Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
WIreless Connections? I am not sure where to find the "wireless connections" field. I "diagnose connections problems", then "view available wireless networks", and when my network is shown, the error in the previous subject line is shown. I then tried diagnosing this issue and moving on to "view wireless security settings to verify that correct security type is selected". The wireless network settings show that the security type is open, and that is what is showing here. Help?
  • hlsimmons Sep 27, 2008
    cant connect a lap top to my wireless router
    Genius:
  • 1,847 Answers
Check this link...
http://www.whizblaze.com/network/vista.htm
Posted on Sep 20, 2008
My laptop is lenovo b460. I have the wireless switch on and it is showing that wireless connections are available. But it does not show the available networks. Please suggest some solution.
There are two ways to view available wireless connections.
1. Thru windows: press Start>Connect to>enter.
2. Lenovo has proprietary software installed called access connections. If this is enabled it should be accessible thru: Start>All Programs>Access Connections. If not enabled it also should be available thru the Control Panel.
Jun 08, 2011 | Computers & Internet
Tip
How to connect your wireless computer to the wireless network ?
Connecting your wireless computer to the wireless network:
Make sure the wireless switch is turned on in the laptop, now look for the available wireless Networks in range, select your network name, enter the security key and get connected. You may also follow the navigation below according to your Operating System
WINDOWS XP: Start > Control Panel > Network and Internet Connections(Network connections) > Right Click Wireless Network Connection icon > Click on View Available Wireless Network
WINDOWS VISTA: Start > Control Panel > Network and Internet (Network and Sharing Center) > On your left hand side click on Manage Network connections > Right Click on Wireless Network Connection icon > Click on Connect/disconnect
WINDOWS 7: Start > Control Panel > Network and Internet (Network and Sharing Center) > On your left hand side Click on Change Adapter Settings > Right Click on Wireless Network Connection icon > Click on Connect/disconnect
MAC OSX: Select airport icon from desktop, turn on Airport, you will be able to view the available networks in range. Select your network name enter key and get connected.
You may also click on Apple logo > System preferences > Airport > select network name
You will be able to see the Network name (SSID) which you gave in the Router, try to connect to this it will ask for password type it and click on Connect. You will get connected wirelessly and able to go online.
on May 19, 2010 | Computers & Internet
Net book will not connect to internet through WiFi. With cable is ok
Here are some suggestions that may resolve your problem....
1. if another computer is connecting OK through WiFi, then the problem is likely with the N150
2. if nothing else is connected through WiFi, then you need to check both N150 and router
3. on N150 without cable, click start and click Control Panel then double click Network Connections
4. Network Connections should show Wireless Network Connection and Local Area Connection
5. if Wireless Network is missing, click back and double-click Wireless Network Setup Wizard
6. if wizard done but Wireless Network Connection is Not connected in Network Connections window
7. in Network Tasks in left sidebar of Network Connections, click View available wireless networks
8. in Wireless Network Connection window, click on Refresh network list in Network Tasks sidebar
9. if No wireless networks were found.... then Make sure the wireless switch on N150 is on
10. with the N150 wireless adapter now enabled, click on Refresh network list
11. if SSID for your router's wireless is listed but not high-lighted, click on it to select the SSID
12. click the connect button, if security-enabled wireless network, a pop-up appears for key input
13. click the connect button after entering and confirming key inputs
14. if after step 10 the SSID for your router is NOT listed, you will need to log into the router
15. connect the N150 to the router using the ethernet cable then open Internet Explorer
16. in IE's address field, type the router's IP address - it is in the form of 192.168.x.x
17. if it is not known, open Network Connections window (step 3) and right-click Local Area Connection
18. in the pop-up, click on status
19. in the Local Area Connection Status window, click on the Support tab
20. the Default Gateway has the router's IP address
21. after entry of IP address, IE presents a router login window for userid and password entry
22. unless changed, the router userid and password defaults are given in the router's manual
23. on the first router screen (usually Setup), click on the Wireless tab
24. if Wireless Network Mode is Disabled, click on v for pull-down then click on appropriate mode
25. if SSID is blank, enter a Wireless Network Name then click Wireless SSID Broadcast enable
26. click Save Settings then click on Wireless Security tab in the Wireless window to set WEP/WPA
27. see your router's manual for details on how to setup WEP or WPA mode and its key
28. if you don't want wireless security (OPEN), then set Security Mode to Disabled (default)
29. if any changes, click on Save Settings then click on x at top right corner of IE to close it
30. disconnect the ethernet cable and right-click the Toolbar's Wireless Network Connection icon
31. if the icon (a single screen with ))) beside it) has a little red x, then on the pop-up...
