Question about Kenmore 24032\24036 Top Load Washer
Ordor from washing machine
I have an ordor coming from my washer. How is the best way to clean it. It is a Kenmore 90 series, heavy duty washer, top load.
    Problem Solver:
  • 12 Answers
I fixed the bad odor problem once and for all!
This problem is caused by mold and mildew growing in a large ventilation hose that runs from the top of the wash drum to a large vent hole in back of the machine.
To correct this problem you can buy a kit from or do the cheap fix like I did.
Step One: Find the vent grille on the upper left corner of the machine. Remove the machine top, only a couple small screws hold it on.
Step two: Remove the hose clamps that hold the hose to the drum and grille then snap out the plastic grille.
Step three: The grille is convex so I used a belt sander to make it flat then I took a computer case fan that was the same size as the grill and hot glued it to the plastic grille. I wired it to an old 12 Volt phone charger (12V 500 Ma) and made it blow air INTO the vent.
Step Four: Put everything back together and enjoy a stink free washer because the mold can no longer grow in that hose.
Note! You must bleach, clean and scrub that crud out of that large vent hose and it is some kind of gross! If you're allergic to mold please wear respiratory protection. My fan has been blowing air into the washer 24/7 for six months and I have seen those case fans run non stop for years. It it dies just snap the hot glue beads and put another fan on it. Total cost for the entire fix, about $10.00
Posted on May 08, 2014
  • 166 Answers
Ngafm at your service,
If you run the washer once a week without clothes and use 1/4 cup of bleach with hot water it will more than likely stop the smell problem!
But after you do the be sure to do white clothes next so no bleach
stains a spot on an article of clothing as happened to me!
AND , leave the washer door open when not in use!
If the smell persists, you may want to call service to make sure all the water is being pumped out and there is no wet lint standing in the pump or drain system of the washer!
Some loaders may have this smell problem on occasion if water is left standing inside some the washer some where!
Posted on Sep 05, 2008
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series washing machine, heavy duty, super capascity plus,quiet pak2 3spd motor w/5spd combo, when in spin mode, it smells like melted crayons
If drain hose is connected to a standpipe check that it's inserted no more than 4". You may be getting a syphoning situation that is allowing gray water to contaminate clean clothes.
Jan 06, 2013 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Bad ordor
you need to remoc=ve the lid then the control panel and then remove the front panel and you can get to the inside of the machine
Jun 05, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer has ordor
run a cycle with a heathy amount of bleach on hot. Odor is usually due to bacteria or somehting left behind. Is there any filter that can be cleaned??
Jan 16, 2010 | Kenmore HE2 Plus Front Load Washer
I have an old Kenmore Heavy Duty 70 series washer.
its a filter inside the water hose thats still blocked or the relay inside the washer for the cold feed is not opening up fully it could just need a clean or maybe a new one fitted
Nov 05, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Washer works but smells like its burning.kenmore 90 series heavy
The burning smell could be the motor going out. When the water gets into the tub and makes it heavy it puts strain on the motor and the motor may be getting weak.
Feb 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
121 people viewed this question
Sal De
 Brian Main
Brian Main
