Question about Samsung TX-P2670WH 26" TV
RE: Samsung 26" (CRT) HDTV won't turn on...
Hi Dan ['Absvcs'],
(From NP - Honolulu, HI)
Definitely appreciate your quick reply to my inquiry!
Yup, already tried determining whether there was a pattern to the TV refusing to turn on -- it happens extremely randomly...
Only thing I can think of is that either something got jostled around during the recent move (maybe the movers bumped it too many times?) or possibly the humidity here?
In either case - regarding your suggestion on looking for 'loose connections' I'll try taking a look - Is there any particular area I should concentrate/target?
What do u think are the chances that all this is due to a failed (burned-out) part? (btw - TV is 4yrs old...)
Thank you,
NP
  • Anonymous Nov 19, 2008
    it sucks it wont let me play my xbox im pissed
  • 4,234 Answers
THe problem is not likely to be a defective part although that could be the case. I would first look for poor solder connections that would have been agrivated by any moves that you have made. If you can solder, resolder any connections on any board that appear grainy or have rings.
Keep me posted.
Dan
Posted on Sep 06, 2008
My 2012 ninja 650 wont let me turn key to on position
Hi, Milad for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Key won turn to the on position
Ignition switch won turn ITS STUCK
Ignition key won turn on 2004 Ninja 250R motorcycles
http://mototh.com/files/kawasaki/Ninja-650R/Kawasaki-Ninja-650R-Service-Manual-EN.pdf
Nov 04, 2016 | 2012 kawasaki Ninja 650
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
Hi sir i have my samsung n150 laptop i cannot get wifi driver for win xp
hi
just try this link
http://www.samsung.com/in/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=1401&prd_mdl_cd=NP-N150-JA01IN&prd_mdl_name=NP-N150&srchword=NP-N150
Apr 21, 2011 | Computers & Internet
I've owned this TV since 2004. Yesterday, the display went out suggesting the lamp might need to be replaced. But it also makes a winding type noise. Any thoughts? Thanks, tom
Hi.
We here at FixYa hope that our esteemed colleague could completely satisfy your current inquiry.
If your issue has not yet been rectified, I will be glad to assist you further.
Should you desire any assistance, please reply to this message and Thanks for choosing FixYa.
Oct 03, 2010 | Samsung HLP5085W 50" Rear Projection...
Jenn Air gas range- burner not fully lit
Can you verify which burner it is that won`t ignite/burn properly ?
I should be able to help, but I just need some clarity. I`ll watch for your reply.
macmarkus :)
Jan 24, 2010 | Jenn-Air PRG3610 (NP) Gas Kitchen Range
Samsung DLP
Yup definitely sounds like the ballast, if not then you have a problem in the power supply. Probably some bad capacitors. Call a local tv repair shop.
Nov 28, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HP-R4262- has sound but no picture...
YOU SHOULD HAVE REPLACED THE Y-MAIN BOARD AT THE SAME TIME, NOW DON'T TURN IT BACK ON UNTIL YOU REPLACE THE Y-MAIN OR IT COULD TAKE OUT THE NEW Y-MAIN
Sep 14, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Since the set works some of the time, I'd first look for poor connections. One thing to keep in mind is when the set does NOT work properly. does that occur more frequently with heat? cold? Humidity? If you can solder, first try resoldering any connecitons on the boards that appear grainy or have rings. If that does not resolve the problem, look for patterns for when the set fails. Those patterns will help to narrow down the possibilities.
Keep me posted,
Dan
Sep 05, 2008 | Samsung TX-P2670WH 26" TV
Please see posting at the link below.
no worries Dan... done and dusted:)
Jul 02, 2008 | SAMTRON 55V 15" CRT Monitor
Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
Jan 01, 2008 | Samsung TX-P2670WH 26" TV
Samsung TX-P2670WH 26" TV Logo
585 people viewed this question
Henry  Thomas
Henry Thomas