32. click View Available Wireless Networks then in Network Tasks sidebar click Refresh Network List
33. continue with connecting to the wireless network at step 11....
Feb 21, 2011 | Samsung N150 (36725723009) Netbook
Troubleshooting wireless home network using windows xp
To Configure a Wireless Connection in Windows XP, Follow the Instructions Outlined Below.
  1. Click the Start button, click Network Connections, and choose Show all Connctions.
  2. Click the Wireless Network Connection icon with your right mouse button, then choose View Available Wireless Networks.
  3. Choose the name of the 2Wire access point from the Available networks list.
  4. In the Network key field, type the hexadecimal key to access the wireless network.
    Note: The hexadecimal key and wireless network name should already be set up on the 2Wire device. Use the key that you set up on the 2Wire device.
  5. In the Confirm network key field, type the hexadecimal key to access the wireless network again for confirmation.
  6. Click the Connect button.
Apr 15, 2010 | HP Pavilion m7680n PC Desktop
Greetings, trying to figure out why my toshiba 5205-S504 cannot access local wifi. Some sort of internal wifi device installed and was working until I reverted back to factory conditions and dummy me...
Use the config-Free software to diagnose your connection. Click Start=>All programs=>Toshiba=>Networking=>Config free. It will show you what is wrong and will allow you to enable the wireless if it is not enabled. If for some reason you cannot find ConfigFree you can do the "repair" yourself.
On your Satellite there should be a switch to physically turn the wireless adapter. The wireless adapter must be turned on: its Led should be lit. There is the image of an antenna near the LED.
This done, you should use the start button ( I am describing the procedure for Windows XP Pro) and click the Connect To submenu =>Show all connections.
In the list of available connections, point to the Wireless adapter and make sure it is software activated. Point with mouse cursor, and right click the icon. Select Enable.
If Windows is managing the wireless connections, you should use it to detect the available wireless networks. To do so, right click the wireless connection and select View Wireless networks. It will show you all the available ones. Select the one you have authorized access to and click connect. You will be prompted to enter a key if necessary and you take it from there.
If you perform the foregoing step and Windows is not the one managing your connections, then you must use the Vaio connection manager (could be Intel PROSet wireless) or some other proprietary one.
Good luck.
Dec 30, 2009 | Toshiba Satellite 5205-S504 PC Notebook
Wired internet working through netgear... wireless access denied
You must determine the wireless security of your router;
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
a. Click on the Wireless Settings under Setup.
b. take note of the SSID
c. if your using WEP...the network key would be on the key 1.
d. If WPA-PSK TKIP is in use just type in a new key with a minimum of 8 characters on the passphrase box. Please remember it.
Connecting Through Wireless Zero Configuration (Windows XP SP1 and SP2)
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then, click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
Apr 06, 2009 | NetGear WGR614 54Mbps Wireless Router...
Can't connect to my router anymore (WEP encrypted).
Hi deray953,
First we need to remove the previous profile in your wireless network. I believe you know the SSID for wireless connection using WEP security. You can check this by going to;
Using Windows XP SP2/3
1. "Control Panel" > Switch control panel to classic view ( look at the upper left side ). > Double click "Network Connections" > Right click "Wireless Network Connections" > choose "Properties"> Click the Tab "Wireless Networks" ( middle tab) > go to the list of profiles and remove the Wireless name or SSID for your home connections. > click OK and Close the properties of wireless.
