Question about Zenith DVT412 System
Sound Not all but most dvd's has the sound very low, yet background noise is loud. If I hit the sound button, can change to spanish, french, comentator of movie making, etc the sound is perfect, when put on english, goes back to low talking, loud background. Some movies have an ENG1 and ENG2 when push the sound button, those that show that I can switch to ENG2 aeverything is fine. There does seem to be a bypass mode that won't change as well. Thank you for any help.
  • melinajanay Sep 24, 2008
    i have the same exact problem,out of nowhere, in aux (the tv) sounds fine and music cd's and even the previews on dvd's sound normal until the movie starts and the talking is completley muffeled but music/background is loud....did you ever get any responses or have any ideas??
  • pgrass24 Feb 07, 2009
    I have the same problem. It seems the center channel is muffled, like sounds coming from a tin can. Everything else is fine.
    Not sure what to do. Is it possible to set that channel thru the TV?
To everyone having sound trouble... there is a solution! First make sure your TV is OFF. Unplugg the 2 main cables going into the DVT 412 for 30 seconds. Then re-plugg them. Press down for a few seconds on all the BLACK tabs connecting the sound wires and release. Without a disc in the player... and the TV still OFF, turn the power on and immediatley hold the down the STOP button on the DVT412 for 5-10 seconds. Your picture, vocal and backround sound will return to normal. Feel free to make changes to the sound now! Happy tuning... GO STEELERS! LOL!
Posted on Oct 21, 2008
For some reason, I get audio for the visually impaired when i play a DVD. The original sound of the DVD plays but an additional narrative (describing each scene) plays as well. The DVD is a recent...
Generally, remote controls for DVD systems have a button labeled "Audio". This button changes which audio track you will hear during the movie. Common tracks include English, French, Spanish, Commentaries, and occasionally Audio for the Hearing Impaired.
It seems odd for the latter audio track to be default, but clicking the Audio button until you have the plain English track should work. I would consult the manual if you have it on hand to see if your system is capable of remembering which track to start on.
Hope this helps.
Jun 13, 2011 | Protron PDS-2315 Theater System
No English language on DVD 's
Bought a new unit. The old unit was a surround sound system in which the previous owner removed the speakers. I wasn't aware of the problem but found out that it would not allow it to play on Dolby 5.1...It would only play DVD's on channel 2, therefore no english etc. Thanks for your help!!!
Feb 10, 2010 | Koss KS4110 DVD Player
The background noise in a movie on Tv is so loud I can hardly hear the conversations. I have tried the audio menu. Normal, Wide, Low ..They all sound the same.
GO again into the customer menu and look for something that says Hall, Surround etc--I have seen this before--usually it is a setting that creates a problem where the background sounds are so loud you cannot hear the people talking......go thru every section of the menu--I be you will find this is your problem.
Let me know what you find--I am here to help people. I do not think you have a circuit problem--only some thing in the menu has been set to the wrong place.
If this has helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 21, 2009 | Toshiba 42H81 42" Rear Projection...
DVD movie background sound too loud to comfortably watch!
on some dvd players and surround sound systems have a thing called DRC (dynamic range compression) you can us that and it will help it a little. i have come across the same problem but im after a digital on to run with plex or vlc on a mac. im having to route it through protools to use a compressor on there, but thats eating my resources.
Aug 24, 2009 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Movies play background noise but no speech. wont allow you to reset factory settings.
This usually happens when you switch between 5.1 or 2.1 there is usually a button or switch on the front of the unit that allows you to cycle through the various speaker setups.
It also happens a lot with downloaded movies where the sound track has been modified to save download bandwidth or if a format change was made eg. dvd to divx
Aug 10, 2009 | Televison & Video
Display is stuck in Spanish.
on your remote for your dvd player hit your menu button then hit options it should have an option to change languages.
Nov 15, 2008 | TruTech TT320
Emerson dvd player - background sound lauder than dialogue
Greetings surfjax,
If you will allow me to make an assumption, you do not have a 5.1 surround system connected to your DVD player. This is a common experience with users of a standard TV or stereo receiver if a movie is being presented in 5.1.
In a surround sound system the center channel speaker provides almost all the vocal tracks while the side channels will provide music and some background noises. You'll still be able to hear the voices in your side speakers, but it will be muted and over powered by music or sound effects.
Some DVD players allow you to "Downmix" the surround signal to stereo. You might want to look around your sound setup on the DVD player or check your owners manual.
Hope this helps.
Jon
Go Ahead. Use Us.
May 22, 2008 | Emerson EWD7003 DVD Player
Subtitles...
This could be a problem with a particular DVD media and not the player. The movie (or the program on the DVD) is recorder with default English subtitle. Have you checked it with any other movie DVD to see if it is the same behavior?
Aug 31, 2007 | Samsung HTDM150 System
Dialogue vs. background music and sound
The on-screen menu appears only when the selected source is DVD or VCD on the DVD/VCD/CD player and the disc is in the slot and NOT PLAYING. On the remote control ONLY: 1. Press CHOICE (it should work now) LANGUAGE menu appears. 2 Press Cursor to move to the menu you want? which is AUDIO Selected item changes its color to green. THEN: 1. Display EXPERT SPEAKER SETTING menu. 2. Press Cursor to select ?TEST TONE,? then press ENTER. ?TEST TONE? changes its color to green and test tone comes out of in the following sequence?left front speaker, center speaker, right front speaker, right rear speaker, and left rear speaker. ? Test tone is output only when the tray loaded with a DVD is selected, but not playing. 3. Press Cursor to move to ?C.SPK? LEVEL? or ?R.SPK?LEVEL,? then press ENTER. 4. Press Cursor to adjust the output level, then press ENTER. ? You can adjust the output level from ??6 dB? to ?+6 dB.? 5. Repeat steps 3 and 4 to adjust the other speaker output level. 6. Press Cursor to select ?TEST TONE,? then press ENTER. Test tone stops. 7. When finished, press Cursor to move to ?EXIT,? then press ENTER. EXPERT SPEAKER SETTING menu disappears. I hope this helps you, please let us know. Best regards, nightdiver
Jun 13, 2006 | JVC MX-DVA9 Shelf System
Zenith DVT412 System Logo
258 people viewed this question
Top Zenith Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Greg Cann
Greg Cann
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
