Belt keeps coming off - Washing Machines
    Novelist:
  • 166 Answers
Give me a good rating before you sign off! I just gave you info that's GOLD!! About PUSH-PULL!
Posted on Sep 05, 2008
  • N Golan
    N Golan Sep 05, 2008
    The belt must need to be replaced. It must be worn or stretched!!!
Hotpoint WF215 my belt keeps coming off, i've just replaced an old one and this one keeps coming off. its the right size so what am i doing wrong? Any help please.
Posted on Oct 06, 2008
Tensioner belt keeps slipping off front pully
Everett, Do you mean drive belt keeps coming off front pulley?
Possible causes, accumulated dirt/debris above deck or on trans axle, damage,stretched,wrong size belt, belt tensioner seized/missing spring if equipped, belt retainers/guides/keepers damaged /missing/ adjusted to far from pulley, damaged/worn pulleys, loose engine, belt way out of alignment,etc.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What Are the Causes of Belt Coming Off Riding Mower
Drive belt keeps coming off when shift into reverse
Need help with mower deck belt keeps coming off Craftsman LT2000...
belt keeps popping off
Jul 20, 2016 | Garden
2002 Pontiac Bonneville supercharger. Why does one of the belts keep coming off?
Check all the pulleys on that belt. One is bad. Oil doesn't help, but shouldn't be the problem of the belt coming off.
May 02, 2015 | Pontiac Cars & Trucks
Hi, got a new belt for my candy CM1 166/1 washing machine but it keeps coming off , its the correct belt , the pulley wheel does not have any play and hardly any on motor wheel either ,belt keeps going...
If the belt is coming off the pullies my be out of line .you need to put a straight edge across the two pullies to make sure they are level . And check there's enough tension on the belt .
Nov 07, 2014 | Washing Machines
New belt keeps coming off toro ride on
First of all is it the right belt and is it installed properly.
Do all the pulleys line up properly?
Are the belt guides in place
Sep 24, 2014 | Toro Garden
Check th eidler pulley for the belt and make sure the belt is runnin in across all the pulleys in a straight line.
Jun 12, 2013 | 2000 Chrysler 300M
The belt on my hotpoint aquarious wma33 keeps coming off
Belt is not adjusted tight enough when being fitted, if no adjustment can be made by moving the motor then the belt may be stretched and will need replacing, the drum bearings may be faulty and causing the pulley to be out of alignment, water may be getting on to belt causing it to slip off.
Dec 29, 2012 | Hotpoint Washing Machines
The drum belt keeps coming off
Whenever you install a new belt, it is also a good idea to replace the idler pulley.
Nov 24, 2009 | Cars & Trucks
The belt keeps coming off
A belt will come off for several reasons.:
Wrong size or stretched... should be changed ever 3-6 months.
Misaligned pulley on brush or idler pulley on 2 belt unit
Misaligned motor.. this is rare
Put in a fresh matching genuine belt and keep a spare handy. Belts stretch and slip long before they break
Nov 06, 2009 | Panasonic Vacuums
The belt keeps coming off the fan
the only reason for the belt coming off the pulley is the something in the belt path is off aligment.
put the belt back on and chek the path where the belt pass. water pump, alternator, AC compressor, Power steeling unit, etc....... or even the pulley tensioner itself.
chance are there is a belt in the wrong pully slot.
Nov 10, 2008 | 1996 Jeep Grand Cherokee
Belt keeps coming off the pulley
I suggest you check your drum bearings, belt will only come off if misaligned.
Mar 09, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
243 people viewed this question
Top Washing Machines Experts
