, dvd's still play
Sounds like tuner fault. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 29, 2014 | Sanyo DP19648 19 in. LCD TV
HAS GREAT PICTURE....BUT NO SOUND
LOL On my DP19638 I have good sound and no picture.
Sadly, no one works on these any more (as the hourly rate quickly exceeds the replacement value). And, getting parts is a "female dog" anyhow. If warranty is up, hit the stores for a new set. I like Vizio and Samsung myself.
Jun 16, 2014 | Sanyo DP19648 19 in. LCD TV
My "sharp" tv green power light blinks but has no sound or picture
Likely a power board issue. Check that the caps on this board are blown, and replace with the exact parts. This can be a $10 fix.
This tv will not turn on at all no sound and no picture
What elese is it doing are there anylights on or flashing?
Dec 19, 2011 | Sanyo DP19648 19 in. LCD TV
I have sound and picture on most channels, but some I only have picture and not sound.
Check your audio settings you are in SAP which means Special Aided programing, usually used for spanish speaking programing.
Aug 24, 2011 | Sanyo DP19648 19 in. LCD TV
I have sound but no picture
Always unplug the TV before you start....:)
On the Sanyo DP19648 has sound and NO picture.Take the TV apart locate the power supply board on left.Remove the plugs for the lights etc.take out the screws carefully unclip the power supply.Turn it over find the F1 tiny chip fuse locaed off center to the left with metal sheild away from you.I used a 2 amp (bc fuse unknown)I broke an agc style standard fuse and used the wire that was inside the fuse and also replaced the slightly bulged 220uf at 25volt cap which is located top side not far from burnt fuse.I suspect the fuse blew bc of the small orange bulged cap.
From Ed the tech....good luck
Jun 22, 2010 | Sanyo DP19648 19 in. LCD TV
We have a Sanyo DP19649 and headphones dont work
Turn speakers off in sound menu if available. Then turn up volume to hear in headphones.
May 06, 2010 | Sanyo DP19648 19 in. LCD TV
Problem using Audio 3 sound inputs for HDMI video
Normally this problem is simply a matter of selecting the correct default audio playback device in the Windows control panel (sound option).
Check the Playback tab and set the default device to either DVI or HDMI.
http://pcaudiohelp.com/fix-hmdi-sound-to-tv
Feb 25, 2010 | Sanyo DP50747 50 in. Plasma TV
No sound output on Sanyo DP19648 TV
Hello, how are you connecting your tv to your regular tv? When you say regular Tv do you mean your cable or what? Are you using hdmi or coaxial cable or how do you connect whatever is working to your tv? Have you tried using that method of connecting with the non-working devices? If so what were your results thanks. the greek
Jun 06, 2009 | Sanyo DP19648 19 in. LCD TV
How do I get the sound back on?
I would return it to where you purchased it, if by UPS then take it to the closest Authorized Sanyo Service Center
Feb 18, 2009 | Sanyo Televison & Video
Sanyo DS24425 24" TV Logo
244 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
