Question about Kenmore Sewing Machines
Sewing I can't lift the needle up and down on my kenmoor 1254180
  • 2,071 Answers
Just click below for the guide how to put the needle ;
Sewing Machine 101- Sewing For Dudes (and Ladies) No. 2: Stitches ...
Anatomy of a Sewing Machine. 1) Bobbin winder 2) Spool pin 3) Thread guide 4) Tension Knob 5) Foot and needle 6) Bobbin housing
Hope this may help you;
Regards,
VOTIT
DON'T FORGET TO RATE:
Posted on Sep 06, 2008
How to change the needle
Hello, George -
Since you did not state the make and model of the sewing machine for which you want to change the needle, I can only refer you generic instruction:
This YouTube video may prove helpful:
https://www.youtube.com/watch?v=vMLWbnf-c5U
Jan 13, 2018 | Sewing Machines
Needle stays down, will not come up.
sounds like the machine froze up, machine needs to be serviced
Sep 25, 2015 | Singer 5400 Sew Mate 60-Stitch Sewing...
Singer sewing machine pulls fabric and snarls
try changing the needle--make sure the needle is the right one for the
fabric being sewed.
rethread the machine using every thread guide
try turning the bobbin the opposite direction
clean under the needle plate and in the bobbin area for lint
you may also have to use a washable stabilizer with the fabric
Apr 15, 2013 | Singer Sewing Machines
I cant get the needle to catch the bobbin thread. I just received the machine, i might not be doing it write? any suggestions
This has to be done by hand.
Raise the presser foot, then thread all the way down to the needle. Put in the full bobbin with thread end loose and visible. Hold the end of the thread in the needle with one hand and carefully turn the wheel so that the needle lowers and lifts the bobbin thread. Place both threads behind the presser foot. Now you can sew.
Jan 24, 2011 | Brother XL3750 Mechanical Sewing Machine
Just started to tangle up and jam up not letting needle to go down making a metal noise followed by jaming noise
Sounds very like a bent needle or jammed bobbin case. have you cleared any broken threads or replaced needle? Lift the needle plate and check under that too.
Nov 26, 2010 | Brother CE5000 Computerized Sewing Machine
The thread from the needle keeps breaking
check the top tension-try 3 or 4
change needle & make sure the needle is inserted correctly
some time the needle & thread don't work togeather--try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 17, 2010 | White Sewing 1418 Mechanical Sewing...
Main thread keeps breaking during sewing
here are some suggestions
try rethreading the machine
check the top thread tension
the needle is bent or blunt
the needle is inserted incorrectly
the needle & thread are not compatable---here's a tip how to tell
Oct 17, 2010 | Euro-Pro Fast and Easy 420 Mechanical...
Which way does the flat side of the needle go towards in a 215 model?
the flat side should face the back of the sewing machine
here's a tip I learned about needle & thread compatibility from a needle & thread expert
happy sewing
Oct 12, 2010 | Husqvarna Huskystar 215 Sewing Machine
Why is my machine breaking my top thread
check needle to see if it's damaged
check top thread tension
the needle & thread may not be compatable here's how to check
cut a 6-8 inch piece of thread that your going to sew with, take the needle your going to sew with either from the machine or package
insert the thread into the eye of needle & lift one end of the thread up to a 45 degree angle & see if the needle will slide down the the thread,,if it slides easily it will work with the thread,,if it hangs on the thread,, use a one size larger needle
Sep 30, 2010 | Singer 1120 Mechanical Sewing Machine
Needle won't take up bobbin
Make sure the needle is inserted with the flat side toward the back of the machine.
Lift the presser foot and then re-thread the machine.
Hand walk the needle down and back up while holding onto the end of the thread at the needle, then pull the bobbin thread up and along with the top thread, pull under the presser and to the back of the machine
Mar 06, 2010 | Sewing Machines
Sewing Machines Logo
130 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