To reconnect again, you need to know your WEP key or network key for wireless connections if not, you can do this procedure...
1.Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
d. Click on the Wireless Settings under Setup.
e. take note of the KEY 1 ...that is your WEP key..take note of it.
Connecting to a Wireless Network on Windows Vista:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network's name or SSID and click Connect.
d. It will ask you for a network key. Type in your wireless network key on the field provided. Then, click on Connect.
Apr 02, 2009 | NetGear RangeMax WPN824 Router
Can't connect to home hub
first, check if your networ adapter is installed properly by opening your device manager. if it is there and does not appear with any marks or splats like a question mark or exclamation point, you can close that window, check if wireless zero config (if you have WinXP) or wireless auto config (if you have WinVista) in Start> Run> Services.msc (XP) or Start>click on search field and type in Services.msc and right-click on that item and choose either Start OR Restart. close that window . (on WinXP) open network connections in control panel, right click on Wireless Network Connections>Properties>click on Wireless Connections tab, place check mark on Use Windows to Configure Wireless, click on OK, that will close that window. then right-click again on the Wireless Network Connection and choose View Available Wireless Network, your network should be there now. on vista, just simply look for the "two computer" icons in the system tray at the bottom right near the time, right-click on that and choose Connect to a Network, it should be able to find your network from there.
Aug 21, 2008 | Computers & Internet
Netgear WGX102
1. Check the physical connections.
a. Connect the XE102 using an Ethernet cable into the modem or router.
b. Plug-in the XE102 and WGX102 into the power outlet.
2. Reset WGX102 device.
a. Please push the reset button in the WGX102 using paper clip and release after 30 seconds.
b. Unplug the WGX102 for 10 seconds and then plug it back in.
3. Set Static IP address on the wireless laptop
a. Please click on Start, select Settings and then Control Panel.
b. Double click on the Network Connections icon.
c. Right click on Wireless Network Connection and click on Properties.
d. Scroll down to Internet Protocol TCP/IP and click on Properties.
e. Change the option Obtain an IP address automatically to Use the following IP address and enter the following:
IP: 192.168.0.5
Subnet Mask: 255.255.255.0
f. Click on Ok button and close Local Area Connection properties.
4. Connect wireless laptop to the WGX102.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select NETGEAR and click on Connect
f. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select NETGEAR and click on Connect.
5. Access WGX102 Web-based utility.
a. Please open any web browser like Internet Explorer or Mozilla Firefox.
b. Connect to the router by typing http://192.168.0.101 in the address field and click Enter or Return key.
c. For security reasons, the WGX102 has its own user name and password. When prompted, enter admin for the user name and password for the password, both in lower case letters.
6. Change WGX102 Mode
a. Click on AP/router mode under setup.
b. Select the option Router (access point + NAT router) under operating mode then click Apply.
7. Configure wireless settings.
b. Change the SSID to any unique name. Make sure that Broadcast name is Enabled.
c. Mode set it to G and B and Channel should be 6.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter 10 digit numbers.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
8. Set the wireless laptop back to dynamic IP address.
e. Check the option Obtain an IP address automatically and Obtain DNS address automatically.
9. Connect wireless computer to the router.
Connect wireless using Windows XP Service Pack 1.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
Connect wireless using Windows XP Service Pack 2.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
From the above configuration please check if you are now able to go online wireless using the WGX102.
Mar 30, 2008 | NetGear WL |WGX102 RANGE EXTEND R Bridge
Cannot configure WGXB102 with router
pl. try the following
1. do hard rest of your router i.e at the back of your router u'll see a tiny reset hole in that whole put in a ball pt. pen and press the hole hard for 10 sec. and some lights on the router should start to flash then take out the power cable for 30 secs and then again plug in the power cable and try opening the router page and do'nt add www to the address.
Jan 23, 2008 | NetGear WGXB102 Wireless Range Extender...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
