Question about HP Computers & Internet
System keeps shutting off. Power will show available, and then not available. Resoldered the power jack on the motherboard. Problem went away, and then came back.
  • Schyre Sep 05, 2008
    It is an HP laptop. Pavilion zx5295. The system will run from the battery, however the power cord will not charge the battery while it is in use. The power cord will not work without the battery, and even at that only sometimes.
  • 236 Answers
I ran into a problem just like this a few months ago. Try installing the latest BIOS drivers from HP's website. For some reason, that fixed it for me. Also, from the BIOS or HP battery optimizer software, try running some tests on the battery to see if there is a problem with it.
Hope that helps....
Posted on Sep 06, 2008
My laptop shut off so I bought a new battery & it still will not work even plugged in
First check your power adapter to make sure it outputting the correct voltage....or working at all minus a light on the adapter.
If you are sure that the adapter is okay, then next palce to check is where the adapter plugs into the computer. Often, the jack on the computer will break its solder joint causing the laptop to not charge or power on. You can have the jack resoldered or replace the motherboard to fix it.
Worse case scenario, motherboard has died and needs to be replaced.
Jun 17, 2010 | HP G60-235DX Notebook
Will not charge battery,have bought new battery, continues to go into not charging mode. Gateway model MA7 charger output 19.27v confirmed
If you are not getting any thing when just the charger is plugged in and either no battery or the battery is dead, but the system will run on a fully charged battery. There may be a problem with the motherboard that a DC jack replacement will not help.. some of the traces sandwiched in the mid-plain on the mother board might have corroded away and need to be bypassed .. check my blog for pictures on how this can be done. http://cegeekbook.blogspot.com/2010/07/gateway-ma7-mx6930-no-power-will-not.html
May 11, 2010 | Gateway Computers & Internet
Toshiba laptop power failure after yanking power cord
Hello.
Sounds like you already determined it, but if you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
Hope this helps.
May 09, 2010 | Toshiba Satellite Pro P300 Notebook
IBM thinkpad does not power up. Nephew watching
Could be the power button shorted, Does it operate when not plugged in?
The plug jack on the back where the pc would be plugged in, sometimes loosens and needs to be resoldered too. If the pc works when not plugged in, but does work on just the battery.
If no power on during either, it is probably the power on switch gone. Any lights whatsoever showing?
Jul 15, 2009 | IBM ThinkPad R50e Notebook
EasyNote GN45 - Dead!
Likely your power plug inside the laptop is corroded around the positive terminal connecting to the motherboard, it will need to be resoldered or replaced. Repair places will charge a couple hundred dollars for this simple job often requiring no parts, good luck.
Jun 16, 2009 | Computers & Internet
Emachine Turns Off
This is the best way to tell. If your system is shutting down on you by behaving like your shutting it down thru windows then it could be a spyware, virus trojan issue going on. If thats the case then run your virus program and see what it finds and remove it. If your laptop is shutting down on you where everything turns off right away with no lights, kind of like a power outage then go ahead and remove the battery and only use the ac adapter and see if that solves the problem. If it does solve the problem then you know its your battery that is the culprit. If your only using the ac adapter and the machine shuts off on you like a power outage with no lights then you know its a problem with the motherboard. With just the ac adapter plugged in, wiggle the cord near where it plugs into the laptop and if it shuts off on you like a power outage then you know its a loose DC Jack and it needs to be resoldered back into place. Hope all this helps.
Jun 12, 2009 | Computers & Internet
The AC pwoer keeps on and off (most time off) all the time, however, it still can recharge the battery
This is not a good sign!
If all physical connection seems fine, it could mean something is wrong on the power modules of the motherboard! Please try another power adapter to see if it's the power adaptor's fault. If not, get it into lenovo service centre for check-up, as this could damage your laptop motherboard's power modules permanently!
This happened exactly what I had on my good old ASUS laptop, I ended up replace the motherboard. Pay little money to get it serviced before you have to replace the whole motherboard!
May 14, 2009 | IBM ThinkPad T42 Notebook
Keeps powering on and off.
Keep in mind since you cleaned it out, only have the AC adaptor hooked up to rule the battery out. If the laptop stays on with only the ac adaptor hooked up and doesn't shut off then you know that the battery is faulty. If it still shuts off even with just the ac adaptor hooked up then it could be the ac adaptor.
Also check one more thing, with only the ac adaptor hooked up, wiggle the cord where it plugs into the laptop and see if the laptop shuts off, if it does then the dc jack on the motherboard is loose and needs to be resoldered back into place so it stays put.
May 13, 2009 | Dell Computers & Internet
1150 won turns on then shuts off
Intermittent power on and off indicates a power supply failure. Check your power supply to make sure if it is working fine.
Oct 06, 2008 | Dell Inspiron 1150 Notebook
Power problem PAVILION zv5000 (AMD) sn:CND5190R9W.
Yes, I have found that the solder joints on connector terminal on the motherboard become unstable/dry/cracked after a period of time, t seems they are not strong enough to cope with constant movement of plug
Motherboard can be removed and joints on base of power adaptor connector on MB resoldered, once again restoring connectivity from power adaptor plug to mainboard.
Use a moderate temp soldering iron.and thin solder and redo solder joints on power adaptor socket.
Dec 04, 2007 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
